Rivets
VE3LVO(at)rac.ca
PostPosted: Wed Jan 10, 2007 10:46 am    Post subject: Rivets Reply with quote
Cheers for 2007,
In my hunt for 3/32" rivets of various lengths, I found almost
everyone can provide 1/8" sorts but none smaller. The kit was issued with a
plastic bag marked TAPK 336 which infers 6/16ths long but they were in fact
5/16s at best.
The 3/32" units are the ideal for many an anchor nut and other small
tasks and are thus invaluable.
I contacted D and D Aircraft Supply at:
Sales: 1(800) 468-8000 (USA)
Phone: 1(603) 926-8881
Fax: 1(603) 926-7855
Email: info(at)ddaircraft.com
and the agent answering told me she had 3/32" aluminum countersunk pop
rivets from 3/16 to 1/2 inches long, by the pound [3000] of which the least
size is 1/8 lb. for about $4.
I thought you should know.
Ferg Kyle
Europa A064 914 Classic
n100rh(at)sbcglobal.net
PostPosted: Wed Jan 10, 2007 3:08 pm    Post subject: Rivets Reply with quote
Fergus,
Thanks very much for your post! I've been trying to rivet the anchor
nuts for the lower cowling and need much longer 3/32 rivets to do the job.
Thanks again!
Ralph
Reno,NV
Fergus Kyle wrote:
Cheers for 2007,
5/16s at best.
Ferg Kyle
h&jeuropa
PostPosted: Sun Jan 14, 2007 11:05 am    Post subject: Re: Rivets Reply with quote
I finally found some data on the T_P_ series of rivets at http://www.micometals.co.nz/PDF/fasteners/MICO_Rivets.pdf. This at least helps you try to find the same size and material rivets at the usual US suppliers. Unfortunately haven't found a data sheet for the No. 3 diameter.
I also learned that Aeroworks here in Michigan supplied hardware to Europa a few years ago and still has a lot of inventory. They have inventory of some of the rivets. Contact Dale Forton at 800-356-1671 or 616-527-1302. Their website is www.aeroworks.com.
Having said all this, I try to purchase as much as is feasible from E04, just to help ensure that they are still around in the future.
Jim Butcher A185, N241BW
