colsonj(at)provide.net Guest
Posted: Tue Jan 16, 2007 6:38 am Post subject: Fuel Tank Update |
I've looked at the archives on fuel tank problems and fixes and I gather Skystars last fuel tanks where built using a vinyl ester resin.Has anyone using that tank experienced problems with auto fuel and the additives?I've pulled the 13 gal.tanks on my 1992 IV 1050 and I'm concidering buying Johns new tanks and I'd like to continue to use auto fuel.Cliff
kitfoxmike
Posted: Tue Jan 16, 2007 7:25 am Post subject: Re: Fuel Tank Update |
currenty I'm running on the left tank, which I believe is one of those tanks, I replaced the smaller tank on the left wing with a new larger one bought from skystar two years ago just before they went defunked. I put in auto fuel and locally it's suppose to have 10% alchahol, and it's also oxegenated, whatever that is suppose to mean, totally. I've been a mechanic for 28 years and I still don't fully understand what they are doing with our fuel, if you know what I mean.
crazyivan
Posted: Tue Jan 16, 2007 9:41 am Post subject: Re: Fuel Tank Update |
Ya gotta be a stinking politician or a corn-belt lobbyist to know what they are doing to our fuel. Maine has so far resisted jumping on the ethanol band wagon, but I think it's only a matter of time before some hack bureaucrats put the squeeze on us to comply with their voodoo science.
_________________ Dave
Piper PA-22/20 |
kitfoxmike
Posted: Tue Jan 16, 2007 10:11 am Post subject: Re: Fuel Tank Update |
I agree, we are left pretty well in the dark.
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jan 16, 2007 1:31 pm Post subject: Fuel Tank Update |
Cliff,
I have researeched Vinyl Ester resins and it seems that there are numerous
formulations. Some are formulated for alcohol resistance, others for other
purposes. I have been running an experiment since October first of 2006 and
have several balsa wood floats coated with: 1) the vinyl ester resin
avalilable from Aircraft Spruce, 2) Kreem, the fuel tank sloshing compound
provided by Skystar, and 3) Gas Tank Sealer from JC Whitney. I have these
floats in test tubes in California auto gas - 7% ethanol, I believe, and
denatured alcohol 97% ethonol.
Periodically, I take the floats up to a virtual altitude of 14,000 ft. which
is likely above the service ceiling of our aircraft. This allows me to
check for a violation of the integrety of the coating as in a low pressure
environment, the air in the balsa would expand and force it's way through
the coating resulting on a bubble or bubbles on the surface of the float.
This vacuum testis done in a bell jar and is observed closely.
I can tell you this much. Keep in mind that the vinyl ester resin from
Aircraft Spruce in an unknown quantity as it comes in a plain can with only
a flamability lable and the ACS part number. I think it is a 3M product per
the ACS catalogue, but have been unable to indentify it more closely than
that. The vinyl ester resin is the only one to date that has any detectable
reaction to the alcohol. In both instances - the 7% and the 97% the surface
has lost it's sheen. None of the floats covered with the tank sealer have
shown any difference in appearance.
To examine the surface appearance of the floats, they must be dried. After
returning the floats to their respective fluid environments, the sealer
coated floats showed no difference taken to the 14,000 ft. pressure, but the
vinyl ester floats showed that they had absorbed air in to the resin layer
as thousands of near microscopic bubbles were seen coming from the entire
resin surface.
What does this all mean? Who knows for sure, but I have the 1992/3 fuel
tanks Kreem sloshed. I am happy with that. For my own personal sense of
well being, if I had the newer vinyl ester resin tanks, I would slosh them
with Kreem using the Kreem guidelines with some info gleaned from this list
regarding thinning of the Kreem before sloshing.
Other opinions may vary.
Lowell
nealscherm(at)comcast.net Guest
Posted: Tue Jan 16, 2007 2:20 pm Post subject: Fuel Tank Update |
OK,
So how are you thinning the slosh? I have the new tanks and will take your suggestion.
Neal
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: "Lowell Fitt"
Cliff,
Periodically, I take the floats up to a vir tual a ltitude of 14,000 ft. which
has lost it's sheen. None of the floats cover ed with the tank sealer have
resin surface.
Lowell [quote][b]
Float Flyr
Posted: Tue Jan 16, 2007 2:49 pm Post subject: Fuel Tank Update |
Voodoo science??
What an overt dirty insult to true Voodoo science!
Noel
When You're right, you're right!
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
crazyivan
Posted: Tue Jan 16, 2007 3:05 pm Post subject: Re: Fuel Tank Update |
My apology to all of the Voodoo Scientists I insulted. You are all a million times better than the stinking politicians and the lobbyists.
Piper PA-22/20 |
kitfoxmike
Posted: Tue Jan 16, 2007 3:31 pm Post subject: Re: Fuel Tank Update |
one note on the new tank that I got from skystar, it's fiberglass and I asked if it needed to be sloshed, frank told me no. So I didn't.
Posted: Tue Jan 16, 2007 6:35 pm Post subject: Fuel Tank Update |
Cliff,
I hope someone chimes in here if I have this wrong, but I think the
recommendation is that you first rinse with Acetone to remove any residue
that may be in the tank. For some reason there tends to be a build up of
pressure when rinsing, so have some way to bleed that off during the rinse.
Thin the Kreem with MEK 50:50 and use that for the slosh. Follow the
directions on the btle for the actual sloshing.
Regarding MEK, before anyone chimes in about its hazards, please do a Google
search and read the MSDS. There are far too many urban legends on this
stuff.
Lowell
dave
Posted: Tue Jan 16, 2007 6:54 pm Post subject: Fuel Tank Update |
all you guys ..sheesh
GREASE IS BLUE AND LITHIUM
HERE IT IS http://www.valvoline.ca/pages/products/heavyduty.asp
All-Fleet Cerulean #2 Grease
Valvoline Cerulean Grease (Blue Lithium Complex) is a premium
grease designed to meet the stressful demands of off-road, commercial fleet
and industrial environments. It provides excellent performance over a
variety of operating conditions and may displace other top-of-the-line
greases for severe and general purpose lubrication.
a.. Is designed as a tacky, lithium complex grease containing
a high level of select extreme-pressure additives for maximum loading
protection
b.. Contains oxidation, rust and corrosion inhibitors for
long-life performance
c.. Features excellent resistance to water washout
d.. Is dyed blue for easy identification
43 Bytes |
9995 Time(s) |
6.78 KB |
9994 Time(s) |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dafox(at)ckt.net Guest
Posted: Fri Jan 19, 2007 8:08 pm Post subject: Fuel Tank Update |
Dave, I'm with you !!!
This is all a political movement, it can't last. if they took all the corn
in the United States and turned it in to Ethanol, it would only amount to
15 % of the fuel supply. in the mean time there would be no feed for the
live stock, wild animals, birds and etc. and how about corn meal? No
Taco's either, this ain't good
This government for the people is way out of hand..... David
