dale1rv6(at)comcast.net Guest
Posted: Mon Jan 08, 2007 12:57 pm Post subject: ICOM push to talk switch |
Greetings,
Can anyone tell me how to make a PTT switch for my handheld?
I just bought an Icom A24. It came with a headset adapter. I tried to make a
simple push to talk switch. That did not work, may have bungled it up. I
thought all I needed was a 1/8 inch plug connected to a spring button switch
to close 2 wires. It appeared to work. Seemed like the outlet for the PTT
was defective because if I put a slight pressure on the plug it made a
noise. So I did exploratory surgery, could not tell if outlet for PTT was
bad, molded rubber design blocked view of details. But I did see 3 wires
(red, blue, white) going in and only expected 2. I amputated what was left
of PTT outlet. The female outlet for the mic is fine, and I have access to
those wires as the outlet is 2 piece closed with simple nut & bolt. Inside
are 3 wires; red, blue, white. Is it possible to wire up a PTT without too
much complexity?
Dale
Float Flyr
