JimT
Posted: Sun Mar 11, 2007 10:33 am Post subject: Wig wag revisited |
Working on the wig wag system using the B+C flasher.
What is going on inside that flasher?
I set it up on the bench with a DPDT switch. one side powers the flasher , the other the right and left landing lights.
the set up works as is, and the bench ohm meter read 4.5 Kohm between the two terminals.
The switched side of the flasher sees 14 volts when the landing lights are on, but I don't think that can present a problem. Based on this I this I don't think I need to set up the steering diode bridge, but thinking is not the same as knowing.
Also an unsolicited plug: I bought the Dynon installation kit over a year ago. This week when I actually wanted to use it, I found the D-sub crimper wouldn't retract two of the pins. A call to B+C sent a new one out. I was actually looking for advice, as the tool is over a year old, although never used, but they went out of there way to help. ( do you think Rotax is going to extend there warranty on the 912S even though it is still in the shipping box?)
nuckollsr(at)cox.net Guest
Posted: Sun Mar 11, 2007 8:44 pm Post subject: Wig wag revisited |
At 11:33 AM 3/11/2007 -0700, you wrote:
two terminals.
The proof of the pudding is the repeatable
experiment. Give it a try and see what happens.
The schematic on page 3.0 of the suite of drawings
http://www.aeroelectric.com/PPS/Lighting/WigWag.pdf
. . . was developed to have a single switch where
down is OFF, mid is Wig-Wag and up is BOTH ON.
If you don't mind full down not being an off
position, then what you propose may be operationally
fine. It would help if you would post a schematic.
JimT
Posted: Mon Mar 12, 2007 5:28 pm Post subject: Wig wag revisited |
Bob
Sorry for the delay. I attempted to learn the express software for this, and simply could not get it off my clipboard. so here is the free hand version. Sorry about the quality but I think it tells the basics
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
13.72 KB |
465 Time(s) |
Posted: Mon Mar 12, 2007 8:57 pm Post subject: Wig wag revisited |
Understand. What you've shown should function just fine.
At 09:26 PM 3/12/2007 -0400, you wrote:
| Quote: | Bob
