landing light
sperry50(at)comcast.net
PostPosted: Sun Mar 04, 2007 3:42 pm    Post subject: landing light Reply with quote
[quote]I have made the cut out in the leading edge and also have the landing light assembly clecoed in place but I still can’t get the lens into the cut out. I am afraid to force it for fear it will crack. I have checked and re-checked the cut out and it seems to be in the correct place and the measurements all seem correct. Does anyone have any tips for getting the lens to fit in the cut out hole? The assembly photos mention cutting a pie shaped piece but no measurements are given. Skip Perry601 quick build [b]
Jaybannist(at)cs.com
PostPosted: Sun Mar 04, 2007 3:53 pm    Post subject: landing light Reply with quote
Skip,
I just trimmed my lens "by guess & by gosh." I probably trimmed it (progressively) three or four times before I could get it to go into place. A very poor design, if you ask me. The same goes for the sheet metal screws that hold it in place.
Jay in Dallas
assembly clecoed in place but I still can't get the lens into the cut out. I
Skip Perry
601 quick build
PostPosted: Sun Mar 04, 2007 4:02 pm    Post subject: landing light Reply with quote
Skip,
By the way, your message was in a VERY small and all on the same line.
Jay in Dallas
Skip Perry
601 quick build
jhstarn(at)verizon.net
PostPosted: Sun Mar 04, 2007 4:25 pm    Post subject: landing light Reply with quote
Your leading edge is different. But we put the lens inside before mounting the assembly with screws. Took a piece of duct tape about 4" long & 1" wide. Folded the center together for about an inch & attached the two remaining "tabs" to the lens. A lot easier to handle. KABONG
Michael Valentine
PostPosted: Sun Mar 04, 2007 4:40 pm    Post subject: landing light Reply with quote
I also had to round the corners of the lens - that was enough for me to slide it in.
Michael in NH
On 3/4/07, Skip Perry < sperry50(at)comcast.net (sperry50(at)comcast.net)> wrote:[quote]
I have made the cut out in the leading edge and also have the landing light assembly clecoed in place but I still can't get the lens into the cut out. I am afraid to force it for fear it will crack. I have checked and re-checked the cut out and it seems to be in the correct place and the measurements all seem correct. Does anyone have any tips for getting the lens to fit in the cut out hole? The assembly photos mention cutting a pie shaped piece but no measurements are given.
dredmoody(at)cox.net
PostPosted: Sun Mar 04, 2007 6:29 pm    Post subject: landing light Reply with quote
I second that; in fact I decided to use flush set solid rivets holding nutplates for #6-32 screws to secure the lense.
Dred
PostPosted: Sun Mar 04, 2007 6:31 pm    Post subject: landing light Reply with quote
My first attempt was equally frustrating and nerve racking. Then I cut the lense down to a size that was just enough larger than the hole to allow a safe edge distance from the holes. After that the lense was a lot easier to fit into the hole.
Dred
demeo(at)sonic.net
PostPosted: Sun Mar 04, 2007 9:54 pm    Post subject: landing light Reply with quote
Trim the lens until it is about 3/8 to 1/2 inch on each side. I used an
olfa knife and got it trimmed to size in about 8 minutes. Keep the lens
warm so it won't crack like mine did when I tried to fit it this winter.
A new lens is very expensive. Round off carefully the corners. Use the
tape method to pull the lens forward once you have it in. It takes a
lot of patience, but it will soon fit. Good luck.
Brad
The information contained in this transmission is attorney-client privileged and/or confidential information intended for the use of the individual or entity named-above as recipient. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
IRS circular 230 Disclosure: As required by U.S. Treasury Regulations governing tax practice, you are hereby advised that any written tax advice contatined herein was not written or intended to be used (and cannot be used) by any taxpayer for the purpose of avoiding penalties that may be imposed under the U.S. Internal Revenue Code.
demeo.vcf
 Filename:  demeo.vcf
 Filesize:  264 Bytes
 Downloaded:  385 Time(s)
ccwacker(at)HOTMAIL.COM
PostPosted: Mon Mar 05, 2007 6:11 am    Post subject: landing light Reply with quote
You will need to cut the lens. Zenith doesn't tell you about that but it is
the only way to get it in.
Chuck Wacker
601XL Quick Build
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: landing light
Date: Sun, 4 Mar 2007 18:43:02 -0500
I
all
Skip Perry
601 quick build
Rates near 39yr lows! $430K Loan for $1,399/mo - Paying Too Much? Calculate
new payment
japhillipsga(at)aol.com
PostPosted: Mon Mar 05, 2007 6:33 am    Post subject: landing light Reply with quote
Skip, that lens can be a real bear. I screwed mine up a bit, but learned from a fellow at Sun n Fun last year a method to get it right. He said to make a wood form the shape of the wing nose. Make a thin cardboard template that will fit in the hole in the wing edge. Make the Lexan the size of the cardboard. Now here's the tricky part. The fellow said that Lexan does not become soft and malleable until it gets to something like 300 degrees ?? His method was to put the form sanding nose up into the oven with the Lexan on top and heat it until the plastic bends down to the shape of the nose skin form. Sounded like a neat way to size and bend the material. I have not tried it myself, but it might work. The fellow may be on this thread. Perhaps you could find him for more details. Best regards, Bill of Georgia
naumuk(at)alltel.net
PostPosted: Mon Mar 05, 2007 4:14 pm    Post subject: landing light Reply with quote
Skip-
Jeff Small passed the procedure on to me. I don't know if he originated it, but I've seen his plane and can tell you that it works for an HDS, with it's thick wing. Probably work for an XL, too, with a little extra juggling and swearing.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Ron Lendon
PostPosted: Mon Mar 05, 2007 7:22 pm    Post subject: Re: landing light Reply with quote
I wouldn't recommend heating plastic in a oven you plan on using to prepare food in. Just not a good idea.
Fitting is just part of the process of making it right.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
marinegunner(at)gmail.com
PostPosted: Tue Mar 06, 2007 4:55 am    Post subject: landing light Reply with quote
As a long time fire fighter, I do not think I would heat plastic in a
cooking oven. I know of several folks who got at least a partial new
home from such antics.
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
This and all other incoming/outgoing email, attachments and replies
scanned prior to opening/sending and uses an external firewall to help
insure virus free email and attachments.
pmaxpmax(at)HOTMAIL.COM
PostPosted: Tue Mar 06, 2007 9:24 am    Post subject: landing light Reply with quote
This is why this list has its limitations. People speculate.  Too much time to think. I mean no disrespect to you, Ron. But I read through emails for people who say things like, "I did this",  and "I know first hand."
So here's what I know first hand: I heated my Plexiglas lens in the very same oven we use to feed our family -- GASP --
with no ill effects. Not a smell, no one came down with cancer in the intervening years. The temps are so low there is no problem. The Thanksgiving Turkey even tasted good Smile
Phil Maxson
601XL/Corvair
Northwest New Jersey
> Subject: Re: landing light
Date: Mon, 5 Mar 2007 19:22:33 -0800
--> Zenith-List message posted by: "Ron Lendon" <rlendon(at)comcast.net>
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder Wink
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! Try it! [quote][b]
planecrazydld(at)yahoo.co
PostPosted: Tue Mar 06, 2007 12:24 pm    Post subject: landing light Reply with quote
...especially if you allow the oven to sit at its self-cleaning cycle for a little while afterwards...
Phil Maxson <pmaxpmax(at)hotmail.com> wrote:
[quote] P { margin:0px; padding:0px } body { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } This is why this list has its limitations. People speculate. Too much time to think. I mean no disrespect to you, Ron. But I read through emails for people who say things like, "I did this", and "I know first hand."
Phil Maxson
601XL/Corvair
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! Try it! 601XL/Corvair?
8:00? 8:25? 8:40? [url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news] Find a flick[/url] in no time
with the[url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news]Yahoo! Search movie showtime shortcut.[/url] [quote][b]
ashontz
PostPosted: Tue Mar 06, 2007 1:37 pm    Post subject: Re: landing light Reply with quote
[quote="planecrazydld(at)yahoo.co"]do not archive
Phil Maxson
601XL/Corvair
--> Zenith-List message posted by: "Ron Lendon" <rlendon>
Worst case, take it to the local high school and ask if you can put it in the kiln.
Even so, I don't see why it would be that hard to make a mini-oven using some flashing or aluminum sheet, sticking the part in there, and then toting the kerosene heater outside and plopping it on the top for a few minutes.
Ron Lendon
PostPosted: Tue Mar 06, 2007 8:55 pm    Post subject: Re: landing light Reply with quote
None taken Phil, I found a thermo plastic shop down the street and let them drape it to the form I made. I had an incident years back with a motorcycle chain, grease and an oven. I guess I'm a little oven shy after that one.
I thought the nut plate idea was pretty good so tonight I made em up. The bottom ones won't be used because it looks like there won't be any clearance. The tops one should work fine though.
Ron Lendon
CH 601 XLB
N601LT - Flying
