Fox5flyer Guest
Posted: Fri Jan 12, 2007 4:34 am Post subject: GSC prop |
Yes , GSC was told ands got pics.
said he never seen that before. > for what that is worth <
I think that is something they all say, but with our litigeous society these
days I can hardly blame them. Admitting any fault admits guilt and opens
the door to a law suit and it doesn't take many of those to put a company
out of business. Still, it gives them customer feedback so they can work on
improving the product.
I am not sure that this one was ever over torques Deke, you can see by the
pics http://www.cfisher.com/gsc/
that the alum. block have a "healthy gap" and I know that the owner is
very
| Quote: | aware and has built a close to 25 planes now .
I noticed it had a good gap and that is why I questioned the torque. The
pics are pretty good, but they aren't nearly as good as the naked eye and
what I saw was what appeared to be damage (rot) at the break visible by the
darker colored wood. That would easily be explained if the airplane spent a
lot of time outside in a wet enviornment. I had a GSC that I put about 400
hours on and I trusted it completely, but it was never allowed to soak up
any water. Near the root, just prior to where it goes into the hub, the
wood is a little rough and appears that it could absorb water if allowed to
soak in long/often enough. Inside the aluminum hub part of the blade root
is just bare wood so any rain entering the hub (through the hub halves)
would be absorbed, and being trapped in there it would be very difficult for
it to dry out.
I wasn't aware that they were using aluminum sleeves on the newer GSC blade
roots. Mine was a black plastic type stuff.
I would rule it out to age, moisture fatigue and just bad luck. Now if
it
| Quote: | was new well I would lean more on GSC.
That prop I think had over 300 or 400 hours on it and over 10 years for
sure.
Dave
Agreed. The GSC (IMO) is a good value for the money and performs well, but
it isn't an all-weather prop and takes some care. I wouldn't even think of
using one on an airplane that sits outside. That's where the carbon fiber
types excell as they're pretty much impervious to weather, but not
everything.
Fortunately for the pilot, it happened on the ground during taxi. That has
to be one maximum scare factor when it happens, especially while in flight.
I don't even like to think about it.
Thanks for sharing this with us.
Deke
FYI I would not condemn your GSC prop over this kinda stuff but I would
certainly make sure that you keep an eye on the condition, time of service
in years as well as hours running time . I think GSC says 500 hours or 5
years ? Over all GSC props do work well I find. Those videos I did in
snow and short take offs and deadsticking in the last month was all on a
GSC.
A few more below,
Here is another GSC problem
http://www.ultralightnews.com/safety_bulletins/gsc_servicebulletin.htm
another one ( good read )
http://www.auf.asn.au/airworthiness/gscbladeshed2.pdf
The problem covered in those issues related to failure of wooden blades at
the glue line adjacent
to the socket and possible crushing of the blade root from deterioration
or
| Quote: | over tightening of the
bolts resulting in degraded clamping of the blade. This was aggravated by
deterioration of the
wood from moisture.
A further (very well compiled) report of blade shedding has been received,
this time involving a
three bladed wooden GSC propeller fitted to a 912 powered Lightwing. The
owner was
experimenting with methods of improving engine power output and he had
achieved an RPM
increase from 5,600 to 5,800 RPM on climb. On levelling at 1,000ft, there
was an almighty bang
and the motor stopped immediately. The aircraft was landed safely and
subsequent inspection
revealed that all three blades had parted company with the hub.
dave
Posted: Fri Jan 12, 2007 5:27 am Post subject: GSC prop |
I will sum up your comments
--Plane has seen zero rain, dew -nothing but UV while flying and is
hanagared the other 100% of time.
condensation in spring / fall ? perhaps a bit in un heated hangar with
concrete floor. But wood has a moisture content and can soak up more from
atmosphere. I would assume there are a few weeks of 100% moisture every year
plus the humid days in summer.
Yes the owner is a long time builder and pilot , he is 84 and still flys
often. He is the second plane to take off in the coffee break movie clip
here http://www.cfisher.com/kitfox/ It is a Kitfox clone called a raven
which he scratch built 14 years ago and it stronger than ever now with
brand new 503 this past summer. He used to make allot props, but now he
says it easier to just buy one. And like you said the GSC are good value
ands a good performer. I have flown with them on floats too and a good
temporary fix it to cover the tips with urethane tap the last few inches on
the leading edge of tip. The tape will erode and it can be replaced. It
easier than fixing pitting with epoxy to those urethane leading edges.
I might have some more blades around the shop and If I do , I will get some
better shots.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
