MPPalmer(at)aol.com Guest
Posted: Fri Dec 29, 2006 9:50 am Post subject: Glasair-List Digest: 1 Msgs - 12/28/06 |
I'd like to know about the new front gear fairing. For the FT, correct?
Is it like the RV pressure recovery fairings? I picked up a couple knots switching to those on the main gear.
Any speed increase for the nose gear?
Mike Palmer <>< [quote][b]
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Craymondw(at)aol.com Guest
Posted: Fri Dec 29, 2006 9:59 am Post subject: Glasair-List Digest: 1 Msgs - 12/28/06 |
The fastest Glasair fixed trike I know uses a McCauley prop and uses his right front engine baffle for his air intake. Installing an engine plentum increases speed. The engine front air inlets can be closed up. Get rid of any "Y's" areas around the landing gear. Ken Johnson noted a buffeting on the front of his engine cowling and reworked his cowling. Stoddard Hamilton also noted a buffeting on the leading edge of the wing. A Swiss builder found that by putting an eight inch long fence on the fuselage in front of the leading edge of the wing increased his speed. A Stoddard Hamilton designer wanted to use a fairing similar to the Spit Fire design on the trailing edge of the wing. Stoddard Hamilton increased the airspeed of the Gl111 by removing the lower belly panel that is found on the two's. Airflow Performance in Spartanburg, SC produces a fuel injector system that adds power to the engine. I use their injector nozzles and noticed a 6 mile per hour increase. Use wool tufts tapped around the fuselage to see air flow. Lastly, use your skins as a mold and reproduce the plane out of carbon fiber. You can get rid of several hundred pounds doing that. And you can offer carbon fiber skins as an after market. Speed freaks that have been hopelessly waiting for Glasair to do all these modifications and produce a faster Glasair would jump at the opportunity. Phoenix Composites in Arizona are the leaders in Glasair modifications. I am surprised that they haven't jumped at the opportunity to offer a highly modified Glasir carbon fiber kit.
