LHusky(at)aol.com Guest
Posted: Mon Mar 05, 2007 3:24 pm Post subject: New "European XL" from Zenith? |
Anyone know what the "Lighter" parts are? Are the flaps fiberglass?
Larry
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Mar 05, 2007 3:48 pm Post subject: Re: New XL |
Flaps fiberglass? Maybe. Look at the main gear. I suspect they shaved a few pounds there.
Tim
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Mon Mar 05, 2007 3:53 pm Post subject: New "European XL" from Zenith? |
The curved landing gear could be composite: www.zenithair.com/zodiac/607/xl-eu7.jpg.
-- Craig
Kurt.Schumacher(at)schumi Guest
Posted: Mon Mar 05, 2007 5:51 pm Post subject: New "European XL" from Zenith? |
In general, the limitation for European Ultralight is 450 kg plus a 22.5 kg
allowance for the rescue system if installed. On pilot with fuel - or two
crewmembers and virtually no fuel....
Stay happy with the LSA regulations over there in the US. One day we might
see a EASA Recreational Aircraft class - in some hundred years when the
Brits, the French, the Portuguese, the Spanish and the German can agree.
Amazed they manage Airbus - aside some lay-offs these days.
Suspect lightweight fiberglass or carbon cowling (was an option from CZAW)
Landing gear bows like the CZAW introduced glass gear legs (engineered to
550 kg MTOM AFAIK)
By the way, there are some pics more to see in the Zenith web - check
http://www.zenithair.com/zodiac/607/xl-eu2.jpg to xl-eu7.jpg
Have Fun!
-Kurt.
SportAviation of Switzerland
http://www.sportaviation.ch/
ashontz
Posted: Tue Mar 06, 2007 1:44 pm Post subject: Re: New |
[quote="craig(at)craigandjean.com"]The curved landing gear could be composite: www.zenithair.com/zodiac/607/xl-eu7.jpg.
-- Craig
I was going to say, that's a definite.
I'd have to think a fiberglass flap would be heavier. Aluminum is about as light as you can go. I know an aluminum boat and a fiberglass boat of the same size, the fiberglass one will be much heavier.
planecrazydld(at)yahoo.co Guest
Posted: Tue Mar 06, 2007 3:20 pm Post subject: New "European XL" from Zenith? |
I got an e-mail from Nick this afternoon and he said that they expect to have the arched gear available by the summer (2007?)!
ashontz <ashontz(at)nbme.org> wrote: [quote]--> Zenith-List message posted by: "ashontz"
[quote="craig(at)craigandjean.com"]The curved landing gear could be composite: www.zenithair.com/zodiac/607/xl-eu7.jpg (http://www.zenithair.com/zodiac/607/xl-eu7.jpg).
-- Craig
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
Read this topic online Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. [quote][b]
dfmoeller
Posted: Wed Mar 07, 2007 5:48 am Post subject: Re: New |
Around the first of this year, I was asking some questions of the factory about relocating the 912S engine a bit further forward to relieve some of the ass-heaviness of the 601XL (among other things). Caleb told me the following via email:
"The Czech Aircraft Works did use a longer engine mount for their 601XLs, but it was much longer, I believe about 9" longer. They made several changes and I think the engine mount being that long was to counter the effects of another change. That being said we are working with our European dealer to produce a new firewall forward package for the 912S that shifts the CG forward. That should be available this summer, but I don't know what that will cost at this time. Another option for you is to get a metal prop for it. They weigh about 15lbs more and being at the very nose of the aircraft will help out a great deal."
Sounds like there may be several changes in the works. I'm hoping this becomes available soon. I'm a big guy and my bird is limited in useful load by rearward CG, not by MTOW.
Doug
Tim Juhl
Posted: Wed Mar 07, 2007 8:39 am Post subject: Re: New |
Doug,
When you refer to "ass-heaviness" do you find yourself using excessive nose down trim in flight with just yourself aboard? Or is the problem that it is light on it's nose when parked (ie. tail grounds when you climb on the wing.) I've been advised that the orientation of the main landing gear when installed can make a big difference in the latter. They say if you install the gear facing the way it is shown in the current plans that grounding the tail is more likely. They also say that installing it facing as it was originally requires a bit more of a pull to rotate and get it flying.
I'm a big guy too but I assumed since people and fuel were fairly close to the CG that it would be hard to get out of the envelope unless you put too much weight towards the back of the rear luggage area.
Tim
CFII
Champ L16A flying
dfmoeller
Posted: Wed Mar 07, 2007 5:47 pm Post subject: Re: New |
Tim,
Actually, the trim isn't terribly effective either way. I have the older, smaller style trim tab, and on approach while lightly loaded, it really won't hold the nose up. Not a problem though, some think thats a safer condition, and I tend to agree.
The 601XL does have some W&B issues though, at least with the 912S installed in the older Zenith engine frames. The Cg is almost at the forward limit, unloaded. About 6 or 8 months ago, there was a thread on this forum wherein a guy described moving his engine forward to try to rectify the issue. The CZAW engine frames were designed to carry the engine more forward than the Zenith ones. I'm 6'4", 280#. With another man on board, figure an average guy at 200# (the mythical 180 pounder was only an average, and that isn't even accurate anymore - this leaves half the population out!!!!), this only leaves 80 pounds for fuel (which still puts the W part safely within the early XL's 1300# MTOW - barely): not a whole lot. Now the kicker! When this fuel load approaches zero, the Cg moves almost 15 mm past the rearward limit - a very dangerous condition. This makes flight planning a real challenge.
Look at some of the Excel W&B spreadsheets made by some on this forum. You'll see that I'm not alone in this.
This situation makes the rear luggage area almost unusable. Install the wing lockers!!!!
This is why I was asking Zenith about moving the engine; that would be a perfect solution.
Note, I am only talking about the Rotax engined models. I believe the Jabirus hold the engine forward already, although they are a few pounds heavier.
My gear is installed in the older manner, so on the takeoff roll, one REALLY has to yank the craft off the ground; it simply will not fly itself off the ground. And on landing, its simply impossible to keep the nose in the air. It is extremely difficult to raise the nose by pressing the tail down, too. I am currenlty in the middle of some fairly extensive work on the bird at present, so I was planning on reversing the gear in the process. This might help the balance issue a bit, too (marginally, but anything helps). I am a little apprehensive though, I fly out of a grass strip thats not maintained all that well, and I wonder how the new gear placement will make the plane behave during all the bouncing around. It seems like the wheelbase will be awfully short then. We'll see! It should be easy enough to change back, if I don't like it.
Doug
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Wed Mar 07, 2007 8:45 pm Post subject: Re: New |
| dfmoeller wrote: | | "The Czech Aircraft Works did use a longer engine mount for their 601XLs, but it was much longer, I believe about 9" longer. They made several changes and I think the engine mount being that long was to counter the effects of another change. Another option for you is to get a metal prop for it. They weigh about 15lbs more and being at the very nose of the aircraft will help out a great deal." |
It's a crock. I know first hand. 15 lbs in the nose will help some, but not as much as moving the whole engine forward 9 inches (duh ... don't even need to do the math on that one).
I had Chris and Matt look over the first LSA out of CZAW (my plane). They scrutinized it with every intention of finding fault. In the end, not even Chris could tell me what was significantly different.
I had to have a new mount and cowl shipped from CZAW and put on by Lockwood in Florida. They did a great job, by the way. The CG is still not where I'd like it, but most definately usable and safe.
ZAC just plain screwed up, in my opinion. Odd that they blame CZAW but then offering the same extra long mount as CZAW.
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
David X
Posted: Wed Mar 07, 2007 8:49 pm Post subject: Re: New |
P.S. The longer mount for my plane was designed by Chris/ZAC, not CZAW. I requested a letter for insurance purposes that indicated it was of ZAC design and specification.
DO NOT ARCHIVE |
dfmoeller
Posted: Thu Mar 08, 2007 5:49 am Post subject: Re: New |
David,
I agree; adding 15 pounds is a poor alternative to moving existing weight. Plus, not nearly as effective.
Do you have any pix of your new installation, particularly the cowling? I'd love to compare the two closely.
The new pix on the ZAC website really don't make the nose look 9" longer to me. Does that cowl look like your in the profile ground shot? It looks a lot like my old one.
Doug
David X
Posted: Sun Mar 11, 2007 9:21 am Post subject: Re: New |
| dfmoeller wrote: | David,
Doug |
I don't have any side-on, so a little hard to see the difference, but the nose is moved out about 9 inches. See attached.
641.16 KB |
620 Time(s) |
89.36 KB |
579 Time(s) |
DO NOT ARCHIVE |
