Introduction To List
james.s.clark(at)comcast.
PostPosted: Thu Feb 08, 2007 5:59 pm    Post subject: Introduction To List Reply with quote
Hello all,
My name is Jim Clark and I would like to introduce myself to your
wonderful online community. I have been lurking for ~10 weeks now and
am finally brave enough to say hello. I'm addicted.
I, in partnership with a close colleague at work, have decided to
undertake this monumental project. I have been planning and budgeting
for several months and am still waffling on what may seem to you guys
as a very important fundamental decision: which kit RV-7 or RV-10.
First a brief background on my goals/budget for this project. Knowing
this info may elicit some targeted advice from you folks:
First: although I haven't finalized an airframe decision, the
following is pretty firmed up:
3 screen GRT EFIS / EM / MFD with internal WAAS & 5 Hz & probably
dual AHRS. (Want the chelton 2/3 screen but can't afford it).
Garmin GTX330 with TIS
Garmin SL30 Nav/Com
8000 audio panel
Panel mount GPS & other comm undecided.
New engine, & redundancy in most areas.
Cross country from east coast to midwest and occasional CA trips.
I am finishing up my IFR rating and absolutely cannot spend more than
150k over the next 2 years. With a strong desire for moderate IFR
capability and redundancy and nice avionics, I am finding myself
having to cut costs somewhere. My question is this: Is it crazy to
save 25k by choosing the RV-7 over the RV-10? I know it seems strange
to pick everything but the airframe first, but those are my
priorities (IFR & avionics first).
I want quickbuild and with ~32k worth of avionics, the RV-10 is
pushing 140k with a new 260 HP. I'd like to hear your thoughts,
should I get the RV-10 and initially save costs in the avionics area
by leaving blank panel area on the right side? I am single, but have
a strong desire to take more than 1 friend along on camping / biking
trips. My partner in this project is a coworker and luckily also a
neighbor. He has a family of 4.
I understand to both get Repairman certs we will need to purchase as
an LLC/corp is this right?
How much more gas / hr do you think the RV-10 is vs the RV-7. Are
there any other extra OPERATING expenses for the RV-10 over the RV-7
that I am misssing.
Thanks in advance for any responses. I apologize for the longwinded
introduction. I can hardly contain my excitement, but I am cautiously
approaching this project.
Cheers,
-Jim Clark
RV-Story DVD in hand and...
On the fence...
rv10builder(at)verizon.ne
PostPosted: Thu Feb 08, 2007 6:55 pm    Post subject: Introduction To List Reply with quote
It's a matter of a 2 seater or 4 seater. Have a family of 4? want to fly 2
of them at once than the 7 won't work, want more camping space; the RV-10
back seat folds down. Going to fly solo everywhere the 7 is more than
enough, etc.
I would ask yourself what your mission is first than determine the avionics.
There is a whole lot of resources on all of this in the EAA Homebuilders
link.( http://www.eaa.org/education/homebuilt_aircraft.html ) If your a
current EAA member- check out all the stages covered and the FAQ under each.
You're going to burn more fuel in the RV-10 simply because it's a slightly
larger plane that uses a larger engine, but again..mission. Makes no
difference if the RV-7 has better MPG and everything else if you want to
carry more than 1 passenger.
As far as the repairman's cert- 1 per person per plane:
from the EAA site: When a Chapter (or school, club, or partnership) builds
an aircraft, only one individual will be considered for a Repairman
Certificate for each aircraft built. Typically, the designated project
leader will be the one who applies for the Repairman Certificate. The
project leader should also be the on who signs for the airworthiness of the
aircraft on FAA Form 8130-6 block III.
Best of success with this decision.
Pascal
AV8ORJWC
PostPosted: Thu Feb 08, 2007 6:58 pm    Post subject: Introduction To List Reply with quote
Jim, add the RV-9 to your evaluation. The wing and tail give similar
flight performance as the RV-10 to a cruiser/IFR platform. If you
wanted a nimble hot-rod then the RV-7A or RV-7 would be better "Mission
Suitable". Read the archives on how the path to having EFIS and
multi-screen EFIS was made more difficult by the placement of support
ribs, in their design.
A little research is going to help you a lot in your decision. The
first step is selecting the journey. You are now well on your way. You
will find a lot of support in anything you chose. JMHO.
Your absolute needs to be balanced with the reality of builders that are
now flying the RV-10 which meets your mission. Both the kit and the
engine continue to reflect the Time Value of Money. A quick build well
help you reach your absolute much sooner. Out of Money. Only one of
you will get a Repairman Certificate. Figure that out early. If your
partner must have 4 POB then you better do a lean budget and get a firm
grip. Fuel burn at 12.5gph at 65% is a good benchmark for fuel
consumption. An IO-360 or 400 is not going to push an RV-10. Come on
over the grass is always Green and in need of cutting.
Help make us 1,000 kits strong.
John Cox
#40600
jhasbrouck(at)woh.rr.com
PostPosted: Thu Feb 08, 2007 7:15 pm    Post subject: Introduction To List Reply with quote
Jim,
I've always been a fan of Van's aircraft but, at 6' 3", I found the two
place RV's tight in the headroom department. The -10 was a better "fit" for
me. It impresses me as a great, comfortable cross country plane with room to
stretch. I also want to take friends along on occasion and the -10 is
obviously better for that mission than the -7. I'm instrument rated but
will probably equip my plane simply at first with the option to upgrade.
I'm designing the panel with that in mind.
A Lycoming IO-360 will burn 10 GPH in cruise. That's what you'd
probably use in the -7. The IO-540 in the -10 will burn 12 to 15 GPH in
cruise ( check Tim's site for better numbers) multiply the difference by
$4.50/gal avgas to get a rough idea if increased fuel costs. Speeds are
close enough for either so no advantage one way or the other. When I owned
factory built planes I'd figure the total hourly operating cost to be 3X the
hourly fuel cost and it seemed to work well for 100 hours/year minimum.
Nowadays 4X the hourly fuel cost may be more appropriate. In reality I
think you'll fly the -10 for more than the -7 but the mission capablities
are greater with the -10. I think the additional cost are worth the greater
flexability.
Don't jump too quickly (pardon the pun) into the quickbuild options.
I'm going standard kits all the way and have progressed very quickly using
only the spare time I have after work and weekends. Most of that working on
my own. I decided to save the bucks I'd have spent on the quickbuild and
put it into other areas of the plane.
I'm sure you'll get a lot of advice from the group, just my $.02 worth.
John Hasbrouck
#40264
jesse(at)saintaviation.co
PostPosted: Thu Feb 08, 2007 8:10 pm    Post subject: Introduction To List Reply with quote
I will answer below a little.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
armywrights(at)adelphia.n
PostPosted: Thu Feb 08, 2007 8:16 pm    Post subject: Introduction To List Reply with quote
Family of 4 is your neighbor? Either commit now to $150K split 2 ways or
find another partner who wants an RV-7. If you go with the -7 I have a
feeling the neighbor will want the -10 halfway through the project and leave
you holding the 100% bag.
Even taking 1 friend on your stated trips, the -10 will be a nice addition
for the large-sized gear you'll have to take, but that's a $30k question
you'll have to answer. How much camping/biking gear can you rent locally for
$30k over the next 10 years, but that you're not familiar with and changes
each time you go?
Save money and go with the -10: Use a 2 screen GRT setup with a DA-10 Dynon
backup for unrelated redundancy, or at least go with an overhauled motor.
You'll save at least $10-20K right there on the motor.
Rob Wright
-10 QB #392
Trying to stay under $150K with G-900X in the plans (overhauled motor with
new cyl's, Hartzell Prop, no other major mods)....
apilot2(at)gmail.com
PostPosted: Thu Feb 08, 2007 8:58 pm    Post subject: Introduction To List Reply with quote
I'm with others on cut back on your avionics. I don't believe you
mentioned an autopilot. Absolutely get at least a wing leveler or
better. Dump the 330 transponder. TIS will slowly go away and there
are better, cheaper ways to get traffic. That alone will get you
started on an autopilot. Look to other sources than Van's for a custom
built engine for less money.
Your missions really speak 4 place. You aren't carrying enough baggage
to go coast to coast with a pax in a two place with much comfort.
Especially not with any form of paper charts. Consider 2 screen rather
than three, and some 2 1/4 backup steam gauges..you will lose
electrics some time. Consider 496 in a panel mount for nav backup.
each time you go?
Garmin SL30 Nav/Com
8000 audio panel
Deems Davis
PostPosted: Thu Feb 08, 2007 9:15 pm    Post subject: Introduction To List Reply with quote
Jim. congratulations on having made the decision to build your own
airplane. Sticking with the RV series of planes will provide you a
support system and the benefits of engineering derived from a fleet of
flying planes that totals nearly 5000 !. (That's more than either
Columbia or Cirus) Doing so you will join a group of
motivated,opinionated, and enthusiastic people that do something that
others think impossible.
Now at the risk of p*****g you off. I think you're going about the
decision from the wrong end. It's easy to get enamored with the 'electro
whizzies/ (Believe me I know I've got a panel full of them!!!!).
BUT----- unless you're going to quit work and build 10 hours a day every
day, this project is going to take you at least a couple of years. (I've
quit work, work 4-6 hours on the plane every day and ITS STILL going to
take me over 2 years to finish!!!!) In that time frame the list of
viable/and affordable electro wizzies will very likely change. The neat
thing about building these planes is that one of the easiest things to
change after you've built the plane is the panel itself. WITHOUT A DOUBT
the MOST DIFFICULT thing to change would be to add 2 more seats to a 2
seat airplane!!!!!.
So.... Think seriously about whether 2 or 4 seats will suit the type of
flying you and your partner will be doing. that's the 1st step to
defining your mission. If it's 4 Stop cause you won't find a better 4
place plane than the -10. If its 2, then decide whether Acro is
important to you or not, if not look (at) a -9, if it is then decide if you
want tandem or sidebyside seating. (-7 or -Cool. then you can move on to
the engine/avionics and assorted decisions. I know this isn't the
answer you were looking for,...... but you were asking for help! And
that's the spirit that this is intended in.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
J
dav1111(at)cox.net
PostPosted: Fri Feb 09, 2007 2:53 am    Post subject: Introduction To List Reply with quote
Dear Jim:
You posted that:
Hello all,
GO WITH THE RV-10. If your partner has a family of four both of you will be a lot happier with an RV-10 vs. and RV-7 in my opinion.
Garmin SL30 Nav/Com
8000 audio panel
WITH A 3 SCREEN GRT EFIS I ASSUME YOU ARE GOING DUEL HORIZON I PLUS A GRT SPORT. INSTEAD OF BEING UNDECIDED ON THE PANEL MOUNT GPS AND OTHER COMM GO WITH A SECOND WASS GPS IN THE GRT SPORT AND GET AN SL 40 FOR THE SECOND COMM.
SAVE $20,000.00 ON YOUR PROJECT BY GOING WITH A GOOD FIRST RUN IO-540 CORE, SEND OFF THE CASE, CRANKSHAFT, AND CAMSHAFT FOR OVERHAUL AND HAVE A REPUTABLE SHOP ASSEMBLY THE ENGINE WITH NEW ECI CYLINDER ASSEMBLIES AND BEARINGS. I DID THIS AND HAVE LESS THAN $25,000.00 IN ESSENTIALLY A NEW ENGINE. BY THE WAY A PROVEN LYCOMING CRANKSHAFT THAT HAS GONE TO TBO IN THE FIRST RUN AND OVERHAULED IS A BETTER CRANKSHAFT THAN A NEW LYCOMING CRANKSHAFT.
CHECK OUT WHAT A THREE SCREEN GRT EFIS PANEL MIGHT LOOK LIKE AT:
http://www.steinair.com/panels.htm Double click Russ' RV-10 panel to see mine. My GRT Sport is in the middle.
that I am misssing.
IF YOU RUN FULL THROTTLE AT LOW ALTITUDES YOU WILL USE MORE FUEL IN THE RV-10. HOWEVER YOU CAN THROTTLE BACK THE RV-10 AND/OR FLY AT HIGH ALTITUDE AND BURN ABOUT 10 GALLONS PER HOUR.
Cheers,
-Jim Clark
GOOD LUCK ON YOUR DECISION.
RUSS DAVES
N710RV - FLYING RV-10
N65RV - RV-6A SOLD
Rhonda(at)bpaengines.com
PostPosted: Fri Feb 09, 2007 6:28 am    Post subject: Introduction To List Reply with quote
Rob wrote:
"or at least go with an overhauled motor.
You'll save at least $10-20K right there on the motor."
I think you're more likely to save around 5-7K with an engine overhauled
to Factory New Limits by a quality shop in stock configuration. I don't
see this changing in the near future because the core market is
dwindling and a clone manufacturer does not appear on the immediate
horizon.
You can get one cheaper, but we have recently seen a rash of engines on
the market that have been recently overhauled using non-serviceable
parts, chromed cylinders, etc. I.E., parts that have been rejected but
make their way to the market through less than reputable sources or say
a serviceable crank that is .010 rods and mains, which means that at the
next overhaul (or possibly a prop strike) it's almost guaranteed that
the crankshaft will need to be replaced. If that happens, plan on
$5,000 (good used crank) - $15,000 (new) tacked on to your engine repair
costs.
In fact the Feds recently prosecuted a group of people in Oklahoma City
for fraud who were selling IO-540 engines as overhauled, when they were
completely unairworthy. They got something like 25 years and the
purchasers got left with nothing. If you do go with an overhauled
engine, make sure you know exactly what you're getting and check
verifiable references.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
Tulsa, OK
jdalton77(at)comcast.net
PostPosted: Fri Feb 09, 2007 5:50 pm    Post subject: Introduction To List Reply with quote
Jim
Welcome!
I faced the same choice and went with the -10, but I guess your mission is
should be the real driver.
Don't forget, the -10 will be more $$$, but ALSO will take quite a bit more
time and effort to get in the air.
I've never heard the LLC/Corp requirement before, but I do have an S-Corp
that owns my Cherokee and my -10.
Your panel sounds fantastic. Good luck!
Where are you located by the way. I'm in Michigan.
Jeff Dalton
RV-10 Wings
tadsargent(at)bellsouth.n
PostPosted: Fri Feb 09, 2007 7:16 pm    Post subject: Introduction To List Reply with quote
Jim I have a 7A and I am building a 10. These aircraft offer vastly
different rolls. The 2 seater is for acrobatics and day/night VFR. Where
the 10 can be IFR and straight and level flown. As for the $25k difference,
well, good luck. You may get away with 60-80 on a 7 but the 10 will exeed
130k for your requirement. Also the 10 has much more fiberglass than any
other RV. How are your skills there? It can be learned but get help from
other builders, they are more than willing to if asked. This is the best
fraternity I have ever had the pleasure of being in. As far as the FAA is
concerned I believe only one person can be listed on the repairman Cert.
Good luck in either choice. They are both great machines.
Tad S.
wvu(at)ameritel.net
PostPosted: Fri Feb 09, 2007 9:15 pm    Post subject: Introduction To List Reply with quote
Uhhh... not sure that it takes considerably more time to build a -10. My
total time was 2550hrs, slow build, and I considered it to be on the high
end compared to some of the numbers that I've heard. This seems reasonably
close to the 2-seat models.
Don't forget to add unexpected/hidden costs into your estimate. Shipping
charges, epoxy, filler, primer, window/winshield glue, tank sealer,
headliner, carpet, baggage door lock, are some items off the top of my head
but it goes on and on.... mine was around $9K. I think Tim Olson's was
$11K at one point during his project.
Anh
N591VU-22hrs
