601XL fuel vents
waj(at)quik.com
PostPosted: Tue Dec 19, 2006 5:27 pm    Post subject: 601XL fuel vents Reply with quote
Hello group ,I have searched the archives and found nothing pertaining to the fuel vents .I am plans building and am having problems determining where the vent line ties into the fuel tank .Could someone give some help in this area . Thanks, Wade
Ron Lendon
PostPosted: Tue Dec 19, 2006 6:59 pm    Post subject: Re: 601XL fuel vents Reply with quote
I just made them up the other day from the dimensions on 6-K-1. Final trimming, 40mm sticking out of the bottom was saved to last. I kept the pipe perpendicular along the tank to make setup easier.
I don't have the prints with me but if you have more questions, just ask.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
waj(at)quik.com
PostPosted: Tue Dec 19, 2006 7:43 pm    Post subject: 601XL fuel vents Reply with quote
Ron ,I have checked 6-K-1 and have all the dimensions ,however I must be
missing something .I do not know where it ties into the tank .I do not have
room to tie into the filler neck .Does it tie into the top of the end or
does it tie into the top of the tank ,does it tie into a welded fitting
somewhere . Wade
craig(at)craigandjean.com
PostPosted: Tue Dec 19, 2006 7:58 pm    Post subject: 601XL fuel vents Reply with quote
I believe it doesn't really tie in anywhere. The upper end of the pipe has a
slight bevel to it and tucks into the upper corner of the tank. The
cross-section view of the tank shows this (poorly). I suspect the vent tube
may be tack welded to the wall of the tank in that upper corner.
-- Craig
Ron Lendon
PostPosted: Tue Dec 19, 2006 9:36 pm    Post subject: Re: 601XL fuel vents Reply with quote
I have mine out being welded. I will talk to the guy and see if he will allow pictures of the process. Tacking it to the top of the tank is something I didn't think about but will mention it to the weldor.
Ron Lendon
CH 601 XLB
N601LT - Flying
Trainnut01(at)aol.com
PostPosted: Wed Dec 20, 2006 4:33 am    Post subject: 601XL fuel vents Reply with quote
Wade
I modified a pair of long range tanks from ZAC. Gave me a chance to look inside. The vent tube is not attached at the top at all. It is beveled on the top end and is positioned with the end about a 1/4 inch from the top outboard corner of the tank. My modified tanks did not work out real well so I made a new set with carbon fiber. I am attaching a photo of one of my new tanks during construction. You can kind of see the vent tube location. The CF tanks have tested well but aren't flying yet.
Carroll Jernigan
601XL
 Filesize:  11.39 KB
 Viewed:  625 Time(s)
waj(at)quik.com
PostPosted: Wed Dec 20, 2006 5:38 am    Post subject: 601XL fuel vents Reply with quote
Thanks Carroll ,I was misreading the prints ,I was not aware that the vent tube was internal . Thanks, Wade
waj(at)quik.com
PostPosted: Wed Dec 20, 2006 5:41 am    Post subject: 601XL fuel vents Reply with quote
Thanks Craig ,I now have a clear picture of what is needed . Thanks ,Wade
larry(at)macsmachine.com
PostPosted: Wed Dec 20, 2006 7:05 am    Post subject: 601XL fuel vents Reply with quote
Wade,
For the wing tanks, any high point in the tank will do. I put the vent
ends below the bottom wing surface by an inch. For the header tank, I
vented next to the incoming line near the top of the tank and routed a
tube to the right wing a few feet out and curved the tip hanging below
directly into the air stream to prevent siphoning and keep the fumes
from being close to the exhaust on the left side.
Larry McFarland - 601HDS at www.macsmachine.com
carlossa52(at)gmail.com
PostPosted: Wed Dec 20, 2006 8:06 am    Post subject: 601XL fuel vents Reply with quote
This is my experience making an -HD tank, but maybe you can use the idea.
I wrapped a piece of aluminum at the top of the tube, and riveted that piece with the tank's side.
See attached picture - I have higher resolution, (~700 KB). Let me know if interested and I'll send privately.
Carlos
CH601-HD, plans
On 20/12/06, Ron Lendon <rlendon(at)comcast.net (rlendon(at)comcast.net)> wrote:[quote] --> Zenith-List message posted by: "Ron Lendon" <rlendon(at)comcast.net (rlendon(at)comcast.net)>
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder Wink
 Filesize:  27.04 KB
 Viewed:  623 Time(s)
waj(at)quik.com
PostPosted: Wed Dec 20, 2006 9:29 am    Post subject: 601XL fuel vents Reply with quote
Thanks Larry ,I have received some good info per my request .I think I now
have it under control .I have been improving my Aluminum welding skills
,however while I was at a local sheet metal shop I saw some good Al welding
.The quality was much better than I could ever acquire .The owner of the
shop gave me a quote of $75.00 to $100.00 for welding both tanks including
the fittings and bead rolling . I have not got the tanks back yet ,hope the
shop can do this job at that price . Thanks again , Wade
waj(at)quik.com
PostPosted: Wed Dec 20, 2006 9:41 am    Post subject: 601XL fuel vents Reply with quote
Thanks Carlos ,for the info . Wade
Ron Lendon
PostPosted: Wed Dec 20, 2006 10:11 pm    Post subject: Re: 601XL fuel vents Reply with quote
Wade,
Sounds like a good price to me. I am being charged $160 per tank and think it's a bargain. I don't have the time to get as good as this guy already is.
Ron Lendon
CH 601 XLB
N601LT - Flying
