Eric Tingey
Joined: 31 Dec 2006 Posts: 4 Location: Windsor Ontario, Canada
Posted: Fri Jan 05, 2007 4:04 pm Post subject: Canopy Fitting |
Group,
I put together a report on the method I developed to fit the Canopy to my CH601 HDS. Not sure how others have done it, but I've heard it is a bit of a trial and error process, this will eliminate that.
Thanks to Dino Bortolin, for his editing of the report.
Eric Tingey
CH601 HDS / Corvair
| Description: |
 Download |
| Filename: |
Canopyfitting[2].pdf |
| Filesize: |
144.21 KB |
| Downloaded: |
479 Time(s) |
601zv(at)ritternet.com Guest
Posted: Fri Jan 05, 2007 4:33 pm Post subject: Canopy Fitting |
I'm printing it out now. Thanks for sharing!
Robin in AR
N601ZV reserved
Do not archive.
Posted: Fri Jan 05, 2007 5:37 pm Post subject: Canopy Fitting |
Congratulations Eric,
You've done in one piece what a lot of people have tried to explain a
good number of times with little success.
It's certainly not in the guidance provided by ZAC. I'd recommend you
forward this to Zenith to help them out.
Well done!
Larry McFarland
Eric Tingey wrote:
Group,
Eric Tingey
CH601 HDS / Corvair
