JRatcli256(at)aol.com Guest
Posted: Tue Feb 13, 2007 7:36 pm Post subject: Gas Tank Study |
Hi Gang,
I'm looking into increased fuel supply for my Mark 3x. I think size, shape, location and angle would have a large effect on the lowest usable fuel level. also soughing of fuel fore & aft and various angles of bank would seriously effect stability and again - useable fuel levels. Distance from the rotation point having the most effect.
Have a program that will allow me to draw various shape/size tanks and rotate it around an axis. Could rotate it around the center of the tank, but don't think this would be correct. Need to determine the longitudinal and vertical axis an aircraft rotates around, especially the Mark 3x in coordinated flight.
I can move the axis wherever I want in the program.
Think it would be at some point along the cord-line of the wing - centerline of the airframe, possibly at the balance point.
Know there must be an engineer or someone out there that can guide me.
Any takers? John H. you must have taken this into consideration when planning your larger tank.
Thanks -- John Ratcliffe
Richard Pike
Posted: Tue Feb 13, 2007 8:19 pm Post subject: Gas Tank Study |
There are all kinds of theories, but in the real world, John has a very workable solution that has served him well.
Mine is quite different, it is mostly in the gap seal area between the wings, but it serves me well. And since I can't weld aluminum, it was suitable for my skill level. As far as distance from the rotation point, stability - I don't know about that, but at the last Kolb Homecoming before he left us, Norm flew my MKIII and said it flew delightfully, more like a Firefly than a MKIII. I value that very highly, so I guess having the gas tank up high doesn't hurt.
Here's how it works -
http://www.bcchapel.org/pages/0003/pg1.htm
Have modified the upper part of the tank since I made that page, to see how it looks now, go here -
http://www.bcchapel.org/pages/0003/pg2.htm
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Tue Feb 13, 2007 8:38 pm Post subject: Gas Tank Study |
John R:
Designing a fuel tank for the mkIII is pretty easy. Get some good
card board or chart board. Construct the tank out of the card board
to fit the space it is going into.
Cross baffle the inside.
Design the bottom of the tank to have a lowest point that every drop
of fuel will drain out when the airplane is in straight and level
flight attitude.
Built ours out of .050" 5052 aluminum sheet. Pop riveted together,
then welded it. Sloshed four times with Randolph fuel tank slosh and
seal for auto fuel and avgas.
Any questions?
_________________ John Hauck
Titus, Alabama |
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Wed Feb 14, 2007 5:00 am Post subject: Re: Gas Tank Study |
Just some pitures from my recent efforts. It is basically the Brothers Hauck design. A little thicker (.063"). Originally calculated 20.5 gallon capacity. Ended up 21.5 gallons when I did the flow test and level gauge markings check.
Still haven't flight tested it yet!
51.83 KB |
328 Time(s) |
113.65 KB |
319 Time(s) |
1.52 MB |
329 Time(s) |
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Wed Feb 14, 2007 6:05 am Post subject: Gas Tank Study |
John,
NICE!
How many Workhrs do you have in fabrication?
Mike in MO
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
jim
Posted: Wed Feb 14, 2007 8:40 am Post subject: Gas Tank Study |
Are you going for a Kolb record of non-stop coast to coast?
Wow, that's a lot of fuel!
Thanks too much,
John Bickham
Mark III-C
"Using my Repairman Certificate"
_________________ Jim
N. Idaho |
Posted: Wed Feb 14, 2007 9:01 am Post subject: Gas Tank Study |
jim dunn
Hi Jim:
20.5 gals is a lot of fuel when compared with 5 or 10 gal fuel
systems. My tank is 25.0 gal.
Wish we could fly coast to coast non-stop on that amount of fuel, but
that is not the case, not at 4 or 5 gph and about 24 hours flight time
from California to my strip in Alabama.
Fuel is safety, primarily. Fuel is convenience. When we run low on
fuel, other problems will usually rear their heads, i.e., wind,
weather, darkness, unavailability of fuel at the next intended stop,
and on and on, until Murphy runs out of ideas.
With a lot of fuel on board I have the luxury of looking at my GPS,
ETE (estimated time enroute), looking over at the fuel sight gauge,
and making an instant decision on weather I have fuel to make it with
an adequate reserve, or I need to find some place to land a little
nearer. Slowing down to conserve fuel to make it to the next
available fuel is a "last" option for me. Many other factors are
involved in flying cross country. A lot of places I fly I have to
have a lot of fuel in order to make it to the next because there is no
place to land for fuel in between.
I never did understand the FAA's intention when writing a 5 gal limit
into Part 103. To me, more fuel is safety.
Titus, Alabama |
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Wed Feb 14, 2007 10:15 am Post subject: Re: Gas Tank Study |
Here are some pictures of my gas tank mock up and fabrication. the shape allows it to be installed with just one cage tube cut out. The sloped sides allow for room to install the fuel pump, gascolator, hot box and battery. It's about 19 1/2 gallons. I added an extra fitting on top so I could pump fuel into it from an aux. tank in the passenger seat if ever required. I had to fabricate and weld in a mounting platform for it to sit on.
Rex Rodebush
66 KB |
324 Time(s) |
72.96 KB |
333 Time(s) |
60.59 KB |
322 Time(s) |
Posted: Wed Feb 14, 2007 6:06 pm Post subject: Gas Tank Study |
Rex:
My fuel tank is very much the same shape as yours. We designed mine
to fit in the upper rear half of the fuselage in order to open up the
bottom rear for a cargo compartment. Looks like you could do the same
thing and not kill available cargo space.
With 25.0 gal I never consider using the left seat for an aux tank.
That is my flight desk.
A couple things I could never get over to the Kolb folks is a nice
generous cargo compartment and a big fuel tank. Maybe if we keep
reminding them that these are quite necessary items for those of us
that like cross country flying, we can get them working on a couple
upgrades.
Glad to see folks upgrading fuel capacity during the building phase of
their projects, and not after they are complete. Most folks finish
the airplane, fly it a few hours, and immediately want more fuel.
Titus, Alabama |
Rex Rodebush
Posted: Thu Feb 15, 2007 8:30 am Post subject: Re: Gas Tank Study |
Hi John,
I thought about mounting the tank as you did but was concerned about aft C.G. (I know this has been talked about before and your tank has not been a problem for you!). Anyway, while the area under the tank will have the battery, hot box, fuel pump, gascolator and ELT; I will make a storage area behind the tank, accessable from the outside, for lighter stuff. ie, sleeping bag, tent, etc.
Rex
John Bickham
Posted: Thu Feb 15, 2007 8:35 am Post subject: Re: Gas Tank Study |
| Quote: | Are you going for a Kolb record of non-stop coast to coast?
Wow, that's a lot of fuel! |
Jim and all,
The fuel tank, equipment, and setup should be setup for the type of flying you intend to do. I learned this the hard way on the way to MV 2004. Bad experience. Combination of pilot error and changing weather conditions. Long story. Another thread.
Short story is got caught by mid morning ground fog that developed after one hour into first leg. It wasn't in the original weather briefing I got that morning. Learned to pay closer attention to temp/dew point spread. Made off field landing. Bent plane. Lucky to be here today. More divine intervention than luck. God intervened and got me down to 10 feet AGL. When HE gave me the plane back I dropped it in from 8 - 10 feet. The sky was blue 30- 40 minutes after my flight terminated in the hay field. John H's advice to "Don't quite flying until your finished crashing" really applied that day.
I really enjoy long XC's with other Kolb drivers. Plan one day to land in each of the lower 48 states within a calendar year. I will also add that the minimum fuel requirement of 30 minute reserve for day VFR is not enough for the slower speed of our little planes. There are some legs out west that won't get you there in no wind conditions with the standard 10 gallon tanks. I had 14 gallon tanks at the time. The fuel capacity gives you options that you need due to changing weather/wind and just in case you are not in case you are not making the best decsions that day.
With the help and advice of John H, Jim H, John W, Paul Petty, and a few others, I am just about finished with the repairs and modifications of my plane. It will be a better and more capable plane for the type of flying I want to do.
Hope to be flying in a few weeks if work shedule allows.
Be safer than me. One day I could give a safety talk on how the "chain of small decisions and circumstances" can lead you to an incident or accident if you don't realize. It is hard to accept that you screwed up.
John Bickham
Mark III-C w/ 912UL
Posted: Thu Feb 15, 2007 9:14 am Post subject: Gas Tank Study |
| John Bickham
John B:
Murphy is a tough character to deal with. If you play with him, he
usually wins.
This is not hearsay. He has had a vendeta for me as long as I have
been flying.
DO NOT ARCHIVE
Titus, Alabama |
Posted: Thu Feb 15, 2007 9:16 am Post subject: Gas Tank Study |
tank has not been a problem for you!). |
| Rex
Rex:
Neither has the 11.6 lb Maule Tundra Pneumatic Tailwheel and 125+ lbs
of gear under the 150 lbs of fuel.
Your system will work fine, but will be limited on amount of gear you
will be able to carry.
Titus, Alabama |
John Bickham
Posted: Thu Feb 15, 2007 9:52 am Post subject: Re: Gas Tank Study |
| Quote: | Rex Rodebush Posted: Thu Feb 15, 2007 10:30 am Post subject: Re: Gas Tank Study
Hi John,
I too was concerned with aft CG. I'm not an engineer, but here was my feeble attempt to distribute the load of the tank more forward. I added a small brace that connected to the tubing that supported the original tank.
Just another way of doing it. I think is will help some. Either way, it stiffens everything up.
42.49 KB |
305 Time(s) |
John Bickham
Mark III-C w/ 912UL
pj.ladd(at)btinternet.com Guest
Posted: Thu Feb 15, 2007 9:54 am Post subject: Gas Tank Study |
It is hard to accept that you screwed up.>>
Hi John,
I think that would be appreciated on the list. That `small bad decisions`
scenario is rather more likely to apply to our sort of flying than an
accident resulting from a single disastrous occurence.
Cheers
Pat
jim
Posted: Thu Feb 15, 2007 10:11 am Post subject: Gas Tank Study |
I think we could all give that talk. Glad to have you with us.
| Quote: | Be safer than me. One day I could give a safety talk on how the "chain of
N. Idaho |
Paul Petty
Posted: Thu Feb 15, 2007 12:09 pm Post subject: Re: Gas Tank Study |
Rex,
Did you add some fuselage to the rear of your airplane? If so why? Looks good!
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
Rex Rodebush
Posted: Thu Feb 15, 2007 1:46 pm Post subject: Re: Gas Tank Study |
Rex,
Did you add some fuselage to the rear of your airplane? If so why? Looks good........
Paul,
No, the cage is as received from Kolb. It was one of the first X-tra cages. I think the present ones are a little different in the back.
Rex
Posted: Thu Feb 15, 2007 2:04 pm Post subject: Gas Tank Study |
Rex, John B, Gang:
Does my heart good to see you guys getting ready to do a little cross
country in your Kolbs. To me, that is what it is all about. Nothing
more exciting than loading up the airplane, and heading out to new
places, a long ways off, to meet new people and enjoy the way those
folks live. By golly, it'll get your heart racing and have you
sitting on the edge of your seat.
Have made plans to move my mkIII home to do the updates next week.
Tired of sitting on the ground looking up. There is no where down
here I can get that "good old feeling" that I get when I break ground
and my Kolb is taking me flying.
DO NOT ARCHIVE
Titus, Alabama |
by0ung(at)brigham.net Guest
Posted: Fri Feb 16, 2007 10:48 am Post subject: Gas Tank Study |
I don't know if it would help or not.... when I ordered the 16 gal alum
fuel tank from the old kolb company,, it came fitted right behind the seat.
In doing W&B on the fuel tank I found it to be almost centered on the rear
cg. When flying solo in the mkIII C I fly near the rear cg. So from full
to empty on the fuel level does not change the cg enough to matter ( going
from memory less than 1 / 4 inch. When I have two on board the cg of the
plane is further forward, causing a fuel burn to move the cg more to the
front as the fuel burns off.
If anyone is interested let me know.
Boyd Young
MkIII C
