deutscht(at)rhwhotels.com Guest
Posted: Wed Dec 20, 2006 8:36 am Post subject: Carpet Install |
Does anyone have any good ideas on how to fasten the carpet and still keep it removable? I planned to use Velcro but it doesn’t seem to stick to the carpet backing well enough.
Tom Deutsch, #40545
Rick S.
Posted: Wed Dec 20, 2006 8:49 am Post subject: Carpet Install |
Tom,
The velcro I have seen on the carpet had been sewn to the carpet. Hot glue may be a good option though, similar to the seaming tape used on carpet.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
jesse(at)itecusa.org Guest
Posted: Wed Dec 20, 2006 9:13 am Post subject: Carpet Install |
Using some kind of contact cement between the carpet and the Velcro seems to be the best way we have found. You mainly just don’t want it sliding around.
Hope this helps.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Deutsch
Sent: Wednesday, December 20, 2006 11:36 AM
Subject: Carpet Install
Tom Deutsch, #40545
[quote] [b]
kearney(at)shaw.ca Guest
Posted: Wed Dec 20, 2006 10:23 am Post subject: Carpet Install |
Hmmm
Is there a fire issue here? Contact cement, IIRC is quite flammable. Is there a better way?
Cheers
Les Kearney
RV10 #40643 – Lost in the empennage
Tim(at)MyRV10.com Guest
Posted: Wed Dec 20, 2006 10:52 am Post subject: Carpet Install |
For those using Abby's carpet at Flightline, to ease your mind,
velcro holds her carpet in well, so you won't have to worry
about this too much.
Les Kearney wrote:
[quote] Hmmm
there a better way?
Cheers
Les Kearney
Posted: Wed Dec 20, 2006 12:32 pm Post subject: Carpet Install |
Tim
Does Abby offer a partial carpet kit or is it all or nothing. Thinking
about painting much of the interior and only carpeting on areas where knees
and elbows touch.
JOhn G
[quote]From: Tim Olson <Tim(at)MyRV10.com>
Reply-To: rv10-list(at)matronics.com
Subject: Re: Carpet Install
Date: Wed, 20 Dec 2006 12:51:47 -0600
Les Kearney wrote:
>Hmmm
>there a better way?
>Cheers
>Les Kearney
wvu(at)ameritel.net Guest
Posted: Wed Dec 20, 2006 6:38 pm Post subject: Carpet Install |
I used snap buttons - 1/2 fastened to the floor pans before they were riveted in place, 1/2 fastened to the carpet. I may sew velcro on the carpet later if needed.
Anh
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Wed Dec 20, 2006 10:11 pm Post subject: Carpet Install |
No worries les,
The most dangerous time for contact cement is when it is still wet. As it dries and the volatiles outgas the glue becomes mostly inert. I’ve compared the contact cement supplied from airtex (which is used in certified installs) to commercially available “dap” type glue and upholstery cement we use for auto tops, and found they are almost identical. The dried cement “boogers “we burn tested did burn a bit under direct flame, but did not support combustion. In a comparison test all types performed the same.
In certified aircraft its common to use cardboard type upholstered panels with foam and a fabric or leather finish. I can tell you with some certainty that the board and foams burn vigorously and DO support a flame. But as long as the exposed surface has an approved burn spec it gets faa blessing or so it seems. I’d not worry about the adhesive as much as wisely choose the materials used in the install.
.02
Steve
40205
Hmmm
Cheers
Les Kearney
-- Release Date: 12/19/2006
12/19/2006
Posted: Thu Dec 21, 2006 3:13 am Post subject: Carpet Install |
I'm not sure. I'd bet it would be partial available, but that answer
would be something to get from her. I just got everything.
John Gonzalez wrote:
Tim
knees and elbows touch.
JOhn G
> Tim Olson - RV-10 N104CD - Flying
> do not archive
> Les Kearney wrote:
>> Hmmm
>> Cheers
>> Les Kearney
