Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Fri Feb 09, 2007 6:35 am Post subject: Rotax Rectifier Wiring |
Hello
The Rotax-Installation Manual, engine electric, 17-1, says: "Attention: Do not interupt circuit between Terminal C and +B of rectifier-regulator during engine run, as otherwise charging will stop."
What does that mean? Can I switch of the rectifier/regulator i.e. charging process with interupt of C/+B (similar to switching of the alternator field switch)?
Martin
Zodiac XL
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
NYTerminat(at)aol.com Guest
Posted: Fri Feb 09, 2007 9:08 am Post subject: Rotax Rectifier Wiring |
Martin,
Yes,
I put a switch (labeled "Alt") in between the C and B+, if you open up the circuit while the engine is running it will stop charging
Bob Spudis
In a message dated 2/9/2007 9:39:43 A.M. Eastern Standard Time, mpohl(at)pohltec.ch writes:
| Quote: | --> RotaxEngines-List message posted by: "Martin Pohl" <mpohl(at)pohltec.ch>
Hello
Martin
Zodiac XL
Martin Pohl
Zodiac XL QBK
http://forums.matronics.com/viewtopic.php?p=93908#93908
= Use lities Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> ======================
Martin Pohl
Posted: Fri Feb 09, 2007 3:10 pm Post subject: Re: Rotax Rectifier Wiring |
Bob
Thank you for the info! I will try to contact Rotax as well and ask them about the connectors. To me their installation instruction is quite unclear.
Martin
Zodiac XL QBK
