		rhyndman(at)paradise.net. Guest
				 Posted: Tue Jan 31, 2006 1:17 am    Post subject: Dynon Pitot Head |
				Has anyone installed a Dynon D10A or D100.  They come with a pitot head,
 OAT and magnetic sensor.   Does anyone have ideas on the mounting
 positions for these sensors?
 Ross
 Just started, Classic wings, the rest XS, Rotax 914.
		DuaneFamly(at)aol.com Guest
				 Posted: Tue Jan 31, 2006 10:13 am    Post subject: Dynon Pitot Head |
				Ross,
 I have just received my Dynon D100. The remote magnetic sensor is in a small
 (4"x2"x11/2") box that gets mounted inside the fuselage with a specific
 orientation to the display unit and away from any magnetic fields caused by
 electrical wires or equipment. It comes with an 18' long cable harness.
 The OAT probe "be mounted somewhere on the skin of the airplane where it will
 not be affected by heat sources".
 The Pitot probe "has been designed for under the wing installation". They
 recommend "mount it at least 6 to 8 inches below the wing and with the tip of the
 probe between 2 and 12 inches behind the leading edge". They go on to say
 that it is usually mounted about mid-wing to stay out of the effect of the prop
 and the wing tip.
 I hope this helps. Let me know if you need any other info that I might have.
 Mike Duane
 Redding, Calif
 XS Conventional Gear
