Question for Chris Wolf
rp3420(at)freescale.com
PostPosted: Tue Jan 09, 2007 12:52 pm    Post subject: Question for Chris Wolf Reply with quote
Chris,
You mentioned that you have not seen a picture of Dave. We have not
seen a picture of your best friend Mike. Can I talk you into posting
one on the list?
Tim Gherkins
FSII
www.milows.com
cwolf41(at)comcast.net
PostPosted: Tue Jan 09, 2007 7:35 pm    Post subject: Question for Chris Wolf Reply with quote
On Tue, 9 Jan 2007 13:52:13 -0700, you wrote:
Chris,
one on the list?
Tim Gherkins
FSII
www.milows.com
Can do. Excellent idea. Photo is attached.
Mike loved to fly more than anyone I've ever known.
After all the rough weather and rougher terrain he and I successfully
navigated over the last 36 years, I can't believe he died while doing touch
and goes in a plane equipped with a ballistic parachute under perfect
weather conditions at a local airport.
It's like hearing that Chuck Yeager slipped on a banana peel and was
killed.
Chris Wolf
 Filesize:  16.42 KB
 Viewed:  279 Time(s)
jimhefner
PostPosted: Wed Jan 10, 2007 8:27 am    Post subject: Re: Question for Chris Wolf Reply with quote
Chris,
Sorry about your loss! Thanks for posting the photo of Mike. Yes, it is very hard to understand how this accident happened under perfect conditions with 2 very experienced pilots. We may never know exactly what happened. I think this should be a lesson to all of us to always be on our guard, even in the most perfect conditions. The ballistic parachute probably could not have been deployed from such a low altitude since they were likely trying to fly the plane. There is a delayed reaction to realizing you need to pull the handle and they didn't have much time.
Here is a picture of Dave since you said you had not seen a picture of him.
Best of luck to you!
Jim
 Filesize:  98.79 KB
 Viewed:  260 Time(s)
Jim Hefner
Tucson, AZ
PostPosted: Wed Jan 10, 2007 8:57 am    Post subject: Question for Chris Wolf Reply with quote
| Jim
Jim:
The ballistic parachute handle can be pulled at any time prior to
impact. Never give up until you are finished crashing.
I have one save at 250 feet AGL and another at 500 feet AGL with a Jim
Handbury hand deployed parachute. The BRS deploys much faster than my
hand tossed model did.
PS: One of my favorite photos of Arizona Dave. Thanks.
PostPosted: Wed Jan 10, 2007 12:59 pm    Post subject: Question for Chris Wolf Reply with quote
On Wed, 10 Jan 2007 08:27:55 -0800, you wrote:
Chris,
I think you're probably right. Apparently the accident happened only a few
hundred feet up. By the time they realized they were in real trouble, they
were probably striking the ground. The only way to hope to save yourself
in such a situation is to pull the handle the moment the plane even
threatens to go out of control, and that's not really practical under
normal piloting conditions. You'd be pulling the handle every time you hit
turbulence, or a thermal.
Mike and I flew a powered parachute (PPC) for six years before deciding to
get a Kolb. As an old skydiver whose life was saved twice by my reserve
parachute, I'm a firm believer in backup parachutes. When we got our PPC,
I insisted on putting a ballistic parachute on it. I think it was the only
PPC in the world equipped with a ballistic parachute. Most PPC pilots
think they don't need a ballistic parachute, since they already have a
parachute wing over their heads. Which is something I completely disagree
with. Any flying machine can fall out of the sky, and can benefit from a
backup parachute.
Whenever Mike and I flew our PPC, the guy on the ground would watch the
PPC's wing from the moment of takeoff, until the machine reached an
altitude of one thousand feet. That way, if anything went seriously wrong,
the guy on the ground would see it before the pilot, and could radio a
warning to the pilot to immediately fire the ballistic parachute. We never
even came close to using the ballistic parachute, but both Mike and I were
always ready to use it at a moment's notice. When Mike called me from
Arizona, on Sunday night, to tell me that Dave's plane was equipped with a
ballistic parachute, I was delighted.
I've often wondered if I had been there, on Monday morning, while Mike and
Dave were flying, and had been watching the plane take off, if I might have
had time to radio a warning to them if I saw the plane going out of
control, in time for them to fire the rocket.
Probably not. By the time of the accident they would have been flying for
several hours, and I probably would have been off somewhere, getting myself
a cup of coffee. And even if I was there, watching them take off, by the
time I realized they were definitely in trouble, it probably would have
been too late for the ballistic parachute to do any good.
Still, I'll always wonder. Was I not there for my buddy when he needed me?
Would my presence have made a difference? These are the questions that
still haunt me.
Thanks very much, Jim.
Chris Wolf
jimhefner
PostPosted: Wed Jan 10, 2007 10:37 pm    Post subject: Re: Question for Chris Wolf Reply with quote
John, I agree BRS's and other chutes can and have saved lives at very low altitudes. I also suspect that when there is one person on-board, like in your situations, the decision making is more clear and immediate than when there are two on-board... therefore at low altitude I suspect it is less likely a chute will be deployed in time due to continued attempts to right the situation, confusion, panic, etc. Just a theory... could be wrong. Everyone flying with chutes should make sure they remove the safety pin before going up since that is not something you want to try to do when in an emergency situation.
Jim Hefner
Tucson, AZ
