lcottrell
Posted: Sun Jan 28, 2007 11:37 am Post subject: help! |
I want to use the buttons on my grip to activate the push to talk switch. Thinking that it should be a simple act of a momentary switch I cut my factory switch wire into. Long enough to splice it back together if thing went as they normally do. Instead of two wires, I find that there are four in that little bundle. Any one know anything or at least enough to help me out here? I have searched the internet and can't find anything other than where to buy them.
Larry, Oregon
lcottrell
Posted: Sun Jan 28, 2007 11:58 am Post subject: help! |
OK, I just tested the four wires Red and Green are activated when the button is pushed. Black and white are also activated when the button is pushed. My grip button has only two contacts. Anybody have a clue as to how to wire this thing.[img]cid:003801c74316(at)usermj5tjr71vq[/img]
24.28 KB |
206 Time(s) |
planecrazzzy Guest
Posted: Sun Jan 28, 2007 12:43 pm Post subject: Re: help! |
Hi Larry,
When I was messin with my old com system...my PTT also had the 4 wires.... there were Two momentary switches...
One - normaly open
One- normaly closed
What this did was cut-off andbody in the intercom , while the pilot is using the radio...
Sounds like yours might be the same...
You could , just use the two wires and elbow the passenger...He he he
Or maybe you have something different...
I think mine was Comtronics...
Gotta Fly...
boyter(at)mcsi.net Guest
Posted: Sun Jan 28, 2007 12:55 pm Post subject: help! |
Larry
The four wires is for a double pole double throw switch?????
Wayne
24.28 KB |
204 Time(s) |
lcottrell
Posted: Sun Jan 28, 2007 1:01 pm Post subject: help! |
| Quote: | Hi Larry,
One - normaly open
One- normaly closed
using the radio...
This one is I-com. Here is a picture, perhaps that will help. If I weren't
afraid of frying the final or something else in the radio, I would just
connect the four wires together into two pairs and call it good.
Larry,Oregon
31.89 KB |
220 Time(s) |
jindoguy(at)gmail.com Guest
Posted: Sun Jan 28, 2007 1:21 pm Post subject: help! |
Larry, Check the Aeroelectric List also here on Mattronics. Some one there will know exactly what to do with your particular set up.
Rick
On 1/28/07, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote: | Quote: |
| Quote: | Hi Larry,
One - normaly open
One- normaly closed
using the radio...
Larry,Oregon
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Posted: Sun Jan 28, 2007 1:42 pm Post subject: help! |
Larry:
Don't take this for gospel, but I think the white wire is the PTT
wire. Ground it and the radio should go to xmit.
However, don't do that because I said so. Let me see if I can find my
schematic for my icom.
_________________ John Hauck
Titus, Alabama |
ceengland(at)bellsouth.ne Guest
Posted: Sun Jan 28, 2007 6:23 pm Post subject: help! |
Larry Cottrell wrote:
| Quote: | I want to use the buttons on my grip to activate the push to talk
Larry, Oregon
Does your PTT include a plug & jack for your headphone mic? If so, that
would explain the extra wires.
Do you have an ohm meter? You can use it to identify which wires are
tied together when the PTT is pushed & which wires go where at the plug
end of the wire.
If you've got an ohm meter & need some help with how to identify the
wires, let me know & I'll try to walk you through using it.
Charlie
lcottrell
Posted: Sun Jan 28, 2007 8:12 pm Post subject: help! |
a58r(at)verizon.net Guest
Posted: Sun Jan 28, 2007 8:26 pm Post subject: help! |
Larry,
Just found an old(!) msg (aug 7, 1998) I sent on FLY-
UL(at)majordomo.hughes.net with diagram for Icom A-22 external PTT ckt.
Still need that info?
regards,
Bob N. FireFly 070 Old Kolb
lcottrell
Posted: Sun Jan 28, 2007 8:32 pm Post subject: help! |
Sure, It couldn't hurt. Thanks I do appreciate it.
Larry.Oregon
APilot(at)webtv.net Guest
Posted: Mon Jan 29, 2007 4:53 am Post subject: help! |
Re: Push to tallk switch. I have never been able to get my ptt switch
to work with my JPH520 radio. Recently, I was told that my radio may
not have the circuit for a ptt switch. Guess that I should have bought
an Icom.
lcottrell
Posted: Mon Jan 29, 2007 8:29 am Post subject: help! |
Posted: Mon Jan 29, 2007 4:30 pm Post subject: help! |
Well, it certrainly isn't definitive, but it truly focuses on who caused the problem. It certainly wasn't you, Larry. Bob is right, that info should have been forthcoming from the manufacturer. If we as consumers don't push back we will always be left to our own devices to fix what the manufacturer has left undone. It's one that should be proceeded with. You paid their asking price and they have let you down. If no one holds their feet to the fire they will never improve.
Rick
On 1/29/07, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote:[quote] --> Kolb-List message posted by: "Larry Cottrell" <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)>
lcottrell
Posted: Mon Jan 29, 2007 6:32 pm Post subject: help! |
Posted: Mon Jan 29, 2007 7:03 pm Post subject: help! |
