MauleDriver(at)nc.rr.com Guest
Posted: Thu Jan 18, 2007 8:51 pm Post subject: Rudder cable exits on tailcone |
Who used what here? I remember a recent post regarding 3rd party parts
for this. I see something called 'DDD' in Mr Deems tailcone. Looking
for advice here before I start riveting on the top skin.
Thanks!
Deems Davis
Posted: Fri Jan 19, 2007 4:33 am Post subject: Rudder cable exits on tailcone |
I used parts from Aircraft Spruce,
http://www.aircraftspruce.com/catalog/topages/ruddercable.php you can
get them from Cleveland, Wicks and others no doubt.
"DDD" is my shorthand for doing the "*D*rill, *D*ebur, and *D*imple"
Dance, as your have learned by now, you get LOTS of practice at this!
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
MauleDriver wrote:
parts for this. I see something called 'DDD' in Mr Deems tailcone.
Looking for advice here before I start riveting on the top skin.
Thanks!
Posted: Fri Jan 19, 2007 8:51 am Post subject: Rudder cable exits on tailcone |
I used the same parts from spruce. I wanted the cables to be removable
in case of, well I don't know what exactly... I used countersunk #6
screw nutplates. That also allowed me to have the fairings slightly
more aft to "capture" the cable sleeve. One thing that I learned though
is that putting the one screw directly in line with the opening makes it
tougher to install the cables later. If I had it to do again, I might
use 4 screws instead of 3 so I could keep the one out of the way for the
cable sleeve, or just offset the one in the front to one side of the
hole. Here's a picture:
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Tailcone%208.
html
cj
#40410
fuse
rv10(at)sinkrate.com Guest
Posted: Tue Jan 23, 2007 1:28 pm Post subject: Rudder cable exits on tailcone |
Thanks Deems and everyone else who responded (I've been offline for a
few days). I will be getting some of those Aircraft Spruce cable exits.
Deems Davis wrote:
Deems Davis # 406
> Thanks!
