hawk(at)digisys.net Guest
Posted: Sat Jan 27, 2007 8:58 am Post subject: Mattituck Buying Experience |
Last fall I pulled the jugs off my Skyote's C-90-8F (stuck ring, and guides needed reamed) and I found one of the cam followers had a wedding-ring fracture at the socket end. I decided to have the engine overhauled by a good shop, but found that for virtually the same price, I could get a brand-new Mattituck TMX O-200 (although it is an Experimental engine, it is built up from the latest Continental certified parts).
It came with all the recent factory production improvements (removable pushrod housings, new upper cylinder design) and beautiful new certified accessories including a light-weight starter, 60 Amp Alternator, Vacuum Pump drive assembly, new Precision Carb (complete with new airbox and filter) and new Slicks. The shipping crate had an all-plywood cover, and is better looking than most of my furniture. The price was 17K, with NO core required. I will slowly rebuild the C-90 as a learning process.
The Mixture Arm configuration was set up for side-to-side actuation, and my particular installation made the fore-and-aft arm the preferred type. I emailed Mahlon to find out where I could buy the alternate arm, and a couple days later the desired hardware just showed up in my mail.
I would recommend Mattituck for anyone considering a new engine. My experience with them could not have been better. Mahlon Russell should be considered a national treasure.
Hawkeye Hughes
Skyote, RV-3
rice737(at)msn.com Guest
Posted: Sat Jan 27, 2007 9:18 am Post subject: Mattituck Buying Experience |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Ditto
d_emond(at)mweb.co.za Guest
Posted: Sat Jan 27, 2007 12:29 pm Post subject: Mattituck Buying Experience |
I support your view. My purchase of a TMX IO-540 went without a hitch. Mahlon has given terriffic support, beyond expectation. Thanks Mahlon.
Dave Emond
RV-10
40159
