O-540-J1A5D Engine Core
jim(at)CombsFive.Com
PostPosted: Tue Jan 31, 2006 4:07 pm    Post subject: O-540-J1A5D Engine Core Reply with quote
I had pursued several contacts for an engine and ended up with both an IO-540-C4B5 (1100 Hours) and a O-540-J1A5D core.
I am looking to sell the O-540-J1A5D core. If there is anyone interested, please contact me off list. I am located in Lexington, Ky.
Thanks, Jim Combs
N312F
40192 - Fuselage
sam.marlow(at)adelphia.ne
PostPosted: Wed Feb 01, 2006 8:49 am    Post subject: O-540-J1A5D Engine Core Reply with quote
Hey Jim, what did the J1A5D come out of?
Thanks, Jim Combs
N312F
40192 - Fuselage
dav1111(at)cox.net
PostPosted: Wed Feb 01, 2006 2:32 pm    Post subject: O-540-J1A5D Engine Core Reply with quote
It came out of a Maule. I helped the owner of the engine sell it to Jim.
Russ Daves
PostPosted: Wed Feb 01, 2006 2:45 pm    Post subject: O-540-J1A5D Engine Core Reply with quote
Does it have a govoner pad on the nose case?
Russ Daves
PostPosted: Wed Feb 01, 2006 3:10 pm    Post subject: O-540-J1A5D Engine Core Reply with quote
Yes, and there is a prop governor attached. I don't know what type governor it is. It looks different than the one on the C4B5. I will check tomorrow.
I am hoping that any prop governor will work with any hydralic prop? This is all new to me.
Comparing the two engines from an external point of view the only difference appears to be the accessory case on the rear. The same parts are there, but located in slighty different areas of the accessory case.
Thanks, Jim C
Date: 2006/02/01 Wed PM 05:44:00 EST
CC: Russell Daves <dav1111(at)cox.net>
Subject: Re: O-540-J1A5D Engine Core
Russ Daves
