klaus.dietrich(at)oracle. Guest
Posted: Wed Mar 07, 2007 1:06 am Post subject: Buzzer |
Hi,
flying a LOM 332 AK powered Bucker since two years, I'm just wondering who else is on the list?
I have now 200hrs on the engine and so far all is fine (except one engine stop inflight, due to a sticking gravity valve after aerobatics....)
Have cleaned the contacts of my buzzer with the result that it's not working anymore; any idea how to properly service and adjust the buzzer?
And do I have to do any service of the magnetos yet?
Klaus (Vienna)
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> vCard Klaus Dietrich Klaus Dietrich 4 2 2007-01-04T14:23:00Z 2007-01-16T12:05:00Z 1 15 88 Oracle Corporation 1 1 108 9.7616 <![endif]--> <![endif]--> <![endif]-->
Klaus Dietrich
Oracle Financing EMEA
Tel/Fax: +43 1 33 777 825
http://www.oracle.com/financing
document.write("")
| - The Matronics Lom-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
bobf(at)feldtman.com Guest
Posted: Wed Mar 07, 2007 6:38 am Post subject: Buzzer |
Klaus - I have the 332B engine - 50 hrs on a glastar. You can get the
buzzer from moraviation.com in Canada or probably from the factory in
Prague - you are so close. You have already cleaned the points on the
contact - there is only a capacitor and a coil in there. MAke sure all
the connection are solid for the P leads going to the buzzer. It is more
likely a connection problem! There is a procedure to check the current
draw through the buzzer points, but don't let it be "on" for more than a
few seconds, or it might burn it out. Do you have the engine manual?
So far I am happy with the LOM engine here in the USA. We have no LOM
mechanics in Texas, so I guess I will have to do most of the work!
Besten gluck!
bobf
aerobatics....)
Klaus (Vienna)
Klaus Dietrich
Jeayers1(at)aol.com Guest
Posted: Wed Mar 07, 2007 6:54 am Post subject: Buzzer |
Hi Klaus,
I installed the "Slick Start" in place of the buzzer. It is a solid state unit, so there is no maintenance. Aircraft Spruce sells them for $349.95 US. I think they were about $270 US, when I bought mine.
I have a M332A engine in a RV-3.
Jim Ayers
Newbury Park, California
(805) 795-5377
In a message dated 03/07/2007 1:06:44 AM Pacific Standard Time, klaus.dietrich(at)oracle.com writes:
Klaus (Vienna)
Klaus Dietrich
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
