Trailering
helicop
PostPosted: Wed Feb 14, 2007 7:01 pm    Post subject: Trailering Reply with quote
I know this has been somewhat discussed before, and from what I have read, I still have questions. Does anyone have any experience trailering their Kitfox for longer distances especially on interstates, and frequently. In the next year or so, I am going to be traveling alot, and I want to take the Kitfox that I buy along with me. I have seen several of the open modified boat trailers that have been in use, but I am going to be hauling longer than just to the airport and home. I have thought that I really want an enclosed trailer to better protect the airplane, especially from vandalism, and the elements. I am planning on buying a Series 5, and I understand that it is a very tight fit in a 8ft 6in wide trailer, along with the heigth. I would really appreciate it if any of you with the vast wealth of knowledge that I have seen, can give me some input.
Thank you and remember to pull back to make the people look smaller, and push forward to make them look bigger.
Gary
Helicop
View user's profile Send private message Yahoo Messenger
Guy Buchanan
PostPosted: Wed Feb 14, 2007 8:23 pm    Post subject: Trailering Reply with quote
I have a IV I store in a toy box. It's the widest one I could find
here in SoCal it my K-IV fits with 1/4" to spare each side. (The
wings are the pacing item.)
We get this question a lot. I'm going to try to put together a Wiki
on Kitfox trailering.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
rkstevens(at)verizon.net
PostPosted: Thu Feb 15, 2007 6:23 am    Post subject: Trailering Reply with quote
Gary,
I have a custom made Kitfox trailer that I'm planning on selling. (I have a hangar now!) The trailer was custom made for a Kitfox IV and has trailered a Kitfox across country (Interstates, etc.). The trailer comes complete with electric brakes and a built-in gas tank with hose (for fueling the Fox). The trailer is Very Heavy Duty. You could carry cars with this thing. Evidently, the guy that originally made it owned one of those equipment rental companies - you know, the companies that rent Bobcat tractors and such. He built it so you could carry anything. Much stronger than a boat trailer. However, it's an open trailer. It's a good one, but an open design.
If you want to talk about it, send me an email & I'll forward my contact info to you.
Ron
Kitfox 6, Christen Eagle II
Date: 2007/02/14 Wed PM 09:01:49 CST
Subject: Trailering
Gary
Helicop
http://forums.matronics.com/viewtopic.php?p=95160#95160
Float Flyr
PostPosted: Thu Feb 15, 2007 7:26 am    Post subject: Trailering Reply with quote
I would think the narrowest trailer possible would be best. Allow a couple
of inches on each side for padding at the wing level. Make sure the plane
is well tied down inside the trailer. A small electric ATV winch mounted in
the front of the trailer will make loading a lot easier and provide a tie
down for the tail wheel. Try to arrange it so the main gear is just aft of
the wheels for balance and tongue weight. Make sure you always have one
blade of your three blade prop, if installed, is pointing down for loading.
A "Y" shaped towbar that attaches to the main gear may help unloading.
There are some custom made trailers for snowmobiles that will carry as many
as six machines and have a boat point front to them that could be perfect
for the long haul with a Kitfox.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
kirkhull(at)kc.rr.com
PostPosted: Fri Feb 16, 2007 6:41 am    Post subject: Trailering Reply with quote
Attached is a pic( I think I got the size down) of my classic 4 on its
trailer. It is not fully enclosed but it has a full bottom to protect it
from road hazards. It seems to work well. As for vandals, everybody stops
to look as yet nobody has touched it. The trailer is a heavally modified
pop up camper. If you would like more pics or info I would be happy to send
them to you off line.
 Filesize:  70.39 KB
 Viewed:  432 Time(s)
Tom Jones
PostPosted: Fri Feb 16, 2007 7:52 am    Post subject: Re: Trailering Reply with quote
Kirk,
Nice looking trailer. Looks like it is easy to load and unload. I am in the process of modifying my trailer now and want to shorten the tongue. What is the distance from the tail wheel to the trailer hitch when the wings are folded?
Tom Jones
PostPosted: Fri Feb 16, 2007 11:05 am    Post subject: Trailering Reply with quote
I don't remember but I will check the next time im out to the airport. The
weatherman says 45 deg on Sunday so I will try to fly then.
rexinator(at)gmail.com
PostPosted: Fri Feb 16, 2007 5:00 pm    Post subject: Trailering Reply with quote
Maybe I'm guilty of stating the obvious, but I haven't noticed yet this
time around that anyone mentioned the risk of G loads from the
suspension on a heavy duty trailer. A lightly loaded heavy duty
suspension will give a rough ride for your airplane. A trailer that is
truly custom designed to carry a relatively light weight but large bulky
load such as our Kitfoxes should have the axle suspension rated for the
weight of the load plus some small percent, say 10%. You should factor
in other things you may regularly carry with the aircraft. Fuel tanks
plus fuel and tools for instance. I would think of trailering like
flying at gross weight into potentially very rough weather.
I have an open car carrier rated to 6,000 lbs, but I am careful to
travel over smooth roads and go very slow where there are rough
surfaces. I also reduced air pressure in the trailer and gear tires. My
ratcheting cargo straps were many with just a little slack to allow the
gear to absorb shock loads as well.
Since you should want an enclosed trailer you will also want to secure
the airplane so that it can not jostle around inside and bang against
the enclosure. Thus a properly rated suspension is more essential for
the long trips. I think I read somewhere that a pothole can easily
transmit over 12 G's through your suspension which of course WILL cause
damage if it gets to the airframe. I would imagine an adjustable air
suspension would work best. Tandem axles on a trailer gives a much
smoother ride. The point is to consider the suspension when deciding on
a trailer.
Rex
Colorado
dafox(at)ckt.net
PostPosted: Sun Feb 18, 2007 8:08 pm    Post subject: Trailering Reply with quote
Rexinator,
I'm glad you replied. I was strongly inclined to do so. some time
ago on the foxlist, can't remember who it was, but someone moved and
hauled his Kitfox in a uhall truck to there new home. when they arrived
he opened the truck, and his kitfox was the same as demolished.
Before loading the kitfox, he swung the wings back, fasten them to
the stand-offs rolled it up in the truck and away he went. All that bouncing
for a long hall, and all that leverage on the wings took it toll, along with
other over torqued stress on the rest of the airplane. A boat trailer
would have been the safest.
i moved my Kitfox from the lake of the ozarks at Osage beach, Mo.
to pleasanto, Ks, 150 mile away. I hauled my fusealage on a Bob cat
trailer mounted on blocks of styrofoam, and had my wings laying on
ropes streched tight just below the ceiling of a uhall truck. When I arrived,
everything was OK.
Becareful when tranporting your airplane, you can do more damage
than you realize.
David , Kitfox IV 1200 , Rotax, 912 UL
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Friday, February 16, 2007 7:00 PM
Subject: Re: Kitfox-List: Trailering
--> Kitfox-List message posted by: Rexinator <rexinator(at)gmail.com (rexinator(at)gmail.com)>
a ========================http://www.matron=======================
bsp; available via href="http://forums.matronics.com">http://forums.matronics.com
_-===================================
kitfox69(at)earthlink.net
PostPosted: Mon Feb 19, 2007 6:04 am    Post subject: Trailering Reply with quote
One of the most important things to do when trailering your KitFox is to take the weight off the tailwheel. I don't know if this has been suggested recently, but the bouncing of the trailer places many more "G's" on the fusalage than a hard landing.
I built my own trailer and installed two steel straps back where the tubes go thru to either side. I made them long enough to take the strain off the tailwheel and run a long 1/4inch bolt thru with a wingnut to secure it. It is simple and does the job well.
If anyone is interested, I'll provide some pictures. I can also provide photos of the trailer with some details should anyone care to build their own. It is open, but capable of trailering my plane, a MOD IV 1200, on wheels, skis, and floats.
Regards, Floyd
Tom Jones
PostPosted: Mon Feb 19, 2007 7:41 am    Post subject: Re: Trailering Reply with quote
Floyd, I would like to see the pictures of your trailer. I am pondering how to build the tail support now so that would be of special interest to me.
thanks, Tom Jones
do not archive.
PostPosted: Mon Feb 19, 2007 1:13 pm    Post subject: Trailering Reply with quote
I set up the tail support to be a stand for the tail to sit in. this way
the tail spring helps cushion out some of the bumps.
kmamjones(at)comcast.net
PostPosted: Tue Feb 20, 2007 9:02 am    Post subject: Trailering Reply with quote
Floyd, I am also interested in seeing those pictures. Looks like you have several interested parties.
Ken Jones
