wigwag switch
rocketbob(at)gmail.com
PostPosted: Tue Jan 16, 2007 6:56 pm    Post subject: wigwag switch Reply with quote
For those of you looking to to wire your landing lights through one switch and also have a wigwag position, like the 4TL1-10 shown in Electric Bob's wigwag diagram but not ridiculously expensive and simpler to wire up, I have found a switch that is perfect. It is made by Carling and the part number is 2GP51-73. No distributors seem to carry this switch as an in-stock item, but if someone like Steinair (Stein are you listening) could order/stock it, it would be a simpler and better solution than any of the diagrams in Electric Bob's wigwag diagram. The switch is a DP3T toggle, OFF-ON-ON so you can wire it to be OFF-WIGWAG-ON for both landing lights yet still keep both lights in separate circuits/fuses when they're not "wagging". I have obtained an engineering sample of this switch from Carling and verified that it will do the job.
Bob Japundza
RV-6 flying F1 under const.
billsettle(at)bellsouth.n
PostPosted: Wed Jan 17, 2007 2:12 am    Post subject: wigwag switch Reply with quote
RocketBob,
Do you have a link to this switch? I tried going to Carling's site but could not pull up that number.
Bill Settle.
Winston-Salem, NC
-8 Wings
Date: 2007/01/16 Tue PM 09:54:53 EST
To: rv-list(at)matronics.com
Subject: wigwag switch
it will do the job.
Bob Japundza
PostPosted: Wed Jan 17, 2007 4:04 am    Post subject: wigwag switch Reply with quote
http://www.carlingtech.com/pdf/s_g.pdf
On 1/17/07, Bill Settle < billsettle(at)bellsouth.net (billsettle(at)bellsouth.net)> wrote:[quote]--> RV-List message posted by: Bill Settle < billsettle(at)bellsouth.net (billsettle(at)bellsouth.net)>
RocketBob,
Bill Settle.
Winston-Salem, NC
-8 Wings
From: "Bob J." <rocketbob(at)gmail.com (rocketbob(at)gmail.com)>
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
