jindoguy(at)gmail.com Guest
Posted: Sat Jan 27, 2007 8:44 am Post subject: Mk 3 steel main gear legs |
When I was in the midst of main gear straightening caused by my horrible landing technique, I thought the way out was TNK's steel gear legs. Now that I am pretty happy with my landings, I know I'm not going to install them. $350 for the pair, plus shipping.
Rick
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
boyter(at)mcsi.net Guest
Posted: Sat Jan 27, 2007 10:24 am Post subject: Mk 3 steel main gear legs |
Are the new steel gear leg from kolb still have the wrong bend at the axle? all the old ones about two years ago, camber was way off when the weight was on the wheels.
Wayne
Kolb mark 3
582 three blade wrap drive
450 hrs.
Posted: Sat Jan 27, 2007 11:31 am Post subject: Mk 3 steel main gear legs |
I bought them in April or May of 2006 so I doubt they are in that lot.
Rick
On 1/27/07, Wayne Boyter <boyter(at)mcsi.net (boyter(at)mcsi.net)> wrote:[quote] Are the new steel gear leg from kolb still have the wrong bend at the axle? all the old ones about two years ago, camber was way off when the weight was on the wheels.
Wayne
Kolb mark 3
450 hrs.
Posted: Sat Jan 27, 2007 12:40 pm Post subject: Mk 3 steel main gear legs |
| Rick
Rick:
If you keep on flying, eventually you will need them.
Old hauck's holler proverb.
hauck's holler, alabama
_________________ John Hauck
Titus, Alabama |
APilot(at)webtv.net Guest
Posted: Sat Jan 27, 2007 5:03 pm Post subject: Mk 3 steel main gear legs |
Tap Plastics sells a 1" dia "S" glass fiberglass rod that is 6 feet long
for $30. That would make two gear legs if a 3/16 thick sleeve could be
found to reduce the dia of the fuselage sleeve on a Mark III. Has
anyone tried them for a gear leg replacement? My guess is that they
might be too flexible. Vic in Sacramento
rowedenny(at)windstream.n Guest
Posted: Sat Jan 27, 2007 9:59 pm Post subject: Mk 3 steel main gear legs |
Posted: Sun Jan 28, 2007 6:49 am Post subject: Mk 3 steel main gear legs |
Interesting idea to use the S glass rod. The Varieze, LongEZ and all their progeny use S glass main and nose ear. Should anyone try this idea, be sure to wrap the leg with E glass laid up at a 45 degree bias. This keeps the S glass rod from splintering or delaminating when bent.
Rick
On 1/27/07, Denny Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:[quote] --> Kolb-List message posted by: "Denny Rowe" <rowedenny(at)windstream.net (rowedenny(at)windstream.net)>
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Tue Jan 30, 2007 7:33 am Post subject: Re: Mk 3 steel main gear legs |
I think Kolb supplied two designs for the steel legs. A very flexible version (I think Steve Green has these); and a very stiff, heat treated version which I think is now the standard. I traded my old aluminum legs to Travis & bought the new, stiff legs. I installed extensions so they go up to the top of the "V" in the cage. I had to use carbide bits to drill these. They were very tough. The deflection is minimal.
See attached pictures for the extensions and the legs.
Rex Rodebush
51.78 KB |
481 Time(s) |
63.09 KB |
496 Time(s) |
46.29 KB |
481 Time(s) |
38.83 KB |
513 Time(s) |
Posted: Tue Jan 30, 2007 7:54 am Post subject: Mk 3 steel main gear legs |
| Rex Rodebush
Rex:
I think you may be a bit confused on the steel gear legs.
Normalized 4130 is stiff. When bent, it will remain bent.
Heat treated 4130 is flexible. When bent, it will return to its
original shape. It is now a spring.
Titus, Alabama |
Posted: Tue Jan 30, 2007 8:04 am Post subject: Mk 3 steel main gear legs |
| I think Kolb supplied two designs for the steel legs. | Rex
Rodebush
Rex:
Forgot to mention in previous post.
The heat treated legs will seem very stiff until there is some weight
on them. Once you get the engine, wings, fuel, and your body in the
airplane, the legs will get quite flexible. Without the weight, they
will seem like they will not bend.
Titus, Alabama |
Rex Rodebush
Posted: Tue Jan 30, 2007 8:31 am Post subject: Re: Mk 3 steel main gear legs |
Hi John,
My understanding is that if you take a piece of 4140 normalized and bend it it will deflect to the yield point and then deform. If you take the same piece and heat treat it (heat, quench and draw) to a higher yield it will then bend and deflect but will require a much higher force to bend the same amount and will therefore be stiffer (and also harder with the higher yield).
If I'm wrong on this let me know.
Rex Rodebush
Posted: Tue Jan 30, 2007 8:38 am Post subject: Mk 3 steel main gear legs |
John, One of the things that helped make up my mind to not install the steel legs is the need to change the wing angle of incidence (according to the TNK document that came with the legs). Did you do this and if so, how?
Rick
On 1/30/07, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:[quote] --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Rodebush
Rex:
"Ya'll drop on in"
Rex Rodebush
Posted: Tue Jan 30, 2007 8:48 am Post subject: Re: Mk 3 steel main gear legs |
Rex:
"Forgot to mention in previous post.
airplane, the legs will get quite flexible. Without the weight, they..."
John,
I agree, I think we are saying the same thing.
Also, I did not change the wing incendence. These legs plus the fat tires will set me up higher so I'm closer to a 3 point stall landing, which I want.
Rex
Posted: Tue Jan 30, 2007 12:14 pm Post subject: Mk 3 steel main gear legs |
the steel
the TNK
| Rick
Rick:
No, I didn't do that. First I heard of it.
My legs and main gear mounts were designed and fabricated by Brother
Jim. I left the incidence per what was called for in the plans.
Would be nice to have less incidence, probably pick up a few mph by
having the tail boom fly straight through the air, rather than at an
angle which increases drag. A little late for that at this time.
Don't want to change windshield, quarter windows, and lift struts.
I am pretty happy with 88 mph at 5,000 rpm empty with 10 gal fuel. Of
course this slows down to around 80 to 85 when I am seriously loaded
to go traveling. Still a decent cruise speed that has proven, if I am
patient, I can get there and get home.
Titus, Alabama |
Rex Rodebush
Posted: Tue Jan 30, 2007 1:10 pm Post subject: Re: Mk 3 steel main gear legs |
the steel
the TNK
| Rick
Rick:
John / Rick,
kolb is suppling a new rear wing attach fitting that is slightly wider than the old one. This allows you to add washers on either side to raise or lower the trailing edge. I wanted these just in case I needed them for fine tuning. I think they were made so you could compensate for the new gear. Travis could give you the details.
Rex
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Wed Jan 31, 2007 2:54 am Post subject: Re: Mk 3 steel main gear legs |
No mention of changing the wing incidence on my plane either.
_________________ Scott
www.ill-EagleAviation.com
do not archive |
rap(at)isp.com Guest
Posted: Wed Jan 31, 2007 4:58 am Post subject: Mk 3 steel main gear legs |
| Quote: | --> I got the paper work with my steel gear legs that recomended
changing the wing incidence. I did not do it. I will see how it flys
fist. I got my call back from the FAA for the inspection end of FEB.
Will have two inspectors they will be using it as a training leason for
the new guy.
Kolb-List message posted by: "icrashrc" <icrashrc(at)aol.com>
Posted: Thu Feb 01, 2007 11:51 am Post subject: Mk 3 steel main gear legs |
Are this legs for a Mk-3 Classic?
Do you still have them?
Pic?
Denny Rowe
Steven Green
Posted: Thu Feb 01, 2007 7:59 pm Post subject: Mk 3 steel main gear legs |
Rex,
I have always used aluminum gear legs. I have bent one set in about 500
hours. Those were bent about 30 seconds after a rod bearing failed in a
582. I was over Tellico lake when the engine failed and used up all of my
excess air speed to clear a line of trees that was between me and the field
I was going to land in. After clearing the trees I was about 3 knots above
stall speed.....not enough to flare for a good landing.
Steven Green
Rex Rodebush
_________________ Steven Green |
Posted: Thu Feb 01, 2007 8:53 pm Post subject: Mk 3 steel main gear legs |
Are "these"
