Shelving required for a complete slow-build kit
Terry Phillips
PostPosted: Fri Feb 02, 2007 11:18 am    Post subject: Shelving required for a complete slow-build kit Reply with quote
I have a pretty mundane question.
I'm expecting delivery of my complete 601XL slow-build kit in a couple of
weeks. I will need to build shelving (or whatever) to hold all the parts
while I build the airframe. I would like to know how others have stored
complete kits, without completely filling up the garage.
How many shelves or bins, what size and shape? I have half of a 2-car
garage to hold the storage and my 4'x12' work bench. Pictures would be
great. Thanks for your sharing your experience.
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Just starting a 601 kit
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
Chris Lewis
PostPosted: Fri Feb 02, 2007 11:37 am    Post subject: Re: Shelving required for a complete slow-build kit Reply with quote
Terry - Check out Andre's site (courtesy of ch601.org)
http://home.tiscali.nl/a.vandenelsen/foto%20pagina%20's/begin/index.html
(Make sure to get the complete URL)
Chris in Seattle
Andre's Garage
 Filesize:  46.08 KB
 Viewed:  594 Time(s)
750/ Zen-vair Semi-Scratch Builder
N750XT (reserved)
john.marzulli(at)gmail.co
PostPosted: Fri Feb 02, 2007 11:58 am    Post subject: Shelving required for a complete slow-build kit Reply with quote
You won't need much shelving.
I built my 12x4 bench on top of a Zenith crate, and still use the crate for storage. Another Zenith crate was turned on it's side and acts as a shelf.
A peg board holds most of my tools. A small plastic tool box on wheels holds my drill and rivet gun.
I put a few smaller shelves up as well to hold a radio and a holder for screws/rivets.
http://photos1.blogger.com/blogger/2584/3102/1600/DSC00233.jpg
http://bp2.blogger.com/_mhDbWUJRTOE/RYeWYnGvw-I/AAAAAAAAAAY/-qi6re2CiW0/s1600-h/DSC01470.JPG
Good luck!
On 2/2/07, Terry Phillips <ttp44(at)rkymtn.net (ttp44(at)rkymtn.net)> wrote:[quote] --> Zenith-List message posted by: Terry Phillips <ttp44(at)rkymtn.net (ttp44(at)rkymtn.net)>
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Just starting a 601 kit http://701Builder.blogspot.com/
"Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes. [quote][b]
Jaybannist(at)cs.com
PostPosted: Fri Feb 02, 2007 12:07 pm    Post subject: Shelving required for a complete slow-build kit Reply with quote
Terry,
I have been working in the same situation as you: half of a two car garage. I retained the current shipping crate (I am building from component kits). I placed it outside the garage and covered it with a large polyvinyl sheet, taped to prevent water penetration, but still accessible to retrieve parts as needed. It worked for me.
Jay in Dallas
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
grs-pms(at)comcast.net
PostPosted: Fri Feb 02, 2007 1:32 pm    Post subject: Shelving required for a complete slow-build kit Reply with quote
barcusc(at)comcast.net
PostPosted: Fri Feb 02, 2007 4:45 pm    Post subject: Shelving required for a complete slow-build kit Reply with quote
I stored everything but sheet metal and canopy on a shelf under the work
bench and on the floor under the bench.
Clyde Barcus
xl(at)prosody.org
PostPosted: Fri Feb 02, 2007 11:34 pm    Post subject: Shelving required for a complete slow-build kit Reply with quote
Terry,
I built 633Z in a 10' x 20' tent in 7 months in 2003 from a kit.
(http://www.eaa.org/homebuilders/list/Zenith%20Zodiac%20CH%20601%20XL_Edwards.asp)
I used a 4' x 12' work table with a shelf underneath.
I put the sheet metal on the floor under the table and on the shelf.
I stored some miscellaneous parts on the shelf.
There were some 3 boxes of small parts that I left stored in the boxes.
I stowed the finished rudder, elevator and wings on the side of the tent.
When I got to the point that I could put the fuselage on the floor
I moved the work table outside.
Here's a picture of the work table:
http://www.cleanh2o.com/633z/workshop_small.jpg
and a picture of the plane on the floor:
http://www.cleanh2o.com/633z/in_tent2_small.jpg
see all thumbnails: http://www.cleanh2o.com/633z/index_thumbnail.html
Later ask about my 2 failed stock mufflers, failed nose gear bearings,
dirty carb stumble, brake line failure, failed starter, bad nose fork,
and the Zenith grin!
Hope to go flying tomorrow!
Cheers, Joe E
N633Z (at) BFI
CH601XL 424 hours
Jabiru 3300, Sensenich 64x49 wood prop
Terry Phillips
PostPosted: Sat Feb 03, 2007 9:46 am    Post subject: Shelving required for a complete slow-build kit Reply with quote
Good flying, Joe. Don't get wet.
George
