paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Wed Feb 01, 2006 7:05 pm Post subject: Mounting 914 waste gate servo |
Freg,
I mounted mine on top of the tunnel, but I manufactured up some aluminum
spacers and used through bolts. If I was to do this over again, I would
consider mounting the servo and the voltage regulator next to each other on
the fire wall. I would then make a fiberglass cover for them and connect a
cold air blast tube to the cover. It would make to servo far more
serviceable and free up space inside your instrument panel.
Paul
Ivor Phillips
Posted: Fri Feb 03, 2006 5:17 am Post subject: Mounting 914 waste gate servo |
Ferg
I used slightly longer AN 3 bolts so i could put the ancor nuts inside the
tunnel, Where in my opion they should be!
Quote: | to mount the subject item on the 'tunnel top' with MS21047-4 anchor nuts
On
top (Manual accent)
of the tunnel. I can't see why, since the servo would then depend on four
3/32 inch rivets through the 1/8inch composite.
Ivor
