torgemor(at)online.no Guest
Posted: Sat Feb 03, 2007 4:37 pm Post subject: RPM indicators for Rotax engines. |
Hi there,
For a long time, I've been looking into this RPM problem related to our
Rotax engines.
You know, I've had it, on my "very" old (sorry lady), engine setup.
Well, this RPM indication problem is NOT related to the "simple" Rotax RPM
indicator!
Hey, this very same principle is used in the most reliable RPM setups we
know about out there!
There is only two wires going into the RPM indicator, just a signal and no
power(?).
OK., since the signal is just an alternating voltage, we simply "steal" a
little of this energy for the indicator, using a full wave (or half wave)
rectifier for power, then we measure the RPM(frequency) of this
alternating voltage, you see, -simple.
The thing is that our "well known" charging system is the problem!
Before any protest here, ( ); Try this:
Make sure that you can see the problem, yes -your RPM indicator is reading
to low (as always -and normal)! This might be confirmed with the hand
hold optical device.
Now, discharge your battery a little (well -make sure there's enough juice
for a restart of the engine), start your engine, switch on a little of the
load that you have, LDG lights etc. -if necessary.
What kind of RPM reading do you see now? Right, normal - but how can this
be?
This is something we'll discuss, but first some confirmation, from those
with the problem..
Torgeir.
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Float Flyr
Posted: Sun Feb 04, 2007 4:44 pm Post subject: RPM indicators for Rotax engines. |
Hi Torgeir:
Following the wiring diagram of my R582-UL the lighting coils are completely
separate from the ignition coils. So loading the lighting system shouldn't
and in fact, doesn't make any difference to my Kitfox tach. My analogue
reading tach is quite linear in it's error. Approximately 200RPM/1000RPM or
20% always consistent and always low.
My tiny tach is powered by a built in battery and triggered by pulses
passing through the plug wires. The pulses are no doubt digitized, de
bounced, frequency counted, divided by 2 (2 firings per revolution) and then
the end result displayed. I believe the highest resolution is 10rpm. As
with most things digital trends are quite difficult to follow ( how fast an
RPM is increasing/decreasing) and steady RPM are easy to attain.
For that reason I still have my old erroneous Kitfox analogue tach in the
dash as well as the digital tach.
BTW. My understanding of the original tach is that it also reads pulses not
signal amplitude. Apparently there was a problem with them burning out with
too much current passing through them so a nice healthy resistor was placed
in series to protect the input of the meter.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Mdkitfox(at)aol.com Guest
Posted: Sun Feb 04, 2007 9:17 pm Post subject: RPM indicators for Rotax engines. |
In a message dated 2/3/2007 7:38:33 P.M. Eastern Standard Time, torgemor(at)online.no writes:
| Quote: | There is only two wires going into the RPM indicator, just a signal and no
power(?).
I have the Rotax RPM indicator for my 912S and while the engine has only 2 wires going to the tach, the Tach has 3 terminals. They're numbered 1,2,3. Does anyone have any idea which terminals get wired to the engine and what's the extra terminal for anyway?
Rick
Series V Speedster - N39RW
Posted: Thu Feb 08, 2007 4:00 pm Post subject: RPM indicators for Rotax engines. |
Hi Noel,
Right on there, yes the newer has it's own coil (the gray wire) winded
parallel on one of the ignition coils. There's also a 1Kohm (1000 ohm)
resistor in serial with this line to prevent too high voltage entering the
RPM indicator. The early model engines had them installed inside the
flywheel house, but later one removed to outside of the engine due to
experienced failure modes. The SI 5UL90E contain information about
"disturbance of tachometer 9667 072" and this resistor. Remember, one "582
engine" rev give 6 pulses (shaped sinus).
So 6800 RPM will produce a frequency of: f=RPM*(number of poles)/60
second(one minute)=6800*6/60=680 I.E. Hz
When the engine is running at 6800RPM the frequency of pulses arriving
from the engine is 680 Hertz. Then it should be easy to check with a
"tone generator" (use less than 10 VAC) and an accurate frequency counter
your RPM indicator.
I've been thinking that this error only was limited to the old engines
without the special thacho wire (Grey), but this Service Instruction "SI
15UL94" also warn about the influence from the lightning coils even the
fact that they are separated from each other. Just thought this might be
interesting for someone out there.
On my Fox, the lightning coil is used for the RPM indicator giving two
periodes pr. rev.
Check here for all the different kind Wesberg (Westach) instruments and
their setup.
http://www.westach.com/
Here's lot's of instruments and connection setup (that's not very
readable).
And this site, some other brand of tachometer for our engines.
http://www.umainstruments.com/Tachometer.htm
Their home site, here's lot's of instruments:
Torgeir.
On Mon, 05 Feb 2007 01:44:10 +0100, Noel Loveys <noelloveys(at)yahoo.ca>
wrote:
Hi Torgeir:
completely
shouldn't
200RPM/1000RPM or
then
an
not
with
placed
Noel
15ul94.pdf |
354.03 KB |
856 Time(s) |
5ul90.pdf |
140.85 KB |
494 Time(s) |
Posted: Thu Feb 08, 2007 4:18 pm Post subject: RPM indicators for Rotax engines. |
Hi Rick,
Find the type of instrument that you have, P/N or model then find the
current setup at Wesberg site here:
I'll think that your tachometer is of the kind that need separate power
supply, or is a combined type that can use only pulse signal, or pulse
with own (steady) power.
Here's the link to Wesberg:
Good luck.
Torgeir.
On Mon, 05 Feb 2007 06:16:25 +0100, <Mdkitfox(at)aol.com> wrote:
| Quote: | In a message dated 2/3/2007 7:38:33 P.M. Eastern Standard Time,
no
power(?).
1,2,3.
what's
Rick
