Powder Coat quality
jesse(at)itecusa.org
PostPosted: Sat Jan 13, 2007 5:00 pm    Post subject: Powder Coat quality Reply with quote
Has anybody else on the list seen this type of quality on the powder-coated parts?
By the way, this is our solution to the axle spacer problem, without the flats yet. AN5-6A bolt through the axle nut too.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
 Filesize:  35.24 KB
 Viewed:  165 Time(s)
nandrand(at)xtra.co.nz
PostPosted: Sat Jan 13, 2007 11:43 pm    Post subject: Powder Coat quality Reply with quote
Hi. Looks as if the metal has not been prepared properly, should be dipped to remove grease,cutting fluid etc. Send it back, tell 'em to do it right.............
      Regards & Fly Safe Noel
