PFolbrecht(at)starkinvest Guest
Posted: Mon Jan 30, 2006 11:08 am Post subject: Gaps in HS rib-to-front-spar joint |
I hate to have to post this.
As the title says, I have a slight gap in two ribs - one on each side.
It is at least wide enough to get a piece of paper under. I have not
yet installed the rear spar so I could drill these out and re-rivet.
Something tells me that I really ought to. Is it something I would need
to worry about? Is it a strength issue?
Paul
Posted: Mon Jan 30, 2006 12:16 pm Post subject: Gaps in HS rib-to-front-spar joint |
To clarify, this is the front-flange of the main rib to front-spar joint
on a 9A HS.
Sent: Monday, January 30, 2006 1:06 PM
To: 'rv-list(at)matronics.com'
Subject: Gaps in HS rib-to-front-spar joint
Paul
chaztuna(at)adelphia.net Guest
Posted: Mon Jan 30, 2006 2:53 pm Post subject: Gaps in HS rib-to-front-spar joint |
Paul,
Only a sheet of paper? On my 8a HS and VS, the rib lengths were off so
badly, that I couldn't maintain edge distance on the front spar flanges.
(My kit was not matched hole remember) I had to cut the front flanges off
the affected ribs and make "scab" flanges to get everything to line up
correctly. It wasn't the only place this was necessary on my kit. It sounds
like your mis-alignment is slight however. If interested, I can email you
photos of how to modify a rib using the scab flange method.
Charlie Kuss
<PFolbrecht(at)starkinvestments.com>
Paul
Bob Perkinson
Joined: 10 Jan 2006 Posts: 51 Location: Hendersonville, Tennessee
Posted: Mon Jan 30, 2006 5:11 pm Post subject: Gaps in HS rib-to-front-spar joint |
If memory serves me the 2 inboard ribs are canted to the outside and require
the fabrication of .040 shims (HS-909) to fill the gap
Bob Perkinson
Hendersonville, TN.
RV9 N658RP Reserved
If nothing changes
Nothing changes
webmaster(at)flion.com Guest
Posted: Mon Jan 30, 2006 7:38 pm Post subject: Gaps in HS rib-to-front-spar joint |
Some of the other replies reference a fit problem but I read it that the
parts fit and that you had a small gap after riveting. If that's the case,
yes, you should drill them out and rivet again. Squeezing is the best
method there; I found that driven rivets tended to gap where the parts were
fairly flexible, unless I clamped near the hole, which made driving rivets
more difficult. Where those rib flanges are, there aren't enough clecos or
other structure to keep things from flexing and separating while you rivet.
This will be true on all remaining structure - wing ribs and fuselage
bulkheads.
The preceding refers to a gap at the rivet. It the gap is between rivets,
there is some fitment issue in the structure. I'd have a tech counselor
look at it and advise you.
Pat Kelley - RV-6A - Cabin floors in, working on passenger seat.
Posted: Tue Jan 31, 2006 5:49 am Post subject: Gaps in HS rib-to-front-spar joint |
Hi Paul-
Re: "I hate to have to post this. As the title says, I have a slight
gap... ...It is at least wide enough to get a piece of paper under. I have
not
| Quote: | yet installed the rear spar... ...Is it something I would need
to worry about? Is it a strength issue?"
Paul
If I understand your situation correctly, I would say that yes, those
should be re-done. I believe that structural members such as the ones in
question here should definitely be in full contact. I'd be concerned that
the rivets in question would loosen pretty quickly in service. In any
case, I'd also suggest that correcting the issue now will prevent sleepless
nights in the future.
I believe that the phenomena you have encountered here is generally caused
by not holding the bucking bar sufficiently tight to the rivet during
bucking. This allows the bucking bar to 'chatter' against the rivet, which
can cause the gap between the parts. You may wonder how I know this....
Glen Matejcek
aerobubba(at)earthlink.net
Posted: Tue Jan 31, 2006 7:28 am Post subject: Gaps in HS rib-to-front-spar joint |
It seems that I overstated the case. I posted from the office, without
the parts in sight, after having thought about this "gap" for several
hours. It turns out that there is full contact where the rivets are and
the gaps are only between rivets, for whatever reason. I probably
should have clamped to prevent this (I had clecos in two of the three
holes when riveting but no clamps) but I don't think it's a concern.
Come to think of it, if the rib had been offset any significant amount,
the skin-to-rib rivets would not likely have fit without redrilling, and
they did.
So, again, I'm afraid this was 90% my newbie-perfectionism and my
overactive imagination at work. I apologize for not looking at things
more carefully before posting.
Thanks.
Paul
