bw(at)llanddewi.plus.com Guest
Posted: Wed Mar 21, 2007 3:11 am Post subject: Radio aerial groundplane |
Hi Bob and list.
Have been following list for some time, really excellent source of information.
I have a carbon fibre shell aircraft, Pioneer 300, can I use the carbon fibre belly pan as a ground plane or should I fit a separate one.
The same question is asked about the transponder aerial, and how far from the comms aerial should it be.
Thanks for great list.
Brian
nuckollsr(at)cox.net Guest
Posted: Wed Mar 21, 2007 5:39 am Post subject: Radio aerial groundplane |
At 11:05 AM 3/21/2007 +0000, you wrote:
| Quote: | Hi Bob and list.
information.
The carbon fiber is about 1000 times the sheet resistance
of aluminum and does not make a good ground plane. You'll
need to use "radials" on the comm antennas and either radials
or a full disk ground plane on the transponder antenna. VOR
and GPS antennas generally do not rely on groundplanes for
proper operation.
| Quote: | The same question is asked about the transponder aerial, and how far from
As far as practical but certainly 36" is plenty. Don't
loose any sleep over it if it's only 20".
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
