Door Locks?
Nick(at)Scholtes1.com
PostPosted: Wed Mar 07, 2007 1:38 pm    Post subject: Door Locks? Reply with quote
All,
I envision taking my 'Fox to places where I want to leave it sit on the
ramp unattended for a while. Is a locking mechanism for the KitFox IV
doors already invented? Does someone have plans, or is there an
aftermarket device? I've studied it, and don't want to re-invent the
wheel if I don't have to.
Best,
Nick
kitfox69(at)earthlink.net
PostPosted: Wed Mar 07, 2007 3:14 pm    Post subject: Door Locks? Reply with quote
Hi Nick,
A trick I used and it works well, is to dispense with any knobs outside
the door and just insert a home made key bent in a "L"shape out of 1/8
round stock. Put it on your key chain and just place it in the slot on the
outside, engaging the hole on the striker and slide it back. Works great
and would take someone with "ill intent" a while to figure out. Recently, I
added a cover over the slot to further foil evil doers. It's just a 1 inch
X 3/8 inch piece of light aluminum flashing, ends rounded, with a
rivet in one end. Turn it down outa the way, insert your homegrown key,
and WALA! , the door she has opened!
Regards, Floyd
[Original Message]
To: kitfox-list(at)matronics.com <kitfox-list(at)matronics.com>
Date: 3/7/2007 4:44:47 PM
Subject: Door Locks?
All,
Best,
Nick
kitfoxmike
PostPosted: Wed Mar 07, 2007 3:29 pm    Post subject: Re: Door Locks? Reply with quote
I went to the aviation dept. at home base and got a lock with a lever, for a cabinet, and put it on the door when locked it holds the door to the fuse. On the other door I put a bolt in the lock mechanism, I have one in each door to keep them both from opening in flight, held in place with mech. wire. Next time I'm at the plane I'll take some pics.
tleiss(at)earthlink.net
PostPosted: Wed Mar 07, 2007 4:44 pm    Post subject: Door Locks? Reply with quote
I also have the Tool Box type key lock with the swinging arm. Mine are on
both sides, with same key..I'll try to remember to take photos too..
Todd Leiss
Model IV Speedster
Merritt Island, FL
[Original Message]
Date: 3/7/2007 6:42:43 PM
Subject: Re: Door Locks?
kitfoxmike
model IV, 1200
speedster
912ul
http://forums.matronics.com/viewtopic.php?p=99357#99357
smokey_bear_40220(at)yaho
PostPosted: Wed Mar 07, 2007 5:57 pm    Post subject: Door Locks? Reply with quote
I installed my door latch with bolts that go thru the
frame and door skin. These bolts have hex heads, so a
hex-key on my key-ring works. Not foolproof, but a
deterant to those not too mechanically enclined.
I worry about crash crew/first on sceen responders
being able to open the doors without some tool in case
of an accident where I am not able to open from the
inside. Comments? I am sure a determined person will
get a KitFox's door open.
Had a friend with a Tri-Champ (Nose gear under the
rear seat) who's plane was borken into. Caused $400
damage to the door in order to steal a $30 CB radio.
The door was not locked! Apparently the thief
couldn't even operate a Champ door handle???
Kurt S.
--- Nick Scholtes <Nick(at)Scholtes1.com> wrote:
All,
leave it sit on the
for the KitFox IV
is there an
to re-invent the wheel if I don't have to.
Best,
Nick
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
http://games.yahoo.com/games/front
Float Flyr
PostPosted: Wed Mar 07, 2007 6:52 pm    Post subject: Door Locks? Reply with quote
These are very light built planes not bank vaults.... If thieves will break
in through the window of a car don't kid yourself thinking that any lock on
a fabric plane will keep them out.
Never leave the keys in the ignition, come to think of it never leave
anything in the plane (GPS or portable radios) and leave the doors open.
Also when possible park in a secure area.
A Lock is only to tell an honest man there is no one home.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Wed Mar 07, 2007 7:42 pm    Post subject: Door Locks? Reply with quote
I have seen the result of thieves stealing a stereo out of a Cadillac. The
quickest way, the method they used was to plug an electric chainsaw into the
power outlet and remove the part of the dash they wanted.
The mistake your friend made was leaving the CB in the plane. If they had
any trouble removing it they could have done a lot more damage. Imagine if
they didn't know the Kitfox door was hinged at the top...
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Bill Willyard
PostPosted: Thu Mar 08, 2007 6:33 am    Post subject: Door Locks? Reply with quote
Nick, I installed locks in both my doors using cam-lock mechanisms purchased from a lock shop. I had them keyed the same for simplicity. By attaching a small piece of aluminum to the inside handle of the door latch, the cam-lock can be used to secure the door without hindering normal door operation when in flight. See attached photo.
Also here is a link that will show some of the many cam-lock options available.
http://www.monroeengineering.com/locks/Cam-Lock/index.htm
Bill W.
 Filesize:  99.15 KB
 Viewed:  573 Time(s)
Bill Willyard
Classic IV 912UL
kitfoxmike
PostPosted: Thu Mar 08, 2007 7:04 am    Post subject: Re: Door Locks? Reply with quote
The kitfox is not a bank vault. But, the thing I hate most is when people get snoopy, or just want to see the experimental out front. Usually they want to sit inside and play with the controls, of course without you knowing. Having some sort of lock on the door takes care of this.
84KF
PostPosted: Thu Mar 08, 2007 7:52 am    Post subject: Re: Door Locks? Reply with quote
"...the thing I hate most is when people get snoopy, or just want to see the experimental out front. Usually they want to sit inside and play with the controls...."
Those non-aviation creeps should just learn to control their dreams and desires.
We need a new FAR.
Oh...I do that with every plane I can.
Float Flyr
PostPosted: Thu Mar 08, 2007 8:15 am    Post subject: Door Locks? Reply with quote
My main worry about leaving the plane out where unknowing people have easy
access to it is that many people don't realize the plane is actually covered
with cloth. On one occasion I had to stop one fellow form checking to see
if it really was cloth with his pocket knife. I live in an area where
snowmobiles are as common as grass. I've been asked, not if the engine came
out of a Ski-Doo but did I think it would fit in a Ski-Doo and have more
power.
I had a friend who had his Seawind 3000 vandalized and the idiot broke the
canopy and stole the battery. The next day he was stopped for speeding and
the Mountie saw the battery in the back of his truck. When he was asked
about the strange looking battery, I think it was a NiCad, he said it was
picked up from a friend the night before. His finger prints matched and he
was prosecuted to the full extent of the law.
In Gander, CYQX, at the seaplane base there is free open access to the
waterfront. A few years ago they put up signs asking people not to fish in
the vicinity of the planes. Since the signs went up there has been no
problems. The people are used to seeing planes and now don't bother them.
There are also better places to fish close to Gander. Of the dozen or so
planes docked there I don't know of any that are locked...those that have
ignition keys ( The beavers generally don't ) the keys are generally
removed. There are no locks on the moorings.
The past few years I've always towed my plane to the pond I fly from. This
costs me an extra hour or two in time to go flying and an extra hour or two
to get the plane back to the garage. More than once I towed the plane to
the beach, unfolded the wings, fuelled the plane and then had to undo
everything and tow back home. (a bit over a mile) In that time the worst
thing that can happen is to have someone offer to help me either launch or
recover the plane.
That was where the fellow was going to see for himself if the plane was
cloth covered. I asked him how he would feel about it if I were to hack a
piece out of his new truck with my knife... His answer was, "Sorry I never
thought about that".
Next summer I have a more remote area to beach the plane in mind. As soon
as I am sure there are no little kids around the two camps close to the
beach I'll pull the plane up there and carry my fuel in to the plane with an
ATV. Any time I'm expecting bad weather the plane will go back to the
garage.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Guy Buchanan
PostPosted: Thu Mar 08, 2007 8:33 am    Post subject: Door Locks? Reply with quote
takes care of this.
In that case Murle Williams' door latches will work. His require an
Allen wrench to open from the outside. I used a modified version of
his design and am quite happy with it.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
kitfoxmike
PostPosted: Thu Mar 08, 2007 8:39 am    Post subject: Re: Door Locks? Reply with quote
I've had more problems with other pilots, generaly the ones with the certified airplanes, the older folks that can't fly anymore... the list goes on.
I really like to be at an airshow where there are kids and I'm there with the plane, I like putting the kids in the plane and watch their eyes light up. The fox fits the kids much better than one of those spam cans.
clemwehner(at)sbcglobal.n
PostPosted: Thu Mar 08, 2007 11:01 am    Post subject: Door Locks? Reply with quote
This subject comes up every few years on this list. A few years back,
the simplest solution proposed was to drill a hole through the bottom of
both door frames and put an aluminum rod through the door frames across
the cockpit with a lock on one end. It can be done with almost no
visible change to the aircraft except for the 2 small holes. It can be a
small lock, because as someone said you don't need a big lock because
you won't prevent a determined intruder anyway, but might deter some
idiot who just wants to sit inside and play with your knobs.
Clem
Lawton, OK
KF-IV, 912
Float Flyr
PostPosted: Thu Mar 08, 2007 12:00 pm    Post subject: Door Locks? Reply with quote
I agree....The operative words here are, "I'm there with the plane".
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
lcfitt(at)sbcglobal.net
PostPosted: Thu Mar 08, 2007 12:39 pm    Post subject: Door Locks? Reply with quote
Nick,
I used a couple of pieces of SS cable with swaged loops on the ends that
can fit through the holes on the outside door handles and passes under the
fuse. I put some heat shrink on critical areas to prevent scuffing the
fabric and lock it with a hasp lock. As someone else suggested, it will
keep the relatively honest out, but nothing, I guess will keep the real bad
guy out.
Lowell
7suds(at)Chartermi.net
PostPosted: Thu Mar 08, 2007 3:46 pm    Post subject: Door Locks? Reply with quote
Bill,
I like your setup, I had the same in my IV less the bungy and the lock. One thing I added to mine was another latching leg alongside the one you have that goes down along the inside of the fuselage holding the door closed. It was positioned farther in towards the seat to allow the original one to go on the outside of the fuselage and the new one on the inside, this would hold the door about a half inch open for those hot days that you wanted to get a little breeze but something that would not blow everything around the cockpit.
Lloyd
Bill Willyard
PostPosted: Thu Mar 08, 2007 6:46 pm    Post subject: Door Locks? Reply with quote
Thanks Lloyd, I may give that a try.
Bill W.
Bill Willyard
Classic IV 912UL
