Albert Gardner
Posted: Sat Jan 13, 2007 9:14 am Post subject: Image Resizer Utility |
Microsoft has a Powertoy utility called ImageResizer which is available here
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx and
will resize picture file by about 90%. The file name is
ImageResizerPowertoySetup.exe and it is very useful not only for making
picture files smaller (i.e., a 698KB jpg was resized to 56KB) to send to the
list but also requires far less disk space for all those pictures we take of
out projects. It works well, is very fast, and the pictures look very good
after being compressed. All you do is select the picture file or files,
right click, select resize and in a few seconds you have a copy of the file
reduced in file while the original is not altered.
Albert Gardner
Yuma, AZ
| Description: |
 Download |
| Filename: |
winmail.dat |
| Filesize: |
4.22 KB |
| Downloaded: |
635 Time(s) |
_________________ RV-9A N872RV
RV-10 N991RV |
n8vim(at)arrl.net Guest
Posted: Sat Jan 13, 2007 9:36 am Post subject: Image Resizer Utility |
Microsoft.. Ick!
Actually, I use Linux most of the time (even at work - we find it much more reliable for our medical devices that are used in the O.R. - Would you want a blue screen to happen there? ).
There's a nice little tool to do the same thing, but gives you much more control over the process. for those so interested:
(Those who want to try Linux without installing anything, there's a complete CD that you can boot to and it will give you a full system without touching your hard drive. http://www.knopper.net/knoppix/index-en.html)
mogrify(1) mogrify(1)
NAME
mogrify - resize an image, blur, crop, despeckle, dither, draw on,
flip, join, re-sample, and much more. Mogrify overwrites the original
image file, whereas, convert(1) writes to a different image file.
SYNOPSIS
mogrify [options] input-file
OVERVIEW
The mogrify program is a member of the ImageMagick(1) suite of tools.
Use it to resize an image, blur, crop, despeckle, dither, draw on,
flip, join, re-sample, and much more. This tool is similiar to con-
vert(1) except the original image file is overwritten with any changes
you request.
For more information about the mogrify command, point your browser to
file:///usr/share/doc/ImageMagick-6.2.5/www/morify.html or
http://www.imagemagick.org/script/mogrify.php.
Run â to get a summary of the mogrify command options.
SEE-ALSO
ImageMagick(1)
COPYRIGHT
Copyright (C) 1999-2005 ImageMagick Studio LLC. Additional copyrights
and licenses apply to this software, see http://www.imagemag-
ick.org/script/license.php
ImageMagick Date: 2005/03/01 01:00:00 mogrify(1)
-Jim 40384
Albert Gardner wrote:
[quote] | Quote: | Microsoft has a Powertoy utility called ImageResizer which is available here
Albert Gardner
Yuma, AZ
| [b]
Posted: Sat Jan 13, 2007 10:15 am Post subject: Image Resizer Utility |
So, your suggestion is to reboot the computer to linux every time we want to resize a picture? J I agree that Linux can be great and is usually (OK, maybe always) more stable, but there is a good reason that some-very-high-percentage of computers in the world run Windows.
Kind of like the comparison between the Lancair and RV-10. The Lancair may be considered by many to be a better plane, but there is a reason (beyond just marketing) that the -10 has sold 700 kits in 3.5 years. Is there any other model of experimental that can boast this?
Do not archive.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein
Sent: Saturday, January 13, 2007 12:35 PM
Subject: Re: Image Resizer Utility
Microsoft.. Ick!
NAME
SYNOPSIS
OVERVIEW
you request.
[url=file:///\\usr\share\doc\ImageMagick-6.2.5\www\morify.html]file:///usr/share/doc/ImageMagick-6.2.5/www/morify.html[/url] or
SEE-ALSO
ImageMagick(1)
COPYRIGHT
-Jim 40384
| Quote: | | Microsoft has a Powertoy utility called ImageResizer which is available herehttp://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx andwill resize picture file by about 90%. The file name isImageResizerPowertoySetup.exe and it is very useful not only for makingpicture files smaller (i.e., a 698KB jpg was resized to 56KB) to send to thelist but also requires far less disk space for all those pictures we take ofout projects. It works well, is very fast, and the pictures look very goodafter being compressed. All you do is select the picture file or files,right click, select resize and in a few seconds you have a copy of the filereduced in file while the original is not altered.Albert GardnerYuma, AZ |
[quote] http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com [b]
Posted: Sat Jan 13, 2007 10:25 am Post subject: Image Resizer Utility |
Jesse,
No No No No! That is *NOT* what I said. I said *I* use Linux. There
may be others out there who want to try it, but why try it without a
purpose?
If we shouldn't share ideas, why even have this list?
Linux is not for everyone. Windows is not for everyone.
-Jim 40384 do not archive, do not flame, but do share your thoughts
Jesse Saint wrote:
| Quote: | So, your suggestion is to reboot the computer to linux every time we
Do not archive.
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
www.saintaviation.com <http://www.saintaviation.com>
Cell: 352-427-0285
Fax: 815-377-3694
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *James Hein
*Sent:* Saturday, January 13, 2007 12:35 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Image Resizer Utility
Microsoft.. Ick!
<http://www.knopper.net/knoppix/index-en.html>
mogrify(1)
mogrify(1)
NAME
draw on,
original
SYNOPSIS
OVERVIEW
of tools.
draw on,
to con-
changes
you request.
browser to
<file:///%5C%5Cusr%5Cshare%5Cdoc%5CImageMagick-6.2.5%5Cwww%5Cmorify.html>
or
SEE-ALSO
ImageMagick(1)
COPYRIGHT
copyrights
mogrify(1)
-Jim 40384
Albert Gardner
Yuma, AZ
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
Posted: Sat Jan 13, 2007 11:20 am Post subject: Image Resizer Utility |
Another option that I use is IRFAN. A very good piece of freeware for
photoediting and handling tasks. Seems to have very compact code with
lot's of function and little overhead. My default photo viewer. Just
Google it if you want to take a look.
Albert Gardner
Yuma, AZ
