Glenn Horne
Posted: Sun Jan 14, 2007 1:55 pm Post subject: Weight |
List, Glenn Horne here. I have a Model II with a 582.
I would like to get some empty weight of other Model II w/ 582's.
Mine seems to be little heavy empty.581 lb's.
Glenn
Mnflyer
rliebmann(at)comcast.net Guest
Posted: Sun Jan 14, 2007 2:14 pm Post subject: Weight |
Glen,
My Model 2/582 weights in at 535 lbs. including a BRS.
Ron
eskflyer(at)lvcisp.com Guest
Posted: Sun Jan 14, 2007 2:37 pm Post subject: Weight |
Model 2 with 582 c box ivo inflight , 467 lbs empty
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Sun Jan 14, 2007 3:39 pm Post subject: Weight |
My 2 with the 582 was at 478.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of john perry
Sent: Sunday, January 14, 2007 5:37 PM
Subject: Re: Weight
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
Lynn Matteson
Posted: Sun Jan 14, 2007 4:04 pm Post subject: Weight |
Good Lord, you guys must be filling the wings with helium! These low
weights have got to be with the 6 gallon tanks, right? What else
makes these planes so light compared to the IV's? Jeez, if my ex-
wives climbed on your scales we might still be married.
Lynn
On Jan 14, 2007, at 6:39 PM, Bradley M Webb wrote:
[quote] My 2 with the 582 was at 478.
Bradley
Subject: Re: Weight
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
GENTRYLL(at)aol.com Guest
Posted: Sun Jan 14, 2007 5:02 pm Post subject: Weight |
I believe you made that same remark when I told you my IV-1050 weighed only 575 with a subaru on front, but it is a fact. Now that I have added the farings for the struts and landing gear, it is about 585.
Posted: Sun Jan 14, 2007 5:08 pm Post subject: Weight |
nope , 13 gallon right tank and 10 gallon nose tank . . did a new weight and
balance last year after installing new ELT and was same weight . light coats
of poly brush and poly spray and very light coat of paint . . Makes for a
great awsome offroad vehicle not to metion the climbout and STOL performance
Float Flyr
Posted: Sun Jan 14, 2007 6:46 pm Post subject: Weight |
I haven't weighed mine but the W&B that came with it says 511 on wheels.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
wliles(at)bayou.com Guest
Posted: Sun Jan 14, 2007 7:02 pm Post subject: Weight |
What makes the 1s and 2s and 3s so light is thiner spars, fewer ribs,
light fabric, thinner and smaller diameter struts, simple, light
engines, single fuselage fuel tank, or smaller wing tanks, minimal
instrumentation, no amenities such as cabin heat, insulation, baggage
storage, etc. In other words the least amount of materials were used to
make a safe airplane with an enclosed cabin. If it wasn't necessary for
flight and minimal comfort it isn't on the airplane. And that's why a
503 powered Model II or a B Model Avid with minimal equipment and paint
can get off in under 100 feet and climb like a bat. Each succeding
Model gained horsepower, comfort, and weight, lots of weight. Of course
most builders seem to have to improve things, which almost always means
adding weight, often lots of weight which results in some fat Model 2s
and 3s. Glenn's model II weighs almost as much as my Avid MK IV STOL
(547lbs). I still think the earlier Avids and Kitfoxes when built
light are the most fun of the litter.
Jerry Liles
Lynn
> Bradley
> To: kitfox-list(at)matronics.com
> Subject: Re: Weight
Float Flyr
Posted: Sun Jan 14, 2007 7:32 pm Post subject: Weight |
What's missing from your plane?? A starter and battery???
That's light!
Noel [quote]
Kitfox III-A
Posted: Sun Jan 14, 2007 7:50 pm Post subject: Weight |
I have starter battery 13 gallon wing tank 10 gallon nose tank nav strobe lights full instruments with lighting and heater insulation all the comforts of home and she is only 467 empty . The secret is in the finishing of the fabric . Use minumum amounts of silver and paint and you will have a lite weight bird.
John Perry
rexinator(at)gmail.com Guest
Posted: Mon Jan 15, 2007 7:09 am Post subject: Weight |
My M2 shows 543 empty on the data plate.
Two 13 gal. wing tanks, one 2 gal. header behind seat, starter battery,
582 dual carb, gsc 3 blade grnd adj, c-box.
Rex Hefferan
Colorado N740GP
msm_9949(at)yahoo.com Guest
Posted: Mon Jan 15, 2007 9:17 am Post subject: Weight |
Hi Glenn.
My Model 2 is also a little heavy at 535# per the AW certificate. Since initial wt and balance calcs, I've added a cargo pod and a few other odds and ends. I'm guessing it's about 550 now.
Glenn Horne <glennflys(at)verizon.net> wrote:
[quote] List, Glenn Horne here. I have a Model II with a 582.
Glenn
[quote][b] No need to miss a message. [url=http://us.rd.yahoo.com/evt=43910/*http://mobile.yahoo.com/mail ]Get email on-the-go [/url]
with Yahoo! Mail for Mobile. [url=http://us.rd.yahoo.com/evt=43910/*http://mobile.yahoo.com/mail ]Get started.[/url] [quote][b]
dcaofak(at)acsalaska.net Guest
Posted: Mon Jan 15, 2007 9:53 am Post subject: Weight |
Watch your ounces when building, save the pounds. I used every suggested weight saving in the manual except drilling holes in the brake rotors.
Model III, 582 = 439.5 pounds empty.
This helps make up for the pilots lack of exercise and weight conditioning.
Also give a useful load of 660 pounds.
John Stoner
Alaska
Posted: Mon Jan 15, 2007 10:44 am Post subject: Weight |
WOW I thought mine was lite. I do have the drilled rotors though.
Looks like you should have some great ski flying this winter John.
My Bro has his covered now , there in Soldotna . He will be working on it this next hitch in from the slope .
Take care fly safe
John Perry
DO NOT ARCHIVE
mclayton(at)rochester.rr. Guest
Posted: Mon Jan 15, 2007 3:59 pm Post subject: Weight |
The W&B data sheet for my KF2 SN89 shows 461 lbs. as the empty
weight. Of course, when I am through rebuilding it, I will have to
redo the Weight and Balance.
