ctsmallwood(at)waitrose.c Guest
Posted: Thu Jan 18, 2007 4:34 am Post subject: Water in tailplane elevator |
Hi All,
A couple of Q,s and help please.
Any one had a problem with H20 in the tailplane strb side
It is a small amount , still same weight as Port tailplane.
Any ideas on removal? noise/wash appears to be F/wd
of pip pin apperture.
Obviously I need to cover pip pin slots,
anyone have a fix for this please?
See you, (those attending) on Saturday at Bosworth Hall
Colin Smallwood G-DEBR
15 hrs into licence, circuits OK but Landing !!!
davidjoyce(at)doctors.org Guest
Posted: Thu Jan 18, 2007 5:03 am Post subject: Water in tailplane elevator |
Colin, Put a sticky PVC circle over them, along with your other access
holes, and wing roots. It will go faster apart from keeping the water out.
Regards, David Joyce, G-XSDJ
nwcmc(at)tiscali.co.uk Guest
Posted: Thu Jan 18, 2007 5:49 am Post subject: Water in tailplane elevator |
A quick solution for covering the pip pin holes is to use discs of self adhesive white pvc sheet. They look neat and unobtrusive. I used them for the wing drag pin and flap rod inspection holes as well. They cope well with the surface curvature, especially at the wing root. It does mean that you need a new set every time the pins are removed. This is only a significant problem if you rig and derig for each flight.
Nigel Charles
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of colin smallwood
Sent: 18 January 2007 12:33
To: matronics
Subject: Water in tailplane elevator
Hi All,
[quote] - The Europa-List Email Forum - --> http://www.matronics.com/Navigator?Europa-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com [b]
pjeffers(at)talktalk.net Guest
Posted: Thu Jan 18, 2007 6:03 am Post subject: Water in tailplane elevator |
Hi Colin,
I have had to deal with H2O ingress in tail planes and wings. The wing was
difficult but tailplanes a lot easier to dry out. It would be simpler to
describe the method when we meet at Bosworth Hall on Saturday rather than by
e mail.
See you Saturday
Pete Jeffers
ami(at)mcfadyean.freeserv Guest
Posted: Thu Jan 18, 2007 1:17 pm Post subject: Water in tailplane elevator |
<<It will go faster apart from...>>>
How much faster?!
Duncan McF
