ZAC Pneumatic Riveter - Questions
davevanlanen(at)sbcglobal
PostPosted: Thu Feb 02, 2006 6:53 pm    Post subject: ZAC Pneumatic Riveter - Questions Reply with quote
I purchased the ZAC pneumatic riveter with my kit, and I am setting it up
for use. It did not come with much for instructions, so I have these
questions:
1. The instructions suggest that I not install a hose coupler on the
riveter itself (i.e. into the regulator supplied with the riveter), due to
adding bulk, putting an unnecessary strain on the inlet threads, etc.
Instead, they suggest using a leader (whip) hose. Is this necessary? I
thought the riveter we used at the workshop had a coupling directly on the
riveter regulator.
2. Next to the air inlet, it says "Oil" with an arrow pointing to the
inlet. No other instructions. What type of oil do I use? How much? How
frequently?
3. If I use a leader hose, can I oil the tool through the end of the
hose? If not, I'd have to take the hose off each time. If I oil through
the hose end, will it even get to the tool, or will it be absorbed into the
hose?
4. The instructions say I need a compressor with at least 1 HP and 12
gallon capacity. I have a 4 HP compressor with an 11 gallon capacity,
developing 7.6 CFI at 40 PSI and 5.1 CFI at 90 PSI. Is this big enough?
Dave Van Lanen
Madison, WI
601XL
dplozay(at)cox.net
PostPosted: Thu Feb 02, 2006 8:14 pm    Post subject: ZAC Pneumatic Riveter - Questions Reply with quote
Dave,
I also have the pneumatic riveter from Zenith. Here's my experience with the
questions you asked:
1. I installed a swivel-coupler on the end of my air hose and a
corresponding (male) coupler on the riveter. That way I can benefit from the
swivel with whatever I have attached to the air line (drill, die grinder,
etc).
2. I use an in-line oiler set to about 2 drops per minute (when air is
flowing). The oiler adds oil to the air that goes to the tool (riveter).
Otherwise one or two drops of oil per session would suffice. Buy air-tool
oil, many brand names exist; available in the air-tool aisle at Home Depot,
etc.
3. If you don't want to use an in-line oiler, definitely use the swivel
coupler (with quick connect fitting). That way disconnecting the air line to
oil is easy and fast.
4. Your compressor will work fine for riveting. I set mine at 46 PSI.
You'll definitely need a bigger compressor if you want to run an air drill
or grinder.
Also, my riveter had a disconcerting tendency for strong kick-back for the
first 200 rivets or so (even after installing the pressure regulator on the
riveter).
I hope this helps,
David Plozay
CH701
n7cr(at)bellsouth.net
Dave VanLanen said the following on 2/2/2006 8:48 PM:
questions:
riveter regulator.
Hose coupler works for me. For the amount of actual time spent with the riveter
I don't think having one on is a problem.
frequently?
My tech advisor says to use "3 in 1" oil. Couldn't find it at the local Home
Despot, but they had a 4 oz container of "Pneumatic tool oil" for a couple of
bucks that works fine. Just squirt a couple of drops in the air inlet when
you're done for the day and squeeze the trigger a couple of times to get the oil
in there. You'll know when you use too much when it sprays oil into the mandrel
reservoir cup.
hose?
Just don't oil the hose you'll be using with your paint spray gun! Wink
Yup. Turn your regulator down to where it reads around 40 psi when you pull the
trigger on the riveter. More than that will make the tool bounce around too
much and anything less than 40 (with the small adjustment regulator valve at the
tool) will often not completely pull the rivet.
Rory
CH-701 empennage finishing tonight
Lacombe, LA
PAULROD36(at)msn.com
PostPosted: Thu Feb 02, 2006 10:16 pm    Post subject: ZAC Pneumatic Riveter - Questions Reply with quote
Dave, just my opinion, but: a: connect it however you want. It's a heavy, tough tool and will work just fine no matter what the plumbing. b: Shoot some WD-40 into the hose, or gun. It'll run through the system in about two trigger squeezes. c: Try pulling some A-5 rivets. If it works, it works. d: Use it to hold down your plans on windy days, and go to Harbor Freight for one of their $35 specials. It's lighter, better balanced, and more comfortable to the hand. Just my opinion.
Paul Rodriguez
601XL/Corvair
Attaching the tailfeathers
DO NOT ARCHIVE
