eskflyer(at)lvcisp.com Guest
Posted: Thu Dec 28, 2006 6:39 pm Post subject: wing tank model 2-3 |
I am looking for a wingtank for the Model 2 -3 , 13.5 gallon needs to
be a left tank .
Wahoo supposed to snow this weekend will be fun on skis for some of us .
John Perry
Float Flyr
Posted: Thu Dec 28, 2006 7:19 pm Post subject: wing tank model 2-3 |
John:
My plane has a 6 Gal U.S. tank on the left side and a 13.5 Gal. U.S. on the
right. I was wondering if you can think of a good reason for this
configuration....
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
runwayrex(at)juno.com Guest
Posted: Thu Dec 28, 2006 7:43 pm Post subject: wing tank model 2-3 |
When I bought my model 3 kit in 1990, I did all the option paperwork with Dan Denney at Oshkosh. He recommended I go with 6 gallons on my side and 13 on the right because we often fly solo and the extra fuel on the right side helps to balance things out. A couple months into the project, I sent the six gallon tank back and replaced it with another 13. I'm glad I did. I've never noticed an imbalance when flying solo.
Rex in Michigan
-- "Noel Loveys" <noelloveys(at)yahoo.ca> wrote:
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
John:
configuration....
Noel
[quote] --
Posted: Thu Dec 28, 2006 7:46 pm Post subject: wing tank model 2-3 |
Noel
My only guess is builder did not want more weight ?. I have the 10 gallon
front tank and 13.5 gallon right tank and would really like a left tank also
for those LONNNNNG flight days when i want to go far and fuel is not
available .
Fly safe
John Perry
Float Flyr
Posted: Thu Dec 28, 2006 8:58 pm Post subject: wing tank model 2-3 |
What I have is the 6 and the 13.5 with a header of 2 Gal. ( all U.S.) I've
had flights of 3 hr with a good half hr. of reserve but at the low speeds of
these planes that's not a lot of range. I generally carry another 12 gal in
the right float if I'm going any distance. 3 Gal U.S. Jerry cans are great
for that.
Noel
[quote] --
Kitfox III-A
lcfitt(at)sbcglobal.net Guest
Posted: Fri Dec 29, 2006 7:34 am Post subject: wing tank model 2-3 |
Noel,
In the early days of small instrument panel and panel tank kitfoxes, the
wing tanks were available options. The tanks were in two sizes as you
mention. My guess is that with the light weights of the early airplanes, it
was considered wise to put the large tank on the mostly empty passenger seat
side and the small tank on the pilot side for lateral ballance.
Lowell
dave
Posted: Fri Dec 29, 2006 7:47 am Post subject: wing tank model 2-3 |
Lowell,
What do you think of a tank that could be mounted behind the seat ?
Custon made of course but you could get I would guess 5 to 10 gal capacity
there.
I have taken may times 3 of the 2 imp container there. so an extra 30
litres or so.
My Baggage sack is tie wrapped in with eyelets in the canvas not velcro-ed
like some.
I have thought of making a new baggage compartment that is solid with a side
door and might do this winter.
My floats are handy for extra fuel cans as well.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Fri Dec 29, 2006 1:20 pm Post subject: wing tank model 2-3 |
Dave,
Sounds like a doable idea. I have an aluminum header tank a bit larger than
the original supplied in the kit. It is mounted aft of the baggage sack and
does affect CG more than if mounted directly behind the seat as the newer
header tanks are. It seems to me that it would be much easier to put fuel
there for extended range than in the wing which would require some serious
fabric work. It seems to me that it could work as an enlarged header tank.
Lowell N96KL
roncarolnikko(at)hotmail. Guest
Posted: Fri Dec 29, 2006 5:23 pm Post subject: wing tank model 2-3 |
The weights and balance might be a challenge, but I saw a rear mounted tank
at Arlington this year. I'll try to attach a picture or three. Ron NB Ore
[quote]From: "dave" <dave(at)cfisher.com>
Subject: Re: wing tank model 2-3
Date: Fri, 29 Dec 2006 10:47:06 -0500
Lowell,
there.
litres or so.
like some.
side door and might do this winter.
Dave
43.03 KB |
319 Time(s) |
38.41 KB |
322 Time(s) |
40.9 KB |
337 Time(s) |
dave
Posted: Sat Dec 30, 2006 5:29 am Post subject: wing tank model 2-3 |
Ron, Thanks for those pics of the rear tank.
Looks like a fair size.
I have a dash tank and 2 6 gal tanks in wings. When on floats I am
restricted to about 3.5 hours and a bit.
I can take gas in floats but an extra 5 to 10 gals behind seat would extend
me 1 to 2 hours . So i can fly in 3 hours and still have enough for return
without refueling.
Dave
