owl40188(at)yahoo.com Guest
Deems Davis
wvu(at)ameritel.net Guest
Posted: Mon Jan 15, 2007 11:12 am Post subject: Cabin Cover Aft Flange Fit |
Niko,
Not sure what you mean by "it opens up 1/8". I don't remember having such trouble. However, any time you have many mediums meet, such as on the sides where the cover meet the tailcone skin and side skins, it gets thick and takes a little time to get it right.
Anh
N591VU-6.5hrs
Posted: Mon Jan 15, 2007 1:05 pm Post subject: Cabin Cover Aft Flange Fit |
View it as the overlap between the Cabin Cover aft flange and the tailcone upper skin. Ideally this overlap should be about 0.70 inches all around (0.050 inch gap is assumed here) for me its about 0.65 inches on the top center and goes down to 0.30 inches as you move down the sides. I don't think it can be changed easily as the elevation angle of the Canopy Cover would have to change (angle of attack) which would shift this problem along the Cabin Side Flange to fuselage side skin attachment as the current fit there is great.
I hope this is clear.
Niko
