Recommended Transponder
John H Murphy
PostPosted: Mon Feb 26, 2007 10:36 pm    Post subject: Recommended Transponder Reply with quote
I'm in the process of getting my Firestar registered. I will need a transponder to use one of the airports I may be flying into. Any recommendations as to what transponder I should purchase? I notice a Garmin 327? on ebay for about $1,600. Is this overkill for what I need?
dhkey(at)msn.com
PostPosted: Tue Feb 27, 2007 4:33 am    Post subject: Recommended Transponder Reply with quote
John, I have the Garmin 327 in my Kolb, I like it. Yes it's overkill but it
looks good. I fly out of class D under B in the mode C veil.
Reply-To: kolb-list(at)matronics.com
Subject: Recommended Transponder
Date: Mon, 26 Feb 2007 22:36:41 -0800
http://forums.matronics.com/viewtopic.php?p=97569#97569
 Filesize:  179.65 KB
 Viewed:  546 Time(s)
Russ Kinne
PostPosted: Tue Feb 27, 2007 6:00 am    Post subject: Recommended Transponder Reply with quote
Check Trade-A-Plane too!
need?
by0ung(at)brigham.net
PostPosted: Tue Feb 27, 2007 7:26 am    Post subject: Recommended Transponder Reply with quote
need?
You may want to try some of the FBO's in your area... sometimes they will
have something that they have removed for an upgrade in a ga aircraft and
will have a good unit for 1/2 price. I am working on getting one and the
previous owner is sending it to the factory for a full checkout. He wants
only 500 for it. I will have to spend a bit more for the encoder but he
thinks it will come to about 700 total.
Boyd
jim
PostPosted: Tue Feb 27, 2007 9:40 am    Post subject: Recommended Transponder Reply with quote
Is this airport in Class B or C airspace? How often will you be flying
into it? If it's Class C and you're only flying into it occasionally, I
would probably skip the transponder and encoder. Instead I would call
your local RAPCON on the phone and ask them if it is a problem getting
clearance into the airspace on short notice. If you have no Xpdr
installed the regs say you need 1 hr advance notice, but I suspect they
will say no problem in which case I would just call by radio when you want
to go in.
If it's class B and/or you plan to go into this airport often, I'd find
the cheapest Xpdr & encoder I could find. Theoretically/legally this also
means a transponder check every 2 years.
In case you didn't know, the blind encoder is a separate device that
determines your altitude referenced to 29.92 and inserts that altitude
into the return echo so the radar operator can get an altitude readout.
The cheapest (new) is about $179. You will also need an antenna, cable,
and it should have a circuit breaker. It's called "blind" because it
doesn't know what your altimiter's altitude is. Non-blind encoders are
internal to the altimiter.
Jim
N. Idaho
Jim
N. Idaho
planecrazzzy
PostPosted: Tue Feb 27, 2007 3:30 pm    Post subject: Re: Recommended Transponder Reply with quote
Wentworth has alot of stuff....
captainron1(at)cox.net
PostPosted: Tue Feb 27, 2007 9:14 pm    Post subject: Recommended Transponder Reply with quote
---- John H Murphy <jhm9812(at)yahoo.com> wrote:
--> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com>
If money is no object get the smallest one you can find. There is an Australian one http://www.microair.com.au/ however they are all otherwise the same. I would buy a used one at around $600 You will also need an encoder for altitude reporting those are under $200.
Get a radio shop for the installation it will save you some potential
Thom Riddle
PostPosted: Wed Feb 28, 2007 5:18 am    Post subject: Re: Recommended Transponder Reply with quote
I found a King refurbished by an avionics shop and yellow-tagged (which means it is certified and good enough for standard category aircraft) on eBay for about $630 not including the Mode C encoder or antenna. I bid on several until I finally got the price I wanted. I had a local avionics shop install it including the Mode C and antenna for about $550 and he certified the altimeter in the process. It has been working full time without a hitch for over a year now and am glad to have it.
Thom in Buffalo
