alan(at)kestrel-insurance Guest
Posted: Mon Mar 12, 2007 7:47 am Post subject: Flap motor |
Just before I shipped the aircraft over to the USA I fitted a new flap motor as the old one had died. As you would expect (with my luck). E04 had changed the design of the motor and therefore I had to re position the mountings. Because of the tight timescale for shipping. I never got a chance to flight test this motor until yesterday (yes I actually went flying..!). I notice that the new motor seems a lot slower than the original. The time from zero flap to full flaps is 17 seconds and retracting back to zero is 18 seconds. Has anyone else noticed this and is it normal with the later flap motors?
Many Thanks in advance.
Alan
Trigear 914
N134AB
(look out America its now flying..!)
-- Date: 08/03/2007 10:58
12/03/2007 08:41
NevEyre(at)aol.com Guest
Posted: Mon Mar 12, 2007 11:25 am Post subject: Flap motor |
Hi Alan,
Yes, the newer flap drive motors are much slower in operation, the supply of the original ones dried up when the manufacturer discovered where they were ending up..... a few were purchased covertly, but in the end they sussed......... the only ones that could be found to fit the bill were the ones currently available.
So, not a problem with your motor, they are all that way.
Cheers,
Nev.
jodel(at)nildram.co.uk Guest
Posted: Mon Mar 12, 2007 11:39 am Post subject: Flap motor |
Mine has the zippy motor but the aircraft that I did my check out in was much slower. I know that I have the “old” type but what was in the other I don’t know.
Simon
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Alan Burrows
Sent: 12 March 2007 15:43
Subject: RE: Flap motor
Alan
Trigear 914
N134AB
12/03/2007 08:41 | Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234
Posted: Mon Mar 12, 2007 12:23 pm Post subject: Flap motor |
Thanks Nev.
That’s a relief. I guess I just stay with it then. Do you happen to know who it was that supplied the original motors as I may go direct and try to get hold of some. I can usually get what I want when I need to J
Sorry I didn’t get back to you about the tie downs, but I have been trying to work out what you meant and having a think about it myself. I must be honest the idea of attaching something to the bell crank mounting didn’t really appeal to me. So how about this as an option.
It is possible to get in through the clear plastic inspection cover as you said, so why not design something along the lines of the Europa attachment, but instead of being bent at a right angle to bond into a corner, why not have the plate straight (still with holes in it) and bond it directly onto the main spar. You could hold it in position whilst the adhesive sets either with a piece of wood fed in through the inspection hatch or maybe a couple of screws directly into the spar. That way the load would all be taken directly on the spar and the original Europa eye bolts could still be used.
What do you think?
Alan
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of NevEyre(at)aol.com
Sent: 12 March 2007 19:23
Subject: Re: RE: Flap motor
Hi Alan,
Cheers,
Nev.
-- Date: 12/03/2007 08:41
12/03/2007 08:41
ami(at)mcfadyean.freeserv Guest
Posted: Mon Mar 12, 2007 1:21 pm Post subject: Flap motor |
Alan,
Too late now, but the old flap motor can often be resurrected by cleaning the commutator, which suffers from oil falling in from the bearing above it.
Or new one from the supplier (made in the US and used on RVs and Kitfoxes too).
Duncan McF.
mau11(at)free.fr Guest
Posted: Tue Mar 13, 2007 9:50 am Post subject: Flap motor |
Hello Simon,
Is it possible that you give me the manufacturer and PN of the flap motor?
Thank you
Michel Auvray
Builder N°145 >> 300 hours flight.
[quote] -----Message d'origine-----
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com]De la part de Simon Smith
Envoyé : lundi 12 mars 2007 20:36
À : europa-list(at)matronics.com
Objet : RE: RE: Flap motor
Simon
Alan
Trigear 914
N134AB
5[b]
