hurstkr(at)redzone.com.au Guest
Posted: Mon Feb 19, 2007 3:02 am Post subject: Tail Wheel Question |
Gentlemen,
I have a classic and when I originally made the rudder, it was as per the original design. On the release of the tail wheel mod, I purchased it and fitted the actuator plate in the bottom of the rudder. After this, I then became aware of Graham Singleton's rudder mod which I then decided to adopt. (see why it is taking me so long to build !!!) I then had to revert to the original drive system for the rudder so I used a piece of foam which I then re glassed to build back up that part of the rudder previously removed for the fitting of the actuator plate.
Problem is that I am not sure if I have left enough clearance between the bottom of the rudder and the tail wheel spring rod. IOW, I don't know how much the tail wheel spring rod will flex.
Would someone be so kind as to provide me with the measurement from the bottom of their rudder to the tail wheel spring rod at its closest point please. ie, the minimum clearance between the two.
TIA.
Kingsley in Oz.
