Parking brake
aprazer
PostPosted: Tue Feb 20, 2007 12:54 pm    Post subject: Parking brake Reply with quote
Ladies and Gents,
I have purchased a Matco parking brake valve and now I am wondering where to install it, so that it will be convenient, but unsightly. Also, what kind of handle works best? Can anyone supply me with this info and possibly pictures?
Mack
601XL in final stages
The poh-oh-unemployed farm boy from Idaho
japhillipsga(at)aol.com
PostPosted: Tue Feb 20, 2007 1:54 pm    Post subject: Parking brake Reply with quote
Mack, again, I built my XL with only left side brakes and no parking break valve. At the annual teardown I added brakes on the right side and the Matco parking break valve. Best mods I have made to date and wish I had installed them in building as you are. Working standing on my head was a real pain!!. I mounted the valve in the center of the plane on top of the heal pan. I made a bracket for a pull cable and ran the knob under the dash at the far left out of the way for entry. Works great and it should be a standard part on the XL. I wish I had some photos to send you as I'm proud of how well it came out. You are welcome to come see it anytime your nearby. Best regards, Bill of Georgia
craig(at)craigandjean.com
PostPosted: Tue Feb 20, 2007 3:05 pm    Post subject: Parking brake Reply with quote
I've attached pictures of how the valve is installed in Bob Archibald's
601XL at Dragonfly Aviation. Note that his plane has pilot and copilot brake
pedals.
Also look at the link below for how the valve was installed in an RV-7.
There are links to the Matco diagrams and some of the fittings which make
for a cleaner installation. For a knob I just bought one of Spruce's cheaper
push/pull cables.
www.rvproject.com/20030521.html
-- Craig
 Filesize:  25.77 KB
 Viewed:  383 Time(s)
 Filesize:  60.27 KB
 Viewed:  396 Time(s)
601zv(at)ritternet.com
PostPosted: Tue Feb 20, 2007 4:51 pm    Post subject: Parking brake Reply with quote
I put mine just left of center about 11" up on the firewall, and fabricated
a bracket several inches above it for a control cable to the insrument
panel.
Robin in AR
N601ZV
aprazer
PostPosted: Wed Feb 21, 2007 2:32 pm    Post subject: Re: Parking brake Reply with quote
Howdy Everyone,
A note of thanks to all for the input -- all your ideas are good, just now to decide which I like the best
Thanks again,
Mack
btucke73(at)yahoo.com
PostPosted: Wed Feb 21, 2007 5:52 pm    Post subject: Parking brake Reply with quote
While researching my next project, a long travel sand
car, I found this:
http://www.team-moto.com/index.cfm?action=ViewDetails&ItemID=62&Category=5
-this would work well for those of us that used
compression fittings and "Plastic" brake lines.
VR/
Brandon
601 HDS / TD / Corvair
70 hours
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
http://mobile.yahoo.com/mail
aprazer
PostPosted: Thu Feb 22, 2007 7:45 am    Post subject: Parking brake Reply with quote
Brandon,
This parking brake is far cheaper than the $105 that I spent on the Matco!
Thanks for the heads up,
Mack
Jaybannist(at)cs.com
PostPosted: Thu Feb 22, 2007 8:13 am    Post subject: Parking brake Reply with quote
Listers, I went down to Home Depot and bought two small brass ball valves, made mounting brackets, a tie between the control levers and an actuator rod, all for about $35. Photos available for those interested.
Jay in Dallas
PostPosted: Thu Feb 22, 2007 11:26 am    Post subject: Parking Brake Reply with quote
List,
Here is my version of a homemade parking brake. Two ball valves from Home Depot, four Adel clamps and some 1/8" aluminum. I bolted the 1/8" bars together because I was afraid that A5 rivets weren't long enough.
With the levers down, the valves are open. Levers up they are closed and pressure is trapped in the lines from the valves to the brake calipers.
I used a bar for a control rod because I couldn't figure out how to make a cable work with the large arc of the levers.
Jay in Dallas
 Filesize:  16.83 KB
 Viewed:  317 Time(s)
 Filesize:  15.34 KB
 Viewed:  323 Time(s)
 Filesize:  27.17 KB
 Viewed:  339 Time(s)
 Filesize:  27.19 KB
 Viewed:  315 Time(s)
eddies
PostPosted: Thu Feb 22, 2007 12:10 pm    Post subject: Re: Parking brake Reply with quote
Hi Jay,
I love the parking brake idea, but I have to ask where did you re-locate your gascolator and fuel pump to
Eddie
PostPosted: Thu Feb 22, 2007 1:36 pm    Post subject: Parking brake Reply with quote
Also see here for another low-cost solution:
www.matronics.com/photoshare/pitcher035(at)adelphia.net.05.07.2006/
-- Craig
dbortol
PostPosted: Thu Feb 22, 2007 2:41 pm    Post subject: Parking brake Reply with quote
Does anyone know how much pressure is in the braking system during a
hard brake application? I'd hate to find out at a critical moment that
the parking brake valve can't handle it.
Dino
Jay in Dallas
