Corrosion Proofing
ptiller(at)lolacars.com
PostPosted: Wed Feb 07, 2007 12:32 pm    Post subject: Corrosion Proofing Reply with quote
Hi,
I'm starting to work through all the metal parts and am thinking about corrosion proofing. I've been advised to use Zinc Chromate on aluminium parts and Zinc Oxide on steel parts which makes sense. Hard anodising has been suggested to me and a search on this list reveals all sorts of other options. The Zinc Chromate option sounds great but I realise that I may be dead from it before I get the plane built!
So, a lot of people on this list have aircraft that have now been flying for a while. Can you tell me from experience what has worked and also what you consider to be best for the plane and indeed the person applying it!
Phil
Visit - www.EuropaOwners.org
topglock(at)cox.net
PostPosted: Wed Feb 07, 2007 2:29 pm    Post subject: Corrosion Proofing Reply with quote
Phil,
All my metal parts, at least those not treated at the factory, are
coated with zinc chromate. I've been in the air for almost two years,
with over 250 hours on the aircraft. No corrosion to report and I
survived the process in good shape...
Jeff - Baby Blue
flyingphil2 wrote:
Hi,
Phil
rparigor(at)suffolk.lib.n
PostPosted: Wed Feb 07, 2007 2:31 pm    Post subject: Corrosion Proofing Reply with quote
Hello Phil
Straight from the mfg. Zinc Chromate needs a top coat to be most
effective. I know plenty of folk use it, it is however porous. Self etch
zinc chromate uses up half of its magic to neutralize acid.
Chemicals with acid and plating work OK but a pain to do.
My favorite corrosion protect ant is PPG DPLF! It is a 2 part epoxy
primer, it does not let in moisture. If you scuff surface it sticks better
than any paint I have tried. Works on aluminium, steel and fiberglass.
Downright amazing. It does not have UV inhibitors though.
When I do Mod 72, I will paint both ID and OD with DPLF,and assemble wet.
When I made precision pins for tailplane torque tube, I used wet paint as
an assembly lube, and coated the ID of the TT as well.
Painting bare fiberglass, DPLF thin and let it full cure before applying
top coat or K-36 high build primer. Adhesion is great.
One word of advise, if you are going over self etch primer with DPLF you
need to wait till it is full dry. Whatever the mfg says, I find it takes a
lot longer. If you put DPLF over slight not dried self etch, or slight not
dried solvent, it will not allow the solvents to permiate. It will not
adhere as well as it has ability to do. If you take a razor blade or sharp
scraper and can peel off the DPLF, smell sample, if you detect solvent,
you didn't wait long enough.
I poured hot linseed oil inside aluminium and steel tubes and poured out
after coating and sealed things up.
Ron P.
grahamsingleton(at)btinte
PostPosted: Thu Feb 08, 2007 4:41 am    Post subject: Corrosion Proofing Reply with quote
Ron & all
DPLF or os ot DP40 in UK? is good stuff, however one other thing to
remember is that you must NOT sand it. It will become permeable if you
do. AS I understand it it's designed to be a very thin impermeable
membrane, so don't flat it off after it dries.
Graham
rparigor(at)suffolk.lib.ny.us wrote:
Hello Phil
Ron P.
william(at)wrmills.plus.c
PostPosted: Thu Feb 08, 2007 6:37 am    Post subject: Corrosion Proofing Reply with quote
Graham,
What is your view on the Mod 72 method of protection? The spec calls for
painting all surfaces with etch primer, allowing it to dry and then applying
the ACF 50 before assembly. If the insert is a tight fit, presumably it
will skin the etch primer back to the metal as it enters the frame tube. I
like Ron's idea of assembling the inserts with the paint on both surfaces
still wet. What is your opinion?
William
asarangan(at)YAHOO.COM
PostPosted: Thu Feb 08, 2007 7:17 am    Post subject: Corrosion Proofing Reply with quote
You can also try alodine, which is a two step chemical dip process. For
aluminum tubes it will work better than zinc chromate because it will
coat the inside surfaces too. I used alodine and then gave it a coat of
zinc chromate on top. I could not get zinc chromate from any of the
local auto paint shops or marine shops. Shipping cost is pretty
expensive if you buy from catalog stores because it is considered
hazmat. I picked up a few cans from the local Grainger outlet for
pretty cheap. It was something like $5 per can. A safer a alternative
is zinc oxide paint.
PostPosted: Thu Feb 08, 2007 11:19 am    Post subject: Corrosion Proofing Reply with quote
Ron's plan sounds good to me, I don't have much faith in etch primer
over zinc plated steel. Could be wrong though, it might bond. Will it
etch zinc?
Graham
William Mills wrote:
<william(at)wrmills.plus.com>
Graham,
for painting all surfaces with etch primer, allowing it to dry and then
applying the ACF 50 before assembly. If the insert is a tight fit,
presumably it will skin the etch primer back to the metal as it enters
the frame tube. I like Ron's idea of assembling the inserts with the
paint on both surfaces still wet. What is your opinion?
William5
