CrownLJ(at)verizon.net Guest
Posted: Sun Jan 14, 2007 11:29 am Post subject: Rim Question for Kitfoxmike |
Subject: Re: : King fox Tires first report
Hey Mike,
What wheel rim and tire do you now have? ( the big one on your website) I currently have Matco 6" rims, and it looks like that is at least an 8" tire, so I would have to change rims. How high is your axle from the ground with that set up?
larry
kitfoxmike
Posted: Tue Jan 16, 2007 7:21 am Post subject: Re: Rim Question for Kitfoxmike |
larry,
not sure what you are wanting to know, but I have the old atv wheel. The tire is that same size as the skyfox tire that is talked about. as far as the ground to axle distance, I'll have to take a measurement for an exact for the tire does squish a little sitting on the ground.
