ICOM push to talk switch
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
dale1rv6(at)comcast.net
PostPosted: Mon Jan 08, 2007 12:57 pm    Post subject: ICOM push to talk switch Reply with quote
Greetings,
Can anyone tell me how to make a PTT switch for my handheld?
I just bought an Icom A24. It came with a headset adapter. I tried to make a
simple push to talk switch. That did not work, may have bungled it up. I
thought all I needed was a 1/8 inch plug connected to a spring button switch
to close 2 wires. It appeared to work. Seemed like the outlet for the PTT
was defective because if I put a slight pressure on the plug it made a
noise. So I did exploratory surgery, could not tell if outlet for PTT was
bad, molded rubber design blocked view of details. But I did see 3 wires
(red, blue, white) going in and only expected 2. I amputated what was left
of PTT outlet. The female outlet for the mic is fine, and I have access to
those wires as the outlet is 2 piece closed with simple nut & bolt. Inside
are 3 wires; red, blue, white. Is it possible to wire up a PTT without too
much complexity?
Dale
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Float Flyr
PostPosted: Mon Jan 08, 2007 3:44 pm    Post subject: ICOM push to talk switch Reply with quote
All you need is the 1/8" jack that fits into the PTT ( push to talk input
jack) and a N.O. (Normally Open) momentary switch. Parts could be
relatively expensive.... maybe $4.00 at the local electronics shop so save
up. Wink There is no polarity to worry about. If you use a shielded wire you
can use the shield to the ring side of the jack and the centre conductor to
the tip of the jack.
I have that system with the same radio in my plane... Works like a charm.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
