cj.tremblay(at)videotron. Guest
Posted: Sun Dec 24, 2006 8:01 am Post subject: Torque force to apply to AN Bolts |
Hi guys,
I want to know if somebody have a short chart list of torque force to apply to Steel Cadium plate bolt : AN3, AN4, AN5 and AN6 for general purpose. Thanks again.
Merry Christmas and Happy new Year to all builders.
Christian Tremblay
A guy who build a CH640 aircraft from plan
http://www.zodiac640.com/
2.68 KB |
2329 Time(s) |
heatonhe36(at)msn.com Guest
Posted: Sun Dec 24, 2006 8:40 am Post subject: Torque force to apply to AN Bolts |
Christian,
Try this link and open chapter 07.pdf. Everything you ever wanted to know
about bolts and more.
Or do a search of AC 43.13-1B
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument
Merry Christmas every one.
Herb
| Quote: | From: Christian Tremblay <cj.tremblay(at)videotron.ca>
Reply-To: zenith-list(at)matronics.com
Subject: Torque force to apply to AN Bolts
Date: Sun, 24 Dec 2006 11:00:31 -0500
Hi guys,
Thanks again.
Christian Tremblay
<< image001.jpg >>
Jaybannist(at)cs.com Guest
Posted: Sun Dec 24, 2006 8:45 am Post subject: Torque force to apply to AN Bolts |
Christian,
I got these values from Caleb at ZAC:
A3 - 20-25 in-lb
A4 - 50-70 in-lb
A5 - 100-140 in-lb
A6 - 150-190 in-lb
Merry Christmas! - Jay in Dallas
Christian Tremblay <cj.tremblay(at)videotron.ca> wrote:
Hi guys,
Thanks again.
Christian Tremblay
JohnDRead(at)aol.com Guest
Posted: Sun Dec 24, 2006 6:37 pm Post subject: Torque force to apply to AN Bolts |
How much additional torque is needed for the self locking fasteners?
John Read
CH701 in Colorado
Posted: Sun Dec 24, 2006 7:49 pm Post subject: Torque force to apply to AN Bolts |
John, I relayed the torque values I got from ZAC to the list. It is my understanding that the high end of the range is sufficient for the nylock nuts. After tightening a few of the AN-3 nuts with a torque wrench, I was surprised at how little force is needed. Certainly less that I would have applied just by "feel."
Jay in Dallas
JohnDRead(at)aol.com wrote:
| Quote: | How much additional torque is needed for the self locking fasteners?
John Read
CH701 in Colorado
Float Flyr
Posted: Mon Dec 25, 2006 3:32 pm Post subject: Torque force to apply to AN Bolts |
You use a special torque wrench called a torque meter to find the resistance to the locking nuts. When this resistance is added to the required torque value you have "Friction Torque". Friction torque should only be used when it is required and should always be noted... after all it is a little different.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Mon Dec 25, 2006 3:35 pm Post subject: Torque force to apply to AN Bolts |
This is not strange. Most of us get used to tightening up nuts and bolts on
out old jalopys (yeah right!) but the ANC mil spec nuts and bolts are
considerably finer pitch thread. That is why they require inch pounds
instead of foot pounds of torque.
Noel
[quote] --
Kitfox III-A
Posted: Tue Dec 26, 2006 5:54 pm Post subject: Torque force to apply to AN Bolts |
Hi Jay:
Thanks for the reply. I used the high end of the torque values. I could not measure the drag torque with anything I had.
Regards, John Read
Posted: Tue Dec 26, 2006 6:32 pm Post subject: Torque force to apply to AN Bolts |
John'
Your welcome. I wanted to share this information, because I found it so hard to come by. I first looked in the DOT/FAA manual for torque values, but unless you know the tensile strength of the bolts, you just can't determine what torque to apply. That is why I went to ZAC for the values. Nick just gave me the run-around, so I asked Caleb, directly. As usual, he came through with a succinct answer.
Jay
| Quote: | Hi Jay:
Regards, John Read
