IO 540 Performance
d_emond(at)mweb.co.za
PostPosted: Tue Jan 30, 2007 9:44 am    Post subject: IO 540 Performance Reply with quote
I am looking for a copy of the performance specs for a Lycoming IO 540 - D4A5, or similar 260hp Lyco.
Power curves etc!
Dave Emond
40159
Tim Olson
PostPosted: Tue Jan 30, 2007 10:15 am    Post subject: IO 540 Performance Reply with quote
Here you go:
http://www.myrv10.com/tips/engine_IO540.html
Power curves etc!
Dave Emond
40159
rv10builder(at)verizon.ne
PostPosted: Tue Jan 30, 2007 10:18 am    Post subject: IO 540 Performance Reply with quote
I believe Tim Olsen's site has everything you ever need for information.
Lyc-IO540-Power-Chart.doc
 Filename:  Lyc-IO540-Power-Chart.doc
 Filesize:  62 KB
 Downloaded:  2433 Time(s)
jim(at)CombsFive.Com
PostPosted: Tue Jan 30, 2007 10:49 am    Post subject: IO 540 Performance Reply with quote
At Tims web site:
From: "Dave & Brenda Emond" <d_emond(at)mweb.co.za>
Date: 2007/01/30 Tue PM 12:43:59 EST
Subject: Re: IO 540 Performance
Power curves etc!
Dave Emond
40159
PostPosted: Tue Jan 30, 2007 10:54 am    Post subject: IO 540 Performance Reply with quote
Thanks Tim
Kellym
PostPosted: Tue Jan 30, 2007 9:05 pm    Post subject: IO 540 Performance Reply with quote
I didn't see anything on weight, dry, with or without accessories.
Is there much variation between the variants of the parallel valve engine?
Pascal wrote:
[quote] I believe Tim Olsen's site has everything you ever need for information.
Kelly McMullen
KCHD
