CJohnston(at)popsound.com Guest
Posted: Mon Jan 15, 2007 12:16 pm Post subject: James Cowl & plenum |
Hey Deems -
Are you using the plenum? I've not really decided, and was wondering if
others had thoughts about it. I don't know much about the mechanics of
it, but it seems like it'd improve cooling etc. Also it (I guess) would
reduce stress on the cowl and attachments, as the plenum is pressurized
and not the entire cowl. Am I incorrect here? What about inspecting
the engine through the oil filler hole? You wouldn't see the top of the
engine there - is that a bummer? Also, doesn't the engine get hot where
it gets close to the plenum? Is this a problem? I'd love any info
before I go calling Sam about it.
cj
#40410
fuse
www.perfectlygoodairplane.net
Deems Davis
Posted: Mon Jan 15, 2007 1:36 pm Post subject: James Cowl & plenum |
This may be a case of the blind leading the blind, but here's what I've
learned.
Apart form aesthetics, the main reason for my going with the James cowl
& plenum was performance. there are no RV-10'd flying with it yet so
performance improvements are subjective. However there are enough RV 6.7
& 8's flying with them to indicate that the combination produces
anywhere between 5-10 mph. It would take a LOT of additional HP to get
the kind of an improvement.
The biggest portion of the improvement is attributable to the Plenum. I
don't begin to understand all of the fluid dynamic physics, but as Sam
explained to me, the 'secret is: with Wills cowl rings you get 32 sq
inchs of air entering the plenum, and you want 32 sq inches of area
around the bottom of the clys for the air to exit the 'pressurized'
portion. an imbalance with more air coming in than exiting results in
drag with the air going back out the front of the cowl. The advantages
of the plenum are that there is no 'leakage' between the baffling and
the top of the cowl. some measurements have indicated that as much as
50% of the cooling air can be lost through what otherwise appears to be
a tight fit between baffling material and the cowl. the leakage also
contributed to increased drag. Sam's cowl comes with templates for his
own baffling that mates to his cowl. His baffling templates are designed
to equalize/optimize the air entering the plenum and the air exiting.
Some builders have used Van's baffling kit and adapted it to Sam's
plenum, Sam strongly cautioned me against this, believing it was a
source of problems with the fitment of the plenum, and also with the
balance of the air flow. he quoted me the numbers on van's baffles and
the area around the bottom of each cyl was larger than the area he
designed in his plans. Another benefit of a properly functioning
plenum/baffle combo it better balanced cooling between cyls. I believe
the Sam indicates that cyl temps with his plenum should not vary by
more than 2% (!).
I've spoken w/ 2 -10 builders that had problems fitting Sam's plenum.
both used Van's baffle kit. I almost skipped ordering a plenum based on
their troubles. to Sam's credit, he remade plenums for both builders and
sent them at his expense. One builder seems satisfied and one isn't. I
spoke with both Will and Sam about the fittment situation, and they
called the builders and talked with additional builders and concluded
that the problems were most likely due to using Van's baffling. Will
told me " if you order one of our products and it doesn't work as it is
supposed to we will stay with you until it does"
So, Yes I have ordered Sam's Plenum,
Access (easy) to the top of the engine is a drawback of the plenum, ans
it derives its benefits from a 'hard' mounting to the baffling. (I've
got these pretty polished induction tubes, color coordinated plug wires,
custom painted crankcase, chrome valve covers, and it's all going to get
covered up. (I just remind myself that 5-10 mph is worth it!). The
epoxy/glass that Sam used is designed for the temps of the engine
compartment.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Chris Johnston wrote:
Hey Deems -
cj
#40410
fuse
ddddsp1(at)juno.com Guest
n8vim(at)arrl.net Guest
Posted: Mon Jan 15, 2007 3:58 pm Post subject: James Cowl & plenum |
Hey,
You'll slow down upon impact.... until then, Go Speed Racer Go!
-Jim do not archive
ddddsp1(at)juno.com wrote:
| Quote: | Deems,
I never realized you were so interested in SPEED. Are you gonna race
at RENO with your 10? I bet you are gonna race John Cox in 2020 when
he gets his RV10 done............... Haven't people told you that
at our age we are suppose to SLOW DOWN. You are retired....you don't
have to get there 20 minutes early. Seriously though, that plenum
setup sounds really ideal and will hopefully give you the speed and
cooling that has eluded some RV10 builders. You will be breaking new
ground when you start flying. Hope you are ready for the POSTS from
all the EXPERTS on this list telling you your numbers CAN"T be real.
Keep sanding that fiberglass!
DEAN 40449
________________________________________________________________________
*FREE* Reminder Service - NEW from AmericanGreetings.com
*Click HERE* and never forget a Birthday or Anniversary again!
<http://track.juno.com/s/lc?s=197335&u=http://www.americangreetings.com/products/online_calendar.pd?c=uol5752>
AV8ORJWC
Posted: Mon Jan 15, 2007 4:22 pm Post subject: James Cowl & plenum |
Dean –
Here is the gauntlet for 2007. Knots not MPH. 200.00 cruise in a RV-10. That’s head to head, over a defined course, same fuel load (60 US Gal). Block to Block just like Nextel Nascar.
Oh yeh, It’s going to fall out of the sky from flutter issues, I keep forgetting. Less weight, Less drag, stronger construction, more efficient cooling, bigger grin. My money is on Deems and that is in addition to all the beer that I owe Camp Condrey from such a pathetic showing of completed RVs at OSH last summer. I am speculating that Deems will win it, cause he can read those gigantic OP technologies screens a millisecond quicker for engine tweaking.
Anyone else of us old timers notice the similarity between Chris Johnson and James McClow. Main difference is in his continual grin, that of his partner and the blazing progress he is making due to lack of spelling errors. I think the secret is a passionate partner chasing the same goal in the same house.
John Cox
the Turbanator #40600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com
Sent: Monday, January 15, 2007 3:46 PM
Subject: Re: James Cowl & plenum
Deems,
I never realized you were so interested in SPEED. Are you gonna race at RENO with your 10? I bet you are gonna race John Cox in 2020 when he gets his RV10 done............... Haven't people told you that at our age we are suppose to SLOW DOWN. You are retired....you don't have to get there 20 minutes early. Seriously though, that plenum setup sounds really ideal and will hopefully give you the speed and cooling that has eluded some RV10 builders. You will be breaking new ground when you start flying. Hope you are ready for the POSTS from all the EXPERTS on this list telling you your numbers CAN"T be real.
DEAN 40449
FREE Reminder Service - NEW from AmericanGreetings.com
Click HERE and never forget a Birthday or Anniversary again! [quote] [b]
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Jan 15, 2007 4:36 pm Post subject: James Cowl & plenum |
Great information Deems. I am leaning towards the James cowl and
plenum, so this is good info for me. One question. Does the James
cowl fasten with camlocs or a hinge, or does it matter? I would like
to use camlocs if possible.
David Maib
#40559
I've learned.
cowl & plenum was performance. there are no RV-10'd flying with it
yet so performance improvements are subjective. However there are
enough RV 6.7 & 8's flying with them to indicate that the combination
produces anywhere between 5-10 mph. It would take a LOT of additional
HP to get the kind of an improvement.
I don't begin to understand all of the fluid dynamic physics, but as
Sam explained to me, the 'secret is: with Wills cowl rings you get 32
sq inchs of air entering the plenum, and you want 32 sq inches of
area around the bottom of the clys for the air to exit the
'pressurized' portion. an imbalance with more air coming in than
exiting results in drag with the air going back out the front of the
cowl. The advantages of the plenum are that there is no 'leakage'
between the baffling and the top of the cowl. some measurements have
indicated that as much as 50% of the cooling air can be lost through
what otherwise appears to be a tight fit between baffling material
and the cowl. the leakage also contributed to increased drag. Sam's
cowl comes with templates for his own baffling that mates to his
cowl. His baffling templates are designed to equalize/optimize the
air entering the plenum and the air exiting. Some builders have used
Van's baffling kit and adapted it to Sam's plenum, Sam strongly
cautioned me against this, believing it was a source of problems with
the fitment of the plenum, and also with the balance of the air flow.
he quoted me the numbers on van's baffles and the area around the
bottom of each cyl was larger than the area he designed in his plans.
Another benefit of a properly functioning plenum/baffle combo it
better balanced cooling between cyls. I believe the Sam indicates
that cyl temps with his plenum should not vary by more than 2% (!).
on their troubles. to Sam's credit, he remade plenums for both
builders and sent them at his expense. One builder seems satisfied
and one isn't. I spoke with both Will and Sam about the fittment
situation, and they called the builders and talked with additional
builders and concluded that the problems were most likely due to
using Van's baffling. Will told me " if you order one of our products
and it doesn't work as it is supposed to we will stay with you until
it does"
ans it derives its benefits from a 'hard' mounting to the baffling.
(I've got these pretty polished induction tubes, color coordinated
plug wires, custom painted crankcase, chrome valve covers, and it's
all going to get covered up. (I just remind myself that 5-10 mph is
worth it!). The epoxy/glass that Sam used is designed for the temps
of the engine compartment.
Deems Davis # 406
<CJohnston(at)popsound.com>
Hey Deems -
wondering if
mechanics of
would
pressurized
of the
where
cj
#40410
fuse
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Deems Davis
Posted: Mon Jan 15, 2007 5:32 pm Post subject: James Cowl & plenum |
I don't believe there's any restrictions on using camlocs. I haven't
read through his plans, but I believe he assumes hinges, just like Van's.
I was also initially thinking about Camlocs, but after seeing some
really well done hinge installations, I've decided to go that way.
David Maib wrote:
David Maib
#40559
Deems Davis
Posted: Mon Jan 15, 2007 5:53 pm Post subject: James Cowl & plenum |
I'm really not a speed freak, I'm just stingy! I laid out enough $'s for
this beautiful mass of precision machined parts, that I want to get all
of my money's worth. Cleaning up drag, is like 'free hp'. So if you're
going to go to the effort to build a nice plane you might as well get it
to perform at it's optimum, I don't know if John's gauntlet of 200 KTS
is achievable for this grasshopper, perhaps, If I began from 5K ft and
dove to 20 ft. above the Salton Sea, on a cold day in late Jan, and
leveled off for a 2 mile speed trap, I might make it. But only time,
and LOTs more F/G sanding/priming will tell
Deems Davis # 406
| Quote: | Deems,
DEAN 40449
rvbuilder(at)sausen.net Guest
Posted: Tue Jan 16, 2007 7:23 pm Post subject: James Cowl & plenum |
On another note about James service, I was one of the first to get the
plenum for the IO-540 back around OSH. It's been sitting in a box since
then because of my move and subsequent building out a new
workshop/hanger. I heard a couple months ago about the fit problem but
decided to wait until I was to the point of needing it before calling
Sam. He called me about two weeks ago to let me know about the problem
and that a new one was being shipped that day. Luckily he called before
going to UPS or my plenum would be sitting at an abandoned workshop in
TX rather than with me in WI!
Once upon a time Deems and I were about even and doing a lot of the
same things like engine, cowl, plenum, etc and I was the one doing a ton
of due diligence and explaining it to the list. Gotta say I'm glad this
move is giving me a substantial break so Deems can have the steep
learning curve for a while! Although if I would have known about my
little hiatus I could have willed him all of my slots as I have had the
engine and plenum since OSH and the cowl for almost two months.
Can't wait for Deems to be flying as it's going to be like a preview of
mine.
Michael Sausen
-10 #352 limbo
LarryRosen
Posted: Tue Jan 16, 2007 7:39 pm Post subject: James Cowl & plenum |
I was also at the same point in the build as you were Michael before you
move. Deemes has speed by me (summer was tough with all the family
stuff getting in the way of building Now I am just in front of you
and watching and learning from Deemes.
Deemes, keep it up, keep posting to your web site. It is helping all of us.
Larry
#356 (4 behind Michael)
mine.
Michael Sausen
-10 #352 limbo
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Rick S.
