Fuel flow for 914
davidjoyce(at)doctors.org
PostPosted: Fri Jan 26, 2007 1:52 am    Post subject: Fuel flow for 914 Reply with quote
Can anyone recommend a fuel flow measuring system for a 914 (ie one that
measures supply and return flows), preferably using Floscan Transducers?
Thanks, David Joyce, G-XSDJ
rparigor(at)suffolk.lib.n
PostPosted: Fri Jan 26, 2007 5:28 am    Post subject: Fuel flow for 914 Reply with quote
Hello David
"> Can anyone recommend a fuel flow measuring system for a 914 (ie one
that
measures supply and return flows), preferably using Floscan Transducers?"
I am not flying yet, have a analogue UMA 1+1/4" fuel flow gauge with EL to
match the rest of my engine instruments. I had 3 marks put on the face
~75%, 100% and 115%, I will be glad to share the dart throw numbers I
chose if you are interested. The face can be changed if I missed by too
much.
I have enough glass in panel, Dynon D10A, and 296 Garmin, for engine
monitoring I am much more comfortable following trends and evaluating data
with needles, just call me old fashioned.
Anyway the UMA comes with a 201B, and I used a Matronics FuelChec (tm)
Return Flow Controller that comes with a 201B to subtract the return from
FPR to tank. If real world flow numbers are not quite accurate enough, Ed
can recalibrate instrument.
Just a side note, I have a Europa mechanical float style sender in my tank
(8 stations). Instead of using the round VDO gauge, I had UMA make a
custom 1+1/4" gauge with EL in 1/8 increments, have yellow at 1/8 to 1/4
and red from 0 to 1/8. If by chance anyone is interested I will share the
ohm data for the 8 points. Such a stupid simple devise, 8 reed switches
and a magnet on the float, the reed switches have a built in hysteresis so
bouncing between stations should be minimal, Europa seems to have
calibrated the stations to match the shape of the tank (stations are not
same spacing, so i assume they did their homework) and cares not about
water, type of fuel and gives me a pseudo inspection hole I can semi look
into tank.
You can get UMA in 2+1/4 and probably 3+1/8. With the 2+1/4 and 3+1/8 you
can get a low and high warning light if you wish, or since it is simple
analogue driving the gauge on the fuel and fuel flow, could build your own
warning light circuit fair easy.
If you want a piece of glass with more buttons and functions, you may want
to look at Matronics, and JPI Fuel Scan 450.
http://www.matronics.com/
http://www.umainstruments.com/newTwo1.htm
This is a down-loadable UMA Catalog:
http://www.sunav.com/uma-electronic.pdf
Sharon is the gal you want to talk to for Sales, and Ed is the Engineer.
Very easy folk to deal with. They exchanged my supplied with FWF MP gauge
for one with proper markings (slight charge). After mounting 2+1/4" engine
instruments (MP, Tach, and Differential) which matched the rest of panel
2+1/4" stuff that is using UMA EL Light rings, found out "No good" since I
can not view them straight on, the light ring obstructed a bit too much
view of the gauge. No problem, sent back and had installed internal EL,
now things are much more better!
Ron Parigoris
paul.mcallister
PostPosted: Fri Jan 26, 2007 5:32 am    Post subject: Fuel flow for 914 Reply with quote
I beleive that Matt Dralle sells a system that works in high reverse flows
situations such as the 914. - Paul
gcrowder2
PostPosted: Fri Jan 26, 2007 7:32 am    Post subject: Fuel flow for 914 Reply with quote
Hi David - I have used the Matronics Fuel Scan DX with return fuel
controller for 3 yrs now
and has been faultless so far. I have a shutoff valve in the return line to
the tank that
is extremely helpful for debug. Instructions are good and support was
immediate when I
had a small cabling snag.
Glenn
Reply-To: europa-list(at)matronics.com
To: "Europa list" <europa-list(at)matronics.com>
Subject: Fuel flow for 914
Date: Fri, 26 Jan 2007 09:50:45 -0000
<davidjoyce(at)doctors.org.uk>
FREE online classifieds from Windows Live Expo – buy and sell with people
you know
jodel(at)nildram.co.uk
PostPosted: Fri Jan 26, 2007 10:16 am    Post subject: Fuel flow for 914 Reply with quote
Hi,
Jpi do the FS450 which will cope with the input from two floscans.
http://www.jpinstruments.com/fuel_scan.html
I have the instrument and harness which are surplus to requirements (but not
the sensors) if you are interested.
Simon G-BZTN
PostPosted: Fri Jan 26, 2007 10:46 am    Post subject: Fuel flow for 914 Reply with quote
Simon, Thanks for that. What sort of price are you thinking of? And is it
surplus because of some problem or have you found a better system? regards,
David
Gilles.Thesee(at)ac-greno
PostPosted: Fri Jan 26, 2007 12:56 pm    Post subject: Fuel flow for 914 Reply with quote
Hi all,
We're using an FS 450 with our Rotax 914, and are satisfied with it.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
