Lubricating master cylinder components for assembly
CJohnston(at)popsound.com
PostPosted: Fri Dec 29, 2006 1:11 pm    Post subject: Lubricating master cylinder components for assembly Reply with quote
hey all -
am i correct in assuming that i can use automotive ATF as an "assembly lube" for assembling the Matco master cylinders? i'm planning on using MIL-PRF-83282 fluid for the brake system instead of the standard MIL-H-5606G (keepin the brake fires at bay!) but fer now, i just need to re-assemble the master cylinders after i powdercoated them, and i need some lube! what say you all?
thanks
cj
#40410
fuse
www.perfectlygoodairplane.net
