orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu Dec 14, 2006 1:25 pm Post subject: Work Table Size |
In the past there have been many topics discussing the minimum size to build a 10 but I have not seen any discussion as to work tables. Tim’s site talks about using an 8 foot and a 4 foot table but no reference to depth. The pictures look like his were not 48”. I suspect 24” or 32”.
I hope to be doing my inventory on the Emp kit next weekend and I am trying to get the work area ready. I already have a 4 x 8 table for general work but for the construction, it looks like most people are using much less then 48” of depth. A shallower table allows easier working from both sides.
If I go with a 4 ft and 8 ft table, can I get by with a 24” depth or do I need 32” or even wider?
I am also considering adding a cutout in the 4 foot table for a 'Hand Riveting and Dimpling Tool' that I can drop in when needed that will allow the aluminum being worked on to rest on the table at the tools work height. Are others finding this arangement useful?
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Rick S.
Posted: Thu Dec 14, 2006 1:50 pm Post subject: Work Table Size |
Gary,
I built two of these and they have been perfect. Add wheels to the bottom with at least two lockable wheels. It can be one long table like for wings or and "L" or square shape. They are super strudy and easy to build.
Heres the link to EAA chapter 1000 workbenches:
http://www.eaa1000.av.org/technicl/worktabl/worktabl.htm
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
kearney(at)shaw.ca Guest
Posted: Thu Dec 14, 2006 2:07 pm Post subject: Work Table Size |
Gary
I built 2 EAA regulation tables per the plans located at : http://www.eaa1000.av.org/technicl/worktabl/tablefig.htm
FWIW, I very much like these tables. They are easy to build and very nice to work on. When I need to, I can put them back to back or end to end. The depth is perfect for the tail kit. As you mentioned, access to either side without reaching is a big plus.
I did deviate from tbe EAA plans in two respects. First, I cut the legs down so I could put on fully castoring wheels (two of them with locks). As I am in a fairly small space, this is a big plus. I also used MDF for the table top and shelf. It is soft, forgiving and smooth. It doesn't trap burrs etc to scratch skins.
Another trick was to put a soft foam mesh mat (used to line drawers etc) on the table tops. The mesh holds work in place and also helps prevent dents from moving pieces around on the table. The mesh also allows burrs etc to fall into the mesh and away from the skins. Periodically I just shake the mesh out on the floor.
A couple of days ago I also built two 18" by 36" tables (also on wheels) upon which I mounted my power tools (bandsaw, vise and grinder on one and drill press and belt sander on another). As these are easily movable, they will likely be quite handy.
Anyway, based on my experience, you can't go wrong with the EAA tables.
Cheers
Les Kearney
RV10 - # 40643 Lost in the empennage
owl40188(at)yahoo.com Guest
Posted: Thu Dec 14, 2006 2:12 pm Post subject: Work Table Size |
Hi orchidman
Welcome the the RV10 building world.
I have used two 8ft by 2 ft tables. Built similarly to those in the EAA site. They worked great. A 32 inch table should work great also but I wouldn't go any wider than that. I used a 2ft depth because I slit a 4x8 plywood sheet in the middle for the two table tops. A more important item might be table height. You don't want to have to bend down for a long period of time while working on your kit.
Happy building
Niko
40188
orchidman
Posted: Thu Dec 14, 2006 2:17 pm Post subject: Re: Work Table Size |
Rick S. wrote: | Gary,
Rick S.
40185 |
Rick,
Your link followed to the plans only shows the 24" deep tables, while the link on Tim's page also shows 24 and 32" deep tables. I can build either but 24" would work better for me if that is sufficient for building the Emp and most of the long work on the wings.
Were your tables 24" on the narrow side? Lengths seem to be commonly mentioned but people forget to mention the narrow dimention.
RV10 - # 40674
(N2GB Flying) |
orchidman
sstella(at)incisaledge.co Guest
Posted: Thu Dec 14, 2006 2:50 pm Post subject: Work Table Size |
Gary,
I just finished my workshop which is in a two car garage and I put two workbenches, one was 10x3x38" high(this is my main bench) and I also have a 8x3x38" high(I have a belt sander, vise and grinder on this). This seems to be sufficient. I didn't go with 4' wide because both benches are up against a wall and it seemed a stretch to reach across. If your bench will be in the middle of the floor and you have access to both sides then 4' wide should be good.
LarryRosen
Posted: Thu Dec 14, 2006 2:54 pm Post subject: Work Table Size |
I used a solid core door for the top of my bench (I have 2) so it is 30"
deep. I modified the eaa plans to accommodate the door depth. I did
leave about 1/2" lip around the perimeter. If I were to do it again I
would leave at least 1". It would make it easier to clamp to. Since
the door top is heavy I have yet to fasten it to the to the leg
structure. This allows me to slide the door around to make a larger
lip. It also gets slid to the side so my dimpler can sit on the support
structure and the door top is about flat with the dimple.
photos are here
<http://lrosen.nerv10.com/Construct/tools/Workshop/index.html>
Larry
#356
orchidman wrote:
Quote: |
Rick S. wrote:
> Gary,
> Rick S.
> 40185
Rick,
Gary Blankenbiller
RV10 - # 40674
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=81587#81587
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Jon Reining
Posted: Thu Dec 14, 2006 3:35 pm Post subject: Re: Work Table Size |
I made my table out of all the materials that they used to crate the empennage kit, with the exception of the legs which I just pulled out some scrap 4x4. I doubled up the plywood, ripped the 1x material into stiffeners, and added a shelf. The best part for me is the the 1x4 stiffener that says "High Dollar Aircraft Parts - This Side Up" upside down. Having a high table really helps. Routering in a place for the steel plate for back riveting also works well for us.
What I'm envious of: a buddy who does custom steel and metal fabrication work (also a pilot) has a 4x4 steel table with a hydraulic lift to raise and lower his work to the most comfortable height. I think something like that would really be the cat's meow.
Jon Reining
41514 (with my dad Bill - and occasional emotional support from my wife Christy - who also reads the list emails)
Tailcone - interrupted - while house is being remodeled and parents are moving
Tim(at)MyRV10.com Guest
Posted: Thu Dec 14, 2006 4:43 pm Post subject: Work Table Size |
Yes, you can blame me. I took those plans and did some calculations to
efficiently allow them to be built either to 24" or 32". In my case,
I'm glad I had 32", but it really is just a personal preference. I had
no problem laying a wing on it, and since I didn't solid-mount my
C-Frame dimpler, I found the width to be a great help. In addition, you
end up getting lots and lots of supplies on the table sometimes, and
having the extra width can be a good thing. 32" was not at all too
wide to work comfortably on both sides of RV-10 parts.
That said, if you're space limited, or prefer skinny tables, then 24"
might be just the ticket. It's just personal preference.
Some people liked theirs moveable with rollers. I preferred mine to
be super solid heavy and unyielding. I really is no big deal either
way, and often could be dependent on the rest of your shop. If I had
unlimited space, I'd have had a couple more of the ones Like I have,
and scattered them around a bit. One thing for sure, when you get
yourself a good sturdy set of tables, you'll find building to go
smoother. Also, it was handy having a top that you didn't mind drilling
into, or painting.
One other thing I found infinitely helpful was an overhead pipe system
with air outlets every few feet, and a few 5 to 10' air hoses. It's
nice sometimes to just have a little piece of hose hanging down so
it isn't in the way while you drill, and really beats tripping over
a 25' hose on the ground.
So yep, I confused the issue by giving 2 options for the standard
EAA Plans. Sucks to have options, doesn't it.
> table tops. A more important item might be table height.� You
> Niko 40188-
Thanks, It looks like my problems are because of Tim! Can I blame
him
The plans he has on his site show both 24" and 32" and this is what I
was questioning. Which is best for the 10. Eveyone that has replied
so far has referenced the plans from what looks like the same group
of people but only has the 24" size. No reference to 32" wide. It is
looking like 24" is winning. This is what I needed to know so I can
build them this weekend.
-------- Gary Blankenbiller RV10 - # 40674 (N410GB reserved) do not
archive
http://forums.matronics.com/viewtopic.php?p=81590#81590
EFDsteve(at)aol.com Guest
Posted: Thu Dec 14, 2006 5:54 pm Post subject: Work Table Size |
I built the 24 inch wide EAA tables, but for the top, I made it 2" wider all around, and that has worked really well for clamping things to the table. Another consideration is that may have to move these through doors at some point, like I did when I moved about a year and a half ago. If my table had been any wider than 28", I would have had a very hard time moving it from one house to the other.
Steve Weinstock
40230
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
into, or painting.
orchidman wrote:
Quote: | --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com>
> Niko 40188-
him
archive
orchidman
Posted: Thu Dec 14, 2006 6:32 pm Post subject: Re: Work Table Size |
Tim(at)MyRV10.com wrote: | Yes, you can blame me. I took those plans and did some calculations to
It sure does
Isn't life great!
So it sounds like 24" will work but if you can go 4" to 8" wider is even better.
RV10 - # 40674
(N2GB Flying) |
Posted: Thu Dec 14, 2006 7:56 pm Post subject: Work Table Size |
The EAA tables are great - I did 3 of them. I thought hard about more
than 24 inches but the 24 really is right. I second the MDF - makes a
great surface. The only reason why you might want to go a few inches
wider or longer is to get an edge you can clamp to. However, I find the
bar clamps to be very effective in clamping to to the 2X4 that holds the
top. Bigger seems better but not necessarily in this case. 2 is better
than 1 and 3 better than 2.
The only variation on the tables I did was to leave off the doublers on
the bottom of the legs. You certainly don't need it for strength and
leaving it off makes it a little lighter and may make it a little easier
to slide on the floor - if you don't use wheels.
Remember to use glue for a solid table.
k5wiv(at)amsat.org Guest
Posted: Fri Dec 15, 2006 4:06 pm Post subject: Work Table Size |
I haven't started building the airplane yet, but have built 2 of the EAA
tables per plans except that I added masonite over the top. I'm finding
them very useful already and have 3' by 4' top and shelf pieces left over.
I'm going to get some more 2x4s for the framing and build 2 2' x 3' tool
stands. I may shorten the legs enough to add casters and still have the
same height as the 5'x2's. And when the airplane construction starts I may
build a couple more then by clamping tables together a great variety of
sizes and shapes can be accomplished.
Jack & Cecilia Sargeant
1127 Patricia St.
Wichita, KS 67208-2642
316/683-5268
Posted: Wed Dec 27, 2006 9:39 am Post subject: Work Table Size |
Hi Tim!
Little question to make my mind need to work less..
you wrote:
One other thing I found infinitely helpful was an overhead pipe system with
air outlets every few feet, and a few 5 to 10' air hoses. It's nice
sometimes to just have a little piece of hose hanging down so it isn't in
Been thinking of doing this myself and wonder what size copper piping did
you use?.. I gather it was 1/4 with 90degree elbows.. if you can fill give
me, I can continue that engineering piece for the start in 2007.
I am in the exact same situation you were in 2/3 years ago. 3 year old and
building up funds to get started. Looking at mid year 2007 if all goes well
between now and than at work, I'm anxious to start but in no rush.
Merry Christmas and wishes for a great 2007.
Pascal
PS: Disneyland offer for a place for your family to stay stands for 2007
lest you forget the offer.
Pascal
LarryRosen
Posted: Wed Dec 27, 2006 1:54 pm Post subject: Work Table Size |
I used 1/2" copper pipe. I plumbed 3 stations. One near the compressor
and the other two on the far side of the garage.
Larry
#356
Pascal wrote:
Hi Tim!
nice sometimes to just have a little piece of hose hanging down so it
did you use?.. I gather it was 1/4 with 90degree elbows.. if you can
fill give me, I can continue that engineering piece for the start in
2007.
and building up funds to get started. Looking at mid year 2007 if all
goes well between now and than at work, I'm anxious to start but in no
rush.
Pascal
2007 lest you forget the offer.
Pascal
#40356
N205EN (reserved)
<http> |
Posted: Wed Dec 27, 2006 5:11 pm Post subject: Work Table Size |
Hi Pascal,
I used 1/2" galvanized pipe, but I think 1/2" copper would be
better unless you can put lots of moisture separation in front
of it. Just make sure the copper is good for about 150psi
and that would be great. It really is nice having a couple
of runs down the ceiling so you can work on either side of the airplane.
I put one down each side of the workbench, but should have put one down
the other side of the garage too. It's pretty cheap to do. The pipe
isn't a big cost. Just the coupler fittings.
It'll be great to hear how things go as you get started with it all.
Pascal wrote:
Hi Tim!
fill give me, I can continue that engineering piece for the start in 2007.
rush.
Pascal
Pascal
nick(at)nickomalley.co.uk Guest
rvbuilder(at)sausen.net Guest
Posted: Thu Dec 28, 2006 6:20 am Post subject: Work Table Size |
I'm curious. Is there a reason that everyone is using copper and other metal pipe for their air runs? Good ole SCH 40 PVC from just about any hardware store is rated for several times the PSI you will ever see from your compressor. Use half inch PVC and you will be done in half the time at a fraction of the cost.
Michael
jesse(at)itecusa.org Guest
Posted: Thu Dec 28, 2006 6:58 am Post subject: Work Table Size |
Amen!
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
